Finally, I got around to testing the 519a for myself. I replaced the emitters on my FWAA Ti from Nichia 219b sw45k to Nichia 519a sm573 DeDomed. Here are the results:
Please notice that as the dedomed 519a starts off at a higher output and yet slightly outlasts the 219b at high output. If one was to start the two emitter options at the same output level, the 519a would obviously sustain the output for longer. Similarly, if they were put at any level of output, as long as it is the same, the 519a will sustain it longer.
Last night I installed a 4500K 519a in an Eagtac D25a on the stock aluminum star with stock driver. Not bad. Output was low, which was expected with this driver and no dedoming, but tint and CRI looked great.
Today I tried installing a 5000K 519a into my Tool Ti. This time I dedomed it. WOW!!! Good output, nice color temp, rosy tint, great CRI, dedoming was super-easy!!!
Please excuse the interruption from a first post newly, but I’ve read this entire thread and am wowed at the scientific knowledge of this group.
I wanted to know about the 519A 5700K dedomed Noctigon KR4 that I just received today and took it out in the swamp next to my house to see what I ordered
I told Hank I wanted a floody bright light with good throw while wandering in Swamp at night.
Hank suggested a KR4 with 519A and 5700K and dedomed it.
All I can say (at 80 years old) is that I’m stunned at the fantastic color rendition and throw of such a nice flood beam.
I don’t know anything about the charts you show but I can attest to how well it works for this old man .
Thank you all for your persistence in chasing perfection.
I’m humbled by such erudite discussion.
The bezel is the easiest to take out on the S1R Baton II. I use a box cutter blade and a hammer. You need to be patient and careful not to damage the coating, but it is not too hard to do.
The S2R Baton II and the Warrior Mini though are another story, as the bezel is internal and there is no external lip for the razor to go in and widen.
Glad to hear it is working well for you. All the theoretical discussion can take on a life of its own that leads to endless comparing of measurements and beams on white walls, but it’s when the light proves its worth in actual use that it earns its place.
