Why can I see a light from farther away than it shines?
The illuminated object eats energy and scatters the light.
The human eye can see single photons.
The main issue is that the reflected light also follows an inverse square law, so unless you are illuminating a mirror or retroreflective surface, the returned light is more like inverse fourth power. I first learned about this while working with a company that makes depth sounders. A basic illustration can be found here: https://www.edn.com/inverse-fourth-power/
This was a huge gimmick in an infomercial some time ago. Instead of stating throw distance, they would say “this flashlight is so powerful, it can be seen from 10 miles away.”
This woulds lead many people to believe that the light has a 10 mile throw. Meanwhile in reality that light only has a 10 foot throw.
I love that the person in the diagram is actually you lmao
It depends upon whether you consider light to be a wave or a particle—it is neither but has properties of both.
If you exposed some film to a distant light source, it would not show a point of light like our eyes see, just an inappreciable amount of basically uniform exposure caused by the dim light. The same thing happens with a light meter when the light is too dim to pick up. This is because light travels in waves and much like waves on the ocean they seem to have no point of origin. But our eyes don’t work like a piece of film or a light meter. If you put the film in a camera, the lens focuses the parallel waves of light into a point, concentrating the dim light so it stands against a dark background in a photo. Our eyes have lenses that work much the same as a camera lens. Since the light is concentrated into a point by the lens in our eyes, we can see it at great distances (billions of light years for stars).
When we shine a flashlight on something in the distance, we see only the light reflected back to us. Not only do we have to deal with the light lost on the return trip, but the reflected light is scattered and is no longer in parallel waves and will no longer focus into a distinct point by the lenses in our eyes or in the lens of a camera.
In a dark place, you can see a light on a sub-lumen moonlight setting that is pointed at you from quite a distance. Even if the same light is used in a totally dark room the eye cannot see any light being cast of a white wall 10 feet away. Sorta the same thing at work with brighter lights and greater distances.
The story on battlefields used to be an enemy could see a cigarette being lighted by a Zippo from miles away.
At a certain distance that light would disappear. If you didn’t move the light source or your body; how long would it take to “see the light”?
The illustration shows two point light sources while reflected light is none.
We discussed this already:
Edit: I made this observation when I had a flashlight mounted on binoculars. The magnified image of an illuminated object was way dimmer than when looking with the naked eye. This was counterintuitive and so I made that model.
The inverse square law applies to an omnidirectional (or at least conical, which is a fixed fraction of a sphere) light source. Perfectly collimated light, like a laser beam, doesn’t diminish at all. This principle applies to both the source and the reflector. A flashlight, unless it’s a laser, is a conical light source. The reflecting surface is typically omnidirectional (roughly hemispherical) as well. To see this, imagine shining a flashlight at a white wall, and walking around the room looking at the wall from different angles. You will be able to see the hotspot from anywhere, because the wall mainly scatters the light rather than reflecting it. This, incidentally, is why retroreflective road signs look so much brighter than everything else at night — because they are reflecting, not scattering, your headlights.
It applies to a point light source, which reflected light is not.
That’s why a phtographer can measure light from an illuminated object at any distance. Try for yourself and measure with your phone an illuminated wall. Halve the distance. What are the figures you get?
It applies to an omnidirectional point source. If the point is directional, like single photon, there is no loss of intensity at any distance — that’s just conservation of energy. The correct way to think about the problem is to look at the statistical behavior of single photons. Your emitter sends photons onto some two-dimensional area (hence inverse square distribution), and then each photon is scattered randomly by the surface (unless it is a true reflector), which means it can go in any direction. Each photon’s point of impact thus behaves roughly like an omnidirectional point source, and therefore the number of scattered photons returning to the two-dimensional area of your retina also follows an inverse square law.
Just do the proposed experiment.
Edit: I did :smiley: . Interesting.
If I double my distance from a uniformly illuminated wall, I’m getting 1/4 the intensity from each square inch of wall, but my lens is taking in 4 times the area, so there’s no net effect. That experiment doesn’t tell us anything. Or are you proposing something else?
For large enough distances lasers still follow the square distance law as we still have difraction, so you can’t expect to shine a laser to the Moon and receive it back from a mirror without attenuation. For close enough distances the dispersion is much smaller than the original beam width so the square distance law may be ignored.
One of my viewers suggested I use an eye chart and sit my camera off to the side, then shine a flashlight at it from various distances to measure usable light. My thoughts would be that the camera is then only seeing the light one way and would therefore be brighter and inaccurate, yes? I’d need to take the photo from where I’m shining the flashlight from.
We’re talking about brightness - luminosity.
See:
Camera in manual mode, histogram plots, distance halved.
I see the brightness doesn’t change significantly, no matter the distance.
The JPG already has some processing applied, they only have 256 possible brightness levels so the scale is compressed in a non proportional way (for example 210 may be 4000 and 220 8000), you would need to shoot in RAW if your camera supports it and disable as much processing as possible.
https://www.cambridgeincolour.com/tutorials/gamma-correction.htm
No, it’s not. Be rest assured I know what I’m doing.
Please provide your data if you doubt the results.
