The There Are No Stupid Questions Thread
Hi, need a little help. First time Anduril 2 user here.
I got a SC31 Pro using Anduril 2, and how do I go to strobe modes?
While OFF, I go click, click, press n hold ……then what? Do I let go after a second? Do I wait for a flash or something before letting go? Do I let got a fraction of a second?
It’s supposed to be 3H then 2C, right? By the time I get to 2C I just end up in ‘Turbo’, I believe.
I’m in advanced UI coz I can toggle between smooth and stepped after ON and 3 clicks.
Thanks!
If your ceiling is whitewashed there would be no danger. If you’re wearing glasses, chances are they’re made from polycarbonate. That absorbs most of the UV radiation.
Beware of UV light that is reflected by shiny surfaces like windows, mirrors, or bathroom tiles. Think of all the tin-foil contraptions that are sold to sun lovers
The more recent version of Anduril II allows for mode switching with 3C from on in Simple UI, so it’s not a tell. Do 3C from off for battery check. If the voltage flash only runs one cycle, you’re still in Simple UI. 10H will take you to Advanced UI, and then 3H from off gets you into blinky modes, 2C to advance through the options.
Thank you very much!
You’re right - as it turns out I’m still in Simple UI! The 3C mode switching in Simple UI got me so I thought I unlocked Advanced UI.
Had to go a long way around with a factory reset then 10H to get into Advanced UI properly.
Thanks for the reply! Properly enjoying Anduril right now.
Can the color of the button light on a SC31 Pro be changed on standby or locked mode? I can do the 7C none-low-full-blinkthrob. It’s the 7H I’m trying to figure out if it’s applicable — example: I want the power button to look blue low while it’s locked out.
OR is this feature not available in the SC31 Pro (red and green for charging only)?
Thanks!
Thanks for the recommendation mate, anyone here use that charger?
Nope. Switch LED’s are red/green only on this model.
Thank you! Was afraid I wasn’t doing it right. Thanks for confirming the hardware limitation!
Just curious if anyone has any recent feedback on a Sofirn IF25A? Most of the feedback out there are a year old already and I’m wondering how it holding out…against say a TS21 or such? Is it worth USD30 and Anduril 2.0?
Seems like the IF22A has been more popular, compared to the IF25A. It has been out for a while… and I’m wondering if they’re nearing a point for an updated release.
Why does this say “New” instead of “Updated”?
Glitch in The Matrix?
What have they changed?
Use it as you would. I’d say if you think the brightness steps down too fast from a specific level then increase your temperature ceiling. Might as well check what room temperature the flashlight is reading while at it. Then there’s the aux light which you can set.
I’m still waiting on my TS10 but I’m going to probably be like you where I’ll keep settings in default at first, to see what works for me or not.
I believe top of ramp is by default 150/150 in simple UI, so yes.
Yes, again. I set my TOR in both simple and advanced UI’s at around 90/150. You’ll have to experiment to determine what works best for you.
I have Convoy L2 with sliced SST40 (when I was doing this there wasn’t SFT yet) and fet+1 driver.
Should I upgrade to SFT40?
I don’t use this flashlight anyway, like most of my collection.
I was in this thread and wondered what happens if you try to charge a CR123 battery in a light that has USB-C charging capability meant for LI 16340?
LB: I was afraid of that.
OK. Another “not stupid question”, how can one lubricate the magnetic ring on the WK40?
….I feel like this thread just allows me to ask stupid Q’s…
Didn’t try getting to the ring yet, so dunno.
