Usually pogo pins are pointy enough to not slip away. You can hold it in place with one hand and use the other one to start flashing. Using a clamp makes it slower, but helps positioning if it is difficult for you to see the tiny pads or if you can’t hold still enough.
I want to thank all the people, named and unnamed, that have helped me learn how to reflash Anduril 2 onto my TS10, SP10 Pro, and SC21 pro, including but not limited to: gchart, SammysHP, Adair21, zumlin, and BruisedMonkey.
I applaud you for bringing Lower Lows to my Anduril lights
my SC21 Pro, and TS10 now have lows of 0.02 lumens, 10x lower than before.
That change has Transformed my nightstand light options. Now I can use lights that were too bright, thanks to the Lower Lows you have created for us, and that gchart has incorporated into these Hex files that I used to reflash my SC21 Pro, SP10 Pro, and TS10.
I’m quite late to the TS10 party as Wurkkos doesn’t sell it in China yet. I had to get it through some back channels
I will test the TS10 Aux lights but the drain claimed in this thread seems too high.
I’ve tested my D4v2 with cyan Aux on high for 2 months and it drained my Samsung 30Q from 4.18V down to 3.81V so it would take 7 months to fully drain the battery. The drain actually tends to slow over time because the Aux lights lose some brightness as voltage drops.
You don’t need to solder wires or use pogo pins. You can just electrical tape the end together to the right configuration and then put enough pressure to make contact with the electrical pads.
Has anyone tested the max current the light can put out, especially with high drain 14500s? Testing current draw for tail E-switch lights is always tricky and I’ve given up on it.
I suspect the light can get up to 2000 lumens at turn on with high drain 14500s.
Hi Wurkkos fans and friends,
The third batch of TS10 are being emergency producing now( shipping within month end).
In order to fulfill the previous commitment and support the sales on other platforms.
Wurkkos office website will only retain 100 pieces in this batch, all of others will be sent to Amazon and Walmart.
According to the current shipping situation, these goods can reach the local warehouse about 7-14 days.
————————-The assignment result——————
Amazon US,
TS10-Black body-4000k-Red Aux 50 pieces
TS10-Black body-4000k-Ice blue Aux 100 pieces
TS10-Black body-6000k-Ice blue Aux 80 pieces
Amazon EU,
Walmart US,
Aliexpress, Lazada&Shopee
TS10-Black body-4000k-Red Aux 43 pieces
TS10-Black body-4000k-Ice blue Aux 109 pieces
TS10-Black body-6000k-Ice blue Aux 56 pieces
