FastTech New Arrivals & Promotion
1*XHP70 & 1*COB 1000LM 6500K & Red LED Flashlight w/Focus Zoom
6-mode / 1*18650/3*AAA / USB-C charging / IPX4 / 100-200m throw / window breaker
Beam range: 100-200 m
Flashlight modes: LED Hi > LED Lo > LED Strobe > COB White Light Hi > COB Red Light > COB Red Light Flash
Lens type: Convex Lens
Mode count: 6
Switch Placement: Side
Switch type: Clicky
Zooming: Yes
“H4 5.75” 200W 20000LM LED Motorcycle Headlight”:https://www.fasttech.com/products/9759020
IP67 / fast heat dissipation
Details:
Operating temperature: –40 to 85’C
Life: 50000 hours
High beam: white light
Low beam: white light
Daytime running lights: white light
Turn signals: amber
2000LM 6500K 50m Diving LED Flashlight
XHP70 LED / 1-mode / 2*26650/2*18650 / IPX8 / 200-300m throw
Details:
Beam range: 200-300 m
Flashlight modes: Hi
Mode count: Q
Zooming: No
Fenix TK22 TAC 2800LM 6500K Tactical LED Flashlight w/21700 Battery
authentic / Luminus SFT70 emitter / 7-mode / IP68 / 540m throw / 74000cd / mechanical operation
Details:
The Fenix TK22 TAC military flashlight stands out in performance and tactical deployment. Designed with the tactical and on-duty lighting needs in mind, the TK22 TAC features Tactical mode and Duty mode. Included with a 21700 rechargeable Li-ion battery, the TK22 TAC is an up to 2800 lumens flashlight in turbo output while throwing its beam a distance up to 540 meters. In Duty Mode, the TK22 TAC delivers 5 output modes including a strobe. Switch to the Tactical Mode to operate for fast, simplified selection of turbo and instant strobe. Perfect for professional use, security and law enforcement, you can count on the TK22 TAC to deliver reliable, powerful lighting for a variety of situations.
2800 lumens maximum output; 540 meters maximum beam distance.
One Luminus SFT70 LED with a lifespan of 50,000 hours.
Included a 21700 rechargeable Li-ion battery with USB Type C port.
Mechanical operation with rapid react dual mode.
Tactical and Duty modes for flexibly needed choice and operation.
Patented dual-function tactical switch for instantly tactical activation.
Single-handed toggle switch for mode selection.
Lockout function avoids accidental activation.
Innovative APF technology system make super tactical flashlight.
Made of durable A6061-T6 aluminum.
Premium type HAIII hard-anodized anti-abrasive finish.
1m impact resistance.
Fitted with high-performance industrial components, the light could operate (certain function fails due to different batteries) normally in temperature from –35 to 45’C.
Fenix BC21R V3.0 MTB Road Cycling Bicycle LED Front Light Helmet Flashlight w/18650 Battery
authentic / Luminus SST40 emitter / 5-mode / 1200LM / 6000K / USB-C charging / IP68 / 142m throw / 5082cd
Details:
The Fenix BC21R V3.0 is a professional bicycle light for mountain and road cycling, suitable for high-intensity and long-distance cycling users. The bicycle light emits an impressive output of 1200 lumens and can be seen at an impressive 142 meters. The light is USB Type-C rechargeable and gets powered by the included 18650/2600mAh battery. It can be used with a bicycle helmet holder and can be installed on a GoPro standard interface for safer riding. Innovatively designed quick-release mount and full-metal housing for better dissipation allow this versatile light to illuminate your trails confidently.
1200 lumens maximum output and 142 meters maximum beam distance.
A Luminus SST40 LED with a lifespan of 50,000 hours.
Included a 2600mAh/18650 Li-ion battery.
USB Type C charging.
Quick-release design, two-step assembly and disassembly.
Easy and fast operation with a single switch.
Boot-up battery level indication and low-voltage warning.
1.5m impact resistance
NexTool 12-in-1 Multi-functional 900LM 6500K & 4000K & RGB LED Flashlight w/Focus Zoom
4*LEDs / 9-mode / w/9.36Wh battery & sound activated 360’ side light / USB-C charging / IPX4 / 245m / power bank & mini speaker function
Details:
12-in-1 multi-functional flashlight: White/red/green/blue focus flashlight, mini speaker, music rhythm light, work light, camp light, sound atmosphere light, warning light, sound and light alarm, power bank in one. It could follow you to anywhere.
360 degree adjustable angle side lamp: Patented magnetic fixation bracket, realize 360 degree lighting Angle adjustment, free hands, easy to choose a better lighting angle. In addition to white light and red light safety warning, suitable for vehicle maintenance, camping camp lights and other scenes.
With the sound atmosphere lamp you could feel the rhythm of music. Sound atmosphere lamp can sense the change of external sound, according to the rhythm of music display. Different lighting effects, available in computer desktop, car interior, outdoor Camp-light scene. Light up the atmosphere anytime.
High decibel buzzer + strong light flash Double protection against danger smart and safe protection. In case of emergency, long press 3.5 seconds can trigger the flashlight beep flash mode, simple and direct operation. When you’re in danger, your brain gets spooked panic and tension dominate consciousness, “ready to explode”,without complex thinking is undoubtedly practical and efficient.
Highlight four-color main light.The flashlight has built-in entry-level mini speakers, bringing you a different experience.
The side lights can move with the rhythm of the music.
Built-in large-capacity lithium battery, which can be used as a power bank.
Support telescopic focusing, adjust the light distance.
IPX4 protection level.
Power bank capacity: 1400mAh (5V 1A)
Speaker power: 4Ω 2W
Impact resistance: 1m
FastTech Summer Blowout Sale - 10% Sitewide Off
Dear valued customers,
Summer is the perfect time to sit back, relax and soak in some rays. We are preparing for a 10% off Sitewide Summer Blowout Sale! Hooray for the Hot Summer Day!
Summer Blowout Sale
Offer: Sitewide 10% off
Valid Date: July 20, 2022 - July 22, 2022 (UTC-6)
Coupon Code: SUMMER22
Customers can pay via PayPal or credit card for the gift card to get an extra 3% free value instantly.
10% does not a Blow Out make.
Aww, I missed this chance.
Nitecore TM20K 20000LM 6500K LED Flashlight w/17.76Wh Battery
authentic / 19*Cree XP-L2 emitters / 8-mode / USB-C QC fast charging / IP68 / 290m throw / 22200cd / Strobe Ready & TurboReady
Details:
Utilizes 19*Cree XP-L2 LEDs with a max output of 20,000 lumens
Max peak beam intensity of 22,200cd and max throw of 290 meters
Lightweight, rigid and fast cooling tube built from unibody CNC technology
Built-in 2*21700 rechargeable Li-ion batteries (9,600mAh in total)
Intelligent Li-ion battery charging circuit with USB Type C charging port
Ambidextrous tactical buttons specially designed for tactical activities
Interchangeable STROBE READY and TurboReady settings
STROBE mode uses randomly changing frequencies for stronger dizzying effects
Highly efficient constant current circuit provides stable output up to 13 hours
Integrated Advanced Temperature Regulation
Optical lenses with double-sided scratch resistant coating
Constructed from aero grade aluminum alloy HA III military grade hard-anodized finish
Waterproof and dustproof rating in accordance with IP68 (2 meters submersible)
Impact resistant to 1 meter
Tail stand capability
Head diameter: 50mm
Fenix E18R V2.0 1200LM 6000K EDC LED Flashlight w/ARB-L16-700P Battery
Authentic / Luminus SST40 emitter / 6-mode / USB-C charging / IP68 / 146m throw / 5397cd / magnetic tail / two-way clip / dual lockout function
Details:
The Fenix rechargeable E18R V2.0 is a high-performance flashlight in an ultra-compact, everyday carry design. This flashlight produces a maximum of 1200 lumens with a useful beam of 146 meters. Powered by an included ARB-L16-700P rechargeable Li-ion battery, this flashlight is fully rechargeable via its USB Type C charging port. Convenient side switch activates all lighting modes and includes a battery level indicator - helping you always know the status of your battery. The magnetic base facilitates hands-free use for attaching the light to most metal surfaces. Waterproof and dustproof, the Fenix E18R V2.0 can handle more than just around-the-house tasks. A reversible pocket clip keeps the light secure whether you prefer bezel-up or bezel-down storage/carry. Take this flashlight on a hike, use at work, or keep it in care for emergencies. The E18R V2.0 is a great everyday carry light that can do much more.
1200 lumens maximum output and 146 meters maximum beam distance.
Utilizes Luminus SST40 cool white LED with a lifespan of 50,000 hours.
Included one ARB-L16-700P rechargeable Li-ion battery.
Magnetic tail for hand-free use.
Two-way clip permits light to be carried bezel up or bezel down.
Simple output selection with the side switch.
Boot-up battery level indication for instant checking of remaining battery level.
Made of A6061-T6 aluminum.
The E18R V2.0 has the innovative Fenix IOP - which protects against high surface temperatures. IOP ensures that the surface temperature does not exceed 60’C to prevent the risk of burns.
Head diameter: 22mm
Tube diameter: 22mm
Manker Timeback III 2500LM 4000K/6500K LED Flashlight
4*Luminus SST20 emitters / 8-mode / 1*18350 / 200m throw
Beam range: 200 m
Flashlight modes: Moonlight > Lo > Mid > Hi > Turbo > Strobe > Beacon > SOS
Lens type: Tempered Glass Lens
Mode count: 8
Convoy L8 6400LM 5700K LED Flashlight
Luminus SBT90.2 emitter / smooth/stepped ramping / 1*26800 / USB-C charging / IPX6 / 1461m throw / 25A output
Details:
Luminous flux: maximum 6400LM, theoretical LED output value, actual light output is lossy, for reference only
Illumination: maximum 534KCD
Range: maximum 1461m (ANSI standard, for reference only)
Modes: click —-> on or off, long press —-> ramps, double click —-> turbo, click 4 times —-> Tactical mode, click 10 times —-> block
Head diameter: 81mm
Battery tube diameter: 35.5mm
Convoy S21E LED Flashlight
1300LM-2400LM 3000K-6500K
SFT40 LED/519A R9080 LED / smooth/stepped ramping / 1*21700 / USB-C charging / IPX4 / 100-200m throw / SMO/OP reflector
Details:
CRI: R70
Battery: 1*21700 flat head lithium battery without protection board (not included)
Switch type: electronic switch (with current standby)
Controller output current: maximum 6A
Driver instructions:
Click to start up, enter the brightness before the last shutdown, long press the switch to enter step-less dimming (brightness increase), release the switch, and long press the switch again to enter step-less dimming (brightness decrease). When the step-less dimming range (1-100%) reaches the maximum or minimum, it flashes to indicate the maximum or minimum brightness. The brightness of the flashlight can be memorized after releasing the switch.
When the driving temperature reaches 55 degrees, the brightness starts to decrease slowly, and the flashlight will use the reduced brightness as the benchmark, and the reduced brightness will be used for the next startup.
Press and hold for 0.5 seconds to ultra-low brightness 0.01A (0.2%) in the shutdown state, and click to shut down. If long-press, there will be no response (ultra-low brightness will not be memorized).
Double-click in any state to reach 100% extremely bright (the highly bright at this time belongs to the part of step-less dimming, click to shut down, and long press for step-less dimming. With memory).
In the shutdown state, click the switch 3 times to enter the burst flash (50% brightness progress) without memory function, click the switch one time to return to the original state. If the long press, no response will be made.
In the shutdown state, click the switch 4 times to enter the tactical momentary on mode. At this time, there is only one gear 100. Press the switch to directly turn on the extremely bright 100, and let go to turn off the light. 4 click to exit the tactical mode. The tactical mode also has temperature control, in any state, press the switch 5 times and the voltage indicator flashes at 1% brightness (count the number of LED flashes, corresponding to the voltage. For example, the LED flashing pause means that the voltage is 3.7V. Click to return to the original state.
In the shutdown state, click the switch 6 times, and the step-less dimming will switch to the conventional four-gear mode (1–10–30–100), click the switch, and long press the switch to change gears. To switch back to step-less dimming, just click the switch 6 times after shutting down.
In the shutdown state, click the switch 10 times to enter the locked state. The light flashes twice at 1% brightness to indicate that it is locked. In the locked state, no matter long press, short press, or double tap, it will flash once to indicate that it is in the locked state. The lock can be unlocked with another 10 clicks. Note that this is the only unlocking method. Considering that the flashlight will be accidentally unlocked due to the special situation that the positive electrode of the battery will be separated from the driving copper column and the power will be cut off due to the violent vibration. The flashlight can not be unlocked by manually loosening the tail cover and removing the battery.
Low voltage protection function: when the voltage is lower than 3V, the step-less dimming and gear mode will automatically jump to 1% to work, except for ultra-low light. But it can also be dimmed. If it continues below 3V, it will bounce back to 1%. It will shut down automatically when it is lower than 2.8V.
FastTech BACK-TO-SCHOOL 10% OFF SITE-WIDE SALE Coming Soon!
BACK-TO-SCHOOL Sale
Offer: Site-wide 10% off
Valid Date: Aug 17th - Aug 19th, 2022 (UTC-6)
Coupon Code: AUG2022
Customers can buy gift certificates via PayPal or credit card to get an extra 3% free value instantly. The gift certificates can apply to E-cigarette product orders.
Convoy S21D 2500LM LED Flashlight
4*Nichia 519A emitters / 12-group / 1*21700 / 50m throw / 8A output
Details:
Bead TIR lens makes the light much softer, The larger the angle of the lens, the more scattered the light.
Head diameter: 32.1mm
Tube diameter: 27.2mm
Driver: 12 groups, 8A constant current, internal temperature protection management, the current of other gears can be calculated according to the proportion. Under temperature control, the maximum current will continue to drop to about 20%
Required battery type: 21700 lithium battery (unprotected and length not more than 71mm)
CRI: Ra > 90, R9 > 90, R12 > 70
12 groups:
Click the switch to turn on / off the flashlight, touch the switch to select the mode
If the flashlight is on, tap the switch 20 times quickly to enter setup mode. (In a visual interface, whenever you click an option, it means that the option is selected. The flashlight has no visual interface. It blinks to represent an option, and “touch the switch in the process of blinking” means to select the option. )
Option 1 (normal-flash 1 time + buzz-flash): Touch the switch to enter the sub-option to select the mode group, if the user has no operation. Configuration mode will enter option 2.
Sub option 1.1 (normal-flash 1 time): Touch the switch to select mode group 1 (0.1, 1, 10, 35, 100%, strobe, beacon, battery check)
Sub option 1.2 (normal-flash 2 times): Tap the switch to select mode group 2 (0.1, 1, 10, 35, 100%)
Sub option 1.3 (normal-flash 3 times): Tap the switch to select the mode group 3 (100, 35, 10, 1, 0.1%)
Sub option 1.4 (normal-flash 4 times): Tap the switch to select mode group 4 (1, 20, 100%, strobe, beacon, check battery, SOS).
Sub option 1.5 (normal-flash 5 times): Tap the switch to select mode group 5 (1, 20, 100%).
Sub option 1.6 (normal-flash 6 times): Tap the switch to select mode group 6 (100, 20, 1%).
Sub option 1.7 (normal-flash 7 times): Tap the switch to select mode group 7 (0.1, 1, 10, 50, strobe, beacon, battery check, SOS).
Sub option 1.8 (normal-flash 8 times): Tap the switch to select mode group 8 (0.1, 1, 10, 50).
Sub option 1.9 (normal-flash 9 times): Tap the switch to select mode group 9 (50, 10, 1, 0.1).
Sub option 1.10 (normal-flash 10 times): Tap the switch to select mode group 10 (1, 10, 35, 100).
Sub option 1.11 (normal-flash 11 times): Tap the switch to select mode group 11 (100, 20, strobe).
Sub option 1.12 (normal-flash 12 times): Tap the switch to select mode group 12 (100% only).
Option 2 (normal-flash 2 times + buzz-flash): Tap the switch to activate the mode memory or inactive, if the user has no operation. The flashlight will enter the last mode.
Battery check instructions:
< 2.95V (1 flash)
2.95-3.25V (2 flashes)
3.25-3.55V (3 flashes)
3.55-3.85V (4 flashes)
> 3.85V (5 flashes)
HaikeLite HK05 30000LM 3000K LED Flashlight
5*SFN60 LEDs / smooth/stepped ramping / 3*21700 / USB-C charging / IPX7 / 1000m throw / 250000cd
Details:
Stepless dimming: When power on, press and hold the switch for stepless dimming to increase and release the brightness, let hand go when you find the brightness you want.
Turbo mode & temperature control protection: Double-click quickly in any mode to enter turbo. And when the temperature of the flashlight reaches 55’C, there will be a temperature control protection function, the brightness will slowly drop to 4500 lumens, and continue to be on for a long time (about 75 minutes). Then when the temperature of the torch is lower than 48’C, brightness will rise again.
Turbo - Strobe - SOS - Tactical flash: When turned on, double-click to turbo, double-click again to strobe, double-click again to S0S mode, and double-click again to tactical flashing. Then single click any mode to turn off normally.
Power indicator:
< 3.2V, blue flashes
< 3V, red flashes
< 2.8V, It will automatically turn off
Charging: Red on
Fully charge: Green on
Output for phone as a power bank: Blue on
Charging power: 5V 3A or 9V 2A or SCP5V 4.5A, two-way fast charging.
Switch between stepless dimming & gear mode dimming: when turned on, three clicks to switch between stepless dimming and gear mode.
Gear mode introduction: Moon-200lm, Low-2000lm, medium- 4500lm, High-8000lm, double-click to Turbo-30,000lm, double-click again to Strobe.
Lock mode:
Lock the machine: Turn off, then press and hold for three seconds
Unlock the machine: Turned on, then press and hold for three seconds
Fenix HT30R 500LM 6500K LEP Flashlight w/21700 Battery
authentic / 1-set 10W white laser module / 3-mode / USB-C charging / IP68 / 1500m throw / 600000cd
Details:
The Fenix HT30R is a high-performance white laser flashlight. A Class 1 laser stimulates a fluorescent crystal to create a broad-spectrum white light, allowing this flashlight to throw a jaw-dropping distance of 1500 meters - that almost equals a mile! The laser light creates a more focused spotlight beam, than a standard LED flashlight, with little spill-over light. The tactical tail switch operates on/off and momentary on while the functional tail switch operates the 2 lighting modes and instant strobe. Extend runtimes when using the included 21700 Li-ion battery and constantly get powered by the hidden USB Type C charging port. Other features include a battery level indicator and it is IP68 rated dustproof and waterproof. Made for applications where distance is the priority such as hunting, search and rescue, the Fenix HT30R flashlight will never disappoint.
The white laser light source, with an output of 500 lumens, emits a broad spectrum of white light similar to the LED spectrum, which not only retains the high collimation characteristics of a traditional laser but also eliminates the harmful beam a monochromatic light produces.
Manufactured with high-performance industrial components, the light will operate normally (certain functions will fail if non-Fenix certified batteries are used) in temperatures from –35 to 45’C.
500 lumens maximum output, 1500 meters maximum beam distance.
Fitted with a set of 10W high-performance white laser module.
Included a Fenix ARB-21-5000 V2.0 Li-ion battery.
Instant activation and instant strobe with dual tail switch.
Hidden USB Type C charging port.
Internal dual-spring structure ensures stable lighting even under severe impact.
Head diameter: 40mm
Tube diameter: 26mm
Working voltage: 2.85-4.2V
Dear all,
It’s that time of year again! The leaves are starting to change color, the days are getting shorter, and kids are getting ready to head back to school. Back to school, back to being awesome. Let’s Join FastTech BACK-TO-SCHOOL Site-wide sale!
BACK-TO-SCHOOL Sale
Customers can pay via PayPal or credit card for the gift card to get an extra 3% free value instantly. The gift certificates can apply to E-cigarette product orders.
Back To School Giveaway
Enter to Win (Any Purchase of $20 or More)
Ends on Aug 22nd, 2022 (UTC-6);
Winners will be chosen on Aug 23rd, 2022 (UTC-6).
Fenix PD25R 800LM 6000K EDC LED Flashlight w/16340 Battery
authentic / Luminus SST20 emitter / 6-mode / 1*CR123A / USB-C charging / IP68 / 250m throw / 15530cd / two-way clip
Details:
The Fenix PD25R flashlight a portable flashlight with a hidden USB Type C charging port. The PD25R blasts an amazing 800 lumens and a total distance of 250 meters. The PD25R is powered by a single 16340 rechargeable Li-ion battery (included) or can operate on a disposable CR123A Lithium battery. The boot-up battery level indicator lets you always know the battery’s status. On/off and momentary-on are activated with the tactical tail switch and six lighting modes are selected with the side switch including a strobe mode. Carry the Fenix PD25R how you want - on a backpack, belt, or Molle system with the two-way body clip. Compact and built-tough with an IP68 dustproof and waterproof rating, this flashlight is perfect for just about any outdoor or work activity.
800 lumens maximum output, 250 meters maximum beam distance.Luminus SST20 LED with a lifespan of 50,000 hours.
Powered by a 16340 rechargeable Li-ion battery and compatible with a CR123A Lithium battery.
Toughened ultra-clear glass lens with an anti-reflective coating.
Battery level indication and low voltage warning.
Instant power activation with momentary tactical tail switch; simple output selection with side switch.
Anti-roll and anti-slip body design; included two-position body clip.
Reverse polarity protection, to protect from improper battery insertion.
PD25R is deemed fit enough to withstand dust, dirt and sand, and is resistant to submersion up to a maximum depth of 2m underwater for up to 4 hours.
Head diameter: 24mm
Tube diameter: 24mm
