The more recent version of Anduril II allows for mode switching with 3C from on in Simple UI, so it’s not a tell. Do 3C from off for battery check. If the voltage flash only runs one cycle, you’re still in Simple UI. 10H will take you to Advanced UI, and then 3H from off gets you into blinky modes, 2C to advance through the options.
Can the color of the button light on a SC31 Pro be changed on standby or locked mode? I can do the 7C none-low-full-blinkthrob. It’s the 7H I’m trying to figure out if it’s applicable — example: I want the power button to look blue low while it’s locked out.
OR is this feature not available in the SC31 Pro (red and green for charging only)?
Just curious if anyone has any recent feedback on a Sofirn IF25A? Most of the feedback out there are a year old already and I’m wondering how it holding out…against say a TS21 or such? Is it worth USD30 and Anduril 2.0?
Seems like the IF22A has been more popular, compared to the IF25A. It has been out for a while… and I’m wondering if they’re nearing a point for an updated release.
Use it as you would. I’d say if you think the brightness steps down too fast from a specific level then increase your temperature ceiling. Might as well check what room temperature the flashlight is reading while at it. Then there’s the aux light which you can set.
I’m still waiting on my TS10 but I’m going to probably be like you where I’ll keep settings in default at first, to see what works for me or not.
