Sofirn SP10 Pro (AA/14500/Andúril 2) - now available!
Forgot to post back about the H10 cells. Not getting much more from them but the one of the four gives a little more oomph. With the clamp I got a max of 2.5A and that one cell gave 2.6A, if the meter can be trusted there.
Also received the green magnetic tailcap. Nicely done, magnet feels on the weaker side, probably just N35. It has a larger/wider spring in there compared to the stock eared tail cap. I tried to remove the magnet with a long acetone soak and couldn’t get it to budge so I’ll likely break it out…have some N52 1/2”x3/32” coming in the mail which should add a couple pounds of pull or more.
Well, this is the best picture I can get with my old busted not so tough camera, but I still can’t really see these as trapezoidal threads……
The threads are called “Acme” the design is stronger than std v-cut threads. Kudos to Sofirn for using an upgraded thread. Now, hopefully they’ll correct that dam blink at the top!
I feel the same way.
Blinking during Ramping is an Anduril “feature”, not specific to the SP10 Pro.
My FWAA has the same feature, and it really Bugs Me. I prefer my TS10 and SC21 Pro, because they do NOT blink during ramping.
imo ALL blinkies should be Optional.
Right now there is No Option for a user to Select to turn off Blinking during Ramping.
Hmm. Shirnask’s pic on the red light has threads that look slightly different from my green SP10 Pro…closer to Acme (which is not a true square cut…better in some ways, at least from a machining standpoint) but they do not look quite the same as the US made Acme threads I have on hand to compare with, for whatever that’s worth. Very similar to what’s on the Convoy M1, WildTrail WT3M, Wurkkos FC11, Sofirn IF22/22A, and most Rofis lights. Wonder if they changed things up, perhaps different machines or locations. At any rate…well done threads, one of the few that are a pleasure to use with good feel and fit and not too much spring pressure to overcome when you start it on.
I have finally succeeded in learning how to reflash my SP10 Pro
thank you for all your help
I flashed that file, and like the 04-14 version from Sofirn, it has a Blink at top of ramp
is there a Hex file with NO Blink at top of ramp?
Great! No, but I’ll cook one up for you here shortly and will post it up.
EDIT: here ya go, try this one
thank you very much for the Hex file, it works! no more Ramping Blink! :person_with_crown:
These look good. I’m still interested whenever you have time to complete the batch. Thanks
Picked up a Red SP10 Pro now that they are on Amazon (US). I think this is the most threadlocker i’ve seen on a single light ever. Probably 90% coverage of every thread all the way around. I thought I was going to change the anodizing color with the amount of hot air I was applying.
congrats on getting it open… what LED are you going with?
This SP10 Pro was super easy, no threadlocker at all:
Worst I’ve seen was on a Fenix light.
They used so much threadlocker that it filled 100% of the threads with excess squeezing out on both sides. It was red threadlocker too. Almost broke my pliers unscrewing the pill and this on a one AAA sized light.
I was going to defer to you on this one. You are like the beam connoisseur after all. DUV/output changes aside what do you think has the cleanest beam? I suspect it will be a short range light so whatever has the least rings/artifacts I suppose.
I find the SP10 Pro reflector has a pretty fuzzy overall profile, and is very forgiving of LED size… it works both domed and dedomed w 519a… both have pros and cons, larger round hotspot, or tighter throwyer hotspot…
but dedoming creates not only warmth, it pushes the Tint DUV down to about –0.0040, whereas the Domed 519a is much closer to the BBL…
the two photos above show the domed and dedomed beam profiles, as seen by my iPhone, which makes them look worse than in real life
here is the stock LH351d beam, for reference, it is no better, on camera
they all have sort of a secondary brighter transition, between hotspot and spill, and a shadow ring before an outer boundary ring…
but in real life, I think if you look at your stock beam, any LED you choose will be as good or better… our eyes are much more forgiving than the camera, in actual use, the SP10 Beam is not as varied across the spill as it looks in photos.
the SP10 Pro reflector is sort of short and wide… not particularly effective at focusing a hotspot… which makes it versatile, and compatible with both large domes or small…
The SC21 Pro has a Much better beam focus… recommended… for beam quality
I suggest you install a domed 519a, see for yourself, and then dedome it… to know first hand… bear in mind they drop about 20% in Kelvin Color when dedoming…
of the 517a Ive tried, the two standouts are the domed 5700K (super clean, not green daylight white), and the dedomed 4500K (makes a nice 3500K), but I recall you like neutral tint duv, so domed 519a may suit you best… it is similar to E21a…
here are my domed and dedomed 519a pairs:
I get my 519a from azhu btw… or there is a telegram based group buy from Clemence…
Since it’s fairly good with either I will start with 519A 3500K dome on. In my test this was already below the BBL by a decent amount using a TIR.
Having followed in the footsteps of moderator007 and gchart by modding my old UTorch UT01 I feel like this light is the “Production light”/next generation of that. Truly a light that was ahead of its time. Very fine OP reflector, deep carry clip, super compact, fine knurling.
However, gchart’s brilliant work with this driver makes this light and I gotta support that.
using a Tir in an SP10 sounds nice… hope you post a photo… and DUV…
gchart’s work on the SP10 Pro driver is amazing, not only does it have AA compatibility, it has the lowest low of any Anduril light I know…
plus he offers a flashing Kit, and updated Hex files… just amazing support :beer:
I sent PMs to the people who mentionned interest in the T1616 programmer.
If I forgot anybody please send me a PM.
Edit : for people in the US please ask Gchart first if he has programmers available.
Here’s my SP10 Pro with 519A 3500K (from Convoy site)
Beam
Beam
Left: SP01 Pro w/ 519A 3500K / Right: UT01 w/ LH351D 3500K
I really like the well defined hotspot of the UT01 reflector but the SP10 Pro is fine too.
Spectro (High with NiMH Eneloop)
nice strawberry color and -duv :+1:
glad the beam works for you too…
Previously my favorite color temp was 4000-4500K.
But now that I’ve tried dedomed 519a, I think my favorite color temp is around 3500K.
jon_slider has gotten me to like warmer tints!!! :laughing: :smiley:
Dangit… now I have to swap emitters in a ton of lights! :money_mouth_face:
