jon_slider, please let us know how that 6 pin adapter works out. I don’t mind soldering pins to boards, but I don’t know anything about board design. I was hoping gchart would throw a design out on Oshpark.
Hey I am actually on BLF too. I read a lot here but I just don’t post much.
The numbers are a bit off, 1.4mm vs 1.27mm, 7.4mm vs 6.35mm (1.27 x 5). I have actually experienced this in the LT1, the spacing between the pads was a bit bigger than between the pogo pins, and they were not lined up straight either, but I was still able to flash it with a similar flashing adapter.
I hope that they are close enough on the SC21 Pro and I hope you have success flashing it.
that is my hope as well
thanks for all your time helping me learn to build a pogo adapter for SC21 Pro
Im finally starting to get the picture… LOL
Questions about Parasitic Drain on the SC21 Pro
can someone with proper tools and skills inform
- What is the Parasitic Drain of the button LEDs on Low and on High
- What is the Parasitic Drain with the main LED ON at lowest mode, w button light on low?
- IS there LVP for the Button light, or Can it overdischarge a battery?
backstory, recent reports on the TS10 show no LVP for button lights, and using High Aux (they are wired as button lights), on that light causes overdischarge.
- It is not RGB, but single color aux LED
- LVP for single color aux LED is not implemented in official Anduril yet
Thus it will be affected as well, like all Anduril lights with single color aux LED.
thank you,
that is why I am asking what the Parasitic Drain is,
on the Green Button Light on High, of the SC21 Pro.
I want to calculate how many days before Overdischarge.
fwiw, that green button light does not produce a measureable output on my light meter
otoh, the TS10 Red Aux on High, measure 0.2 lumens (and overdischarges within 5 days of 24/7).
fwiw, The Floor output of 1/150 on the main LEDs of the TS10 also measures 0.2 lumens.
Hey Jon,
I measured the parasitic drain on my SC21 pro at 2.5mA on high and 100µA on low.
With an 800mAh battery, that’s roughly 13 days on high or a year on low.
Thank You!
I finally figured out how to reflash Anduril 2 onto the SC21 Pro
the programmer I got from gchart for the SP10 Pro, also works for the SC21 Pro, with a separate harness…
I did not have pogo pins, I soldered the wires to the flashing pads on the driver. The wire harness I used for the SC21 Pro, came from a separate purchase on aliex…
all this thanks to Adair21’s post,
plus lots of help from several kind people who coached me privately to install all the software and driver, on my iMac.
Question about battery type
is the Sofirn 16340 Battery an ICR, IMR, or INR chemistry?
Alright you flashing fiends… while I think the decision on the flashing pad arrangement of the SC21 Pro is just silliness, I just can’t help but make flashing keys (especially when I am persuaded to do so…). I just whipped these guys up, I’ll have them available whenever Oshpark can get them to me (likely a couple of weeks):
Depending on what style of programmer you have, I made two different types of adapters, one with the resistor and diode on board, one without. Really, the one with the resistor and diode would cover both scenarios - you would just connect the RX line and leave the TX empty… but I created and ordered the 3-wire version before I thought about that. Oh well!
3-wire version:
4-wire version:
yay,
Im getting ready to order a couple more SC21 Pro, because, tailmagnet, lighted button, built in charging, great beam, moddable, get the battery too… Makes a perfect Total Package gift for someone new to LiIon…
notice the button light stays On when main LED is On…
Hot Tip
if you prefer the button light Off when main LED is On, reflash w gchart’s Awesome TS10 Hex File.
and btw, the SC21 Pro button is Easy to find by touch too, it sticks out nicely. :innocent:
I keep one in my car… can be a hands free car camping/tailgating/tire changing lamp, thanks to the magnet and hatclip, and can also be recharged in the car… w the A to C USB cable included in the package.
And with gchart’s Awesome Hex File and Flashing Kit, it adds Anduril 2, with Firefly lows, and LVP on the button lights. State of the Art!
30% off SC21 Pro
(not affiliated, just a fan)
Discount code: B1VJQER6
great work
confused by the choices, I will take whichever Programming kits for both TS10, and SC21 Pro, that you want to sell me. I have a couple TS10 inbound, to fill the gap since this pair went to new homes:
You are an absolute legend! Put me down for a 3-wire version. I’m tired of using my embarrassing homemade key
You got it brother. I’ll hit you up when they come in
Yea, that is pretty ghetto….but effective.
Lol!
Im interested.
Gchart, please put me down for the 4 wire version with diode. That would work great with the UPDI programmer I have.
Thank you, Bob.
Jon, thanks for the link. I just ordered 3 more, one of each color, with battery of course. I see some emitter swaps in my future
congrats, me too
here are some recents
I think Im missing one w sw45k :innocent:
