Convoy S21E LED Flashlight
1300LM-2400LM 3000K-6500K
SFT40 LED/519A R9080 LED / smooth/stepped ramping / 1*21700 / USB-C charging / IPX4 / 100-200m throw / SMO/OP reflector
Details:
CRI: R70
Battery: 1*21700 flat head lithium battery without protection board (not included)
Switch type: electronic switch (with current standby)
Controller output current: maximum 6A
Driver instructions:
Click to start up, enter the brightness before the last shutdown, long press the switch to enter step-less dimming (brightness increase), release the switch, and long press the switch again to enter step-less dimming (brightness decrease). When the step-less dimming range (1-100%) reaches the maximum or minimum, it flashes to indicate the maximum or minimum brightness. The brightness of the flashlight can be memorized after releasing the switch.
When the driving temperature reaches 55 degrees, the brightness starts to decrease slowly, and the flashlight will use the reduced brightness as the benchmark, and the reduced brightness will be used for the next startup.
Press and hold for 0.5 seconds to ultra-low brightness 0.01A (0.2%) in the shutdown state, and click to shut down. If long-press, there will be no response (ultra-low brightness will not be memorized).
Double-click in any state to reach 100% extremely bright (the highly bright at this time belongs to the part of step-less dimming, click to shut down, and long press for step-less dimming. With memory).
In the shutdown state, click the switch 3 times to enter the burst flash (50% brightness progress) without memory function, click the switch one time to return to the original state. If the long press, no response will be made.
In the shutdown state, click the switch 4 times to enter the tactical momentary on mode. At this time, there is only one gear 100. Press the switch to directly turn on the extremely bright 100, and let go to turn off the light. 4 click to exit the tactical mode. The tactical mode also has temperature control, in any state, press the switch 5 times and the voltage indicator flashes at 1% brightness (count the number of LED flashes, corresponding to the voltage. For example, the LED flashing pause means that the voltage is 3.7V. Click to return to the original state.
In the shutdown state, click the switch 6 times, and the step-less dimming will switch to the conventional four-gear mode (1–10–30–100), click the switch, and long press the switch to change gears. To switch back to step-less dimming, just click the switch 6 times after shutting down.
In the shutdown state, click the switch 10 times to enter the locked state. The light flashes twice at 1% brightness to indicate that it is locked. In the locked state, no matter long press, short press, or double tap, it will flash once to indicate that it is in the locked state. The lock can be unlocked with another 10 clicks. Note that this is the only unlocking method. Considering that the flashlight will be accidentally unlocked due to the special situation that the positive electrode of the battery will be separated from the driving copper column and the power will be cut off due to the violent vibration. The flashlight can not be unlocked by manually loosening the tail cover and removing the battery.
Low voltage protection function: when the voltage is lower than 3V, the step-less dimming and gear mode will automatically jump to 1% to work, except for ultra-low light. But it can also be dimmed. If it continues below 3V, it will bounce back to 1%. It will shut down automatically when it is lower than 2.8V.
