Please check your message, thank you!
PM sent!
Please check your message to receive the code, thank you!
Code please. Thank you.
Quick question…
Hard hard is it to get the the lens. I need to sand it to disperse the beam.
The 30-off coupon on the product page was removed by Amazon.com. Code alone is only good for 15 off.
code please
Agreed!
@Sofirn, Please clarify and update!
Without the Amazon.com coupon, how will we be able to purchase the SC21 for $19.79?
45% Discount code please!
I re-set the 30%off coupon, will show up on the sales page again 5 hours later.
Code still available?
Can you pm the 15 % code please . Thanks
It’s available. Please check your message, thank you!
I just replied to your message. Thanks for your patience! :innocent:
This mini light is a floodlight. Or Or am I not getting what you mean?
What I suspect "dave101" is asking, is how difficult is it to remove the bezel so that he can reach & remove the lens. I will also assume that despite it being a "floodlight" as you describe, he would still like to soften the beam further by etching it with sandpaper.
If that's "dave101's" plan, personally I would recommend using diffusion film, or even 3M's Scotch Magic™ tape (the cloudy type) instead, either of which can be easily removed if desired.
If you have a tool, you can remove it not hard. I saw some flashlight enthusiast changing the emitter or lens of SC21 and made cool shapes.
Sofirn:This mini light is a floodlight. Or Or am I not getting what you mean?
dave101:Quick question… Hard hard is it to get the the lens. I need to sand it to disperse the beam.
What I suspect “dave101” is asking, is how difficult is it to remove the bezel so that he can reach & remove the lens. I will also assume that despite it being a “floodlight” as you describe, he would still like to soften the beam further by etching it with sandpaper.
If that’s “dave101’s” plan, personally I would recommend using diffusion film, or even 3M’s Scotch Magic™ tape (the cloudy type) instead, either of which can be easily removed if desired.
Code please! Thank you!
Code please! This light would make a great gift to a trusted friend…
Code please!
