FW3A Troubleshooting / FAQ
But only once and with a very specific heating profile. Otherwise they will get damaged. 80 °C is a pretty safe temperature, though.
They can actually handle higher heat than that, but briefly and people have ran the leds to the point of the heat melting the solder. My point was that 85° is a good upper level to not exceed due to the battery. Then there is a huge gap from 85°C to 200°C. So no one really needs to worry about the led or driver components. Worry about battery heat first (and not burning your hand). Don’t waste time worrying about the driver and led. They are quite robust.
JasonWW, SammysHP, thank you for detailed explanation!
[quote=JasonWW]
[quote=Alexxey]
Actually I checked one more time, ramp is not so smooth near to moonlight level. I can see several barely visible steps (starting from moon) before it gets nice and smooth. Is it same for original version or is it a bad sign?
It’s not very likely you got an old original model with all 3 channels. It’s not the newest version for sure either which is one channel (no 7135 chips). So you might have that middle version. It’s hard to say for sure. Even my early model is not perfectly smooth around the very lowest levels.
You should decide if whatever version you have is going to work for your needs and not worry so much how many channels you have. That is a tiny detail that makes a tiny difference. Even a FET only version should be pretty decent except for the very lowest levels around moonlight. It’s really not that big a deal as long as it’s operation and functionality is good.
Yeah I know, it’s just some deep desire of a perfect toy :slight_smile:
For sure it’s not the old original version, but what if Lumintop decided to make fw3a great again? I guess there is no way to tell other than unsolder something.
Comments like this made me worried in the first place actually :slight_smile: - Which Lumintop FW3A to buy? - #10 by BlueSwordM
I get the feeling that was Blueswords way of saying he’s disappointed in Lumintop.
If he tried a modern one he may think it was fine.
I thought there were basically 4 versions of the FW3A made:
  • First version: 7+1+FET driver, no tailcap retaining ring. <— good
  • Second version: 7+1+FET driver <— best
  • Third version: 1+FET driver <— bad (not efficient at mid-to-low power settings).
  • Fourth version: FET driver <— worst (not efficient at mid-to-super low power settings and lacks moonlight).
So basically, only the 1st and 2nd versions have the best driver. The 1st and 2nd versions should have 6 chips visible on the underside of the driver when the head is removed from the body.
The 3rd and 4th versions should have a flat underside of the driver with no visible chips. The final 7135 chip is on the topside of the driver so can’t be seen without removing the driver. However, a user should easily be able to distinguish a 3rd from 4th version without disassembly simply by setting to the lowest possible ramp. The 3rd version will have a really low moonlight with which you can easily stare into the emitters while the light is on from close range with dark-adapted eyes without discomfort. The 4th version won’t have moonlight and will be too bright to comfortably stare into the emitters at their lowest setting.
The original poster of this thread described looking into the bottom of the head and seeing 6 chips on the underside of the driver. This means he should have either the first or second version, … meaning he got a good one.
At least that’s my recollection.
Sounds right to me.
Four basic hardware differences sound right to me too. To those, you can add firmware variations. I have no idea how many versions were applied to production lights. I have an early April 2019, first batch with no tailcap retainer ring as well as a June 2019 version and there is a slight difference in what happens when the lights are e-locked and the switch button depressed and held.
The April ’19 light comes on in moonlight no matter how many clicks the switch gets before being held down. The June ’19 light produces genuine moonlight mode when given a 1H. Or 3H, 5H, etc (odd numbers). When the switch is given a 2H, 4H, 6H, etc. (even numbers) the light is on at a brighter level. I prefer that. It gives me a choice depending on the circumstances. That June light operation pleased me so much that I reflashed the April ’19 light with the June ’19 firmware. (That is the behavior when set to smooth ramping. When set to stepped-level operation the first, 1H produces the brighter level and the 2H produces the moonlight.) Both lights use that June ’19 firmware to this day. It does what I want and I have seen no need to change to any later version.
I’ve ended up with two of the elusive purple TK-editions. Both have the plastic tail retaining ring, two-step lockout brightness, and full three channels.
I haven’t heard of any middle revisions with 6 7135s on the underside that don’t have three channels. So it sounds like a good one.
I rarely use them anymore. Eventually the switches got unreliable, I believe due to tube contact issues. My KR4 took over their duties. The sprung tube is just superior.
Thank you for such a detailed explanation!
Looks like i got 2nd version despite the fact that I bought it last week on aliexpress (SST-20 black). Or maybe there are 5th version with all channels back in place?
Also the button is all great, clicky and reliable. Hope it will stay that way.
Also I got 2 step brightness on lockout. Moon on 1H, somewhat brighter on 2H. But none of the 3H, 4H etc doesn’t work (I mean it’s all moon).
And 1 more thing. I also got bunny on the button. Whed do they start doing it?
Does kapton tape solve shorting problems?
Recap:
My FW3A with 18350 tube would periodically start shorting out after loosening/tightening the tube for physical lockouts. I’d have to “fiddle” with it… wiping down the tube, using a cotton swab on the mcpcb… and usually that would work. But then I had a bizarre instance of my FW3A suddenly turning itself on to turbo in the middle of the night (thankfully I’d pointed it towards me before falling asleep, so the bright beam woke me up before it seriously overheated). THAT was the last straw. I stopped using it.
Someone had suggested applying some kapton tape to the very end of the tube. Kapton is strong, extremely thin tape that insulates as well if not better than your typical electrical tape. I’d misplaced my roll… couldn’t recall where I’d put it. So periodically I’d look around. FINALLY, I found it. So I applied kapton tape to the tube, aligning the edge of the tape to the edge of the forward end of the tube and made one good 360 degree wrap with some overlap. It seems to work. I can loosen and tighten the FW3A repeatedly and it works fine.
The only exception I’m finding is that if I screw down the tube extra tight, it shorts out. As long as I don’t screw down quite that firmly, it’s OK.
i just put 3 narrow strips of black tape at the 2 ends of the ‘signal tube’
[a whole 3/4” wide circle of tape, was too thick to go back in the light]
wle
I actually wrapped the whole circumference of the signal tube front end with kapton tape. Just snug enough to still enter the chamber. The tail end of the tube doesn’t have a metal retainer, so there’s no issue there. But actually I’m thinking I should apply a few strips along the length of the tube to help a little more with centering.
Hi! I have a very strange issue. I guess I mess something up and now I have only 1 brightness level when locked (moon). 2h doesn’t work anymore (it’s also moon).
How is this even possible and how can I fix it?
OMG I found the answer FW3A Lockout question
So 2h gives you floor of stepped mode. That’s smart, too bad it’s not in the manual. :slight_smile:
sounds like you are in lockout mode
try 6 clicks
if that does not work, unscrew head and put back [reboot]
I wish they would have printed the full Anduril manual
who is ‘they’?
the whole thing is online
ANDURIL USER MANUAL & LIST OF LIGHTS
https://bazaar.launchpad.net/~toykeeper/flashlight-firmware/fsm/view/head:/ToyKeeper/spaghetti-monster/anduril/anduril-manual.txt
lumintop
