The W35L and W65L are long-range LEP weapon lights with spill beams, the W35L is the compact (18350 battery) and the W65L is the full size (18650 battery). Shared LH18 head, light intensity of 175,000 candela, throwing distance of 836 meters, 630 lumens. The light head adopts a customized LEP light source and an optical lens innovatively designed by weltool, which optimizes the beam of the traditional LEP weapon light to have a spill beam, which has a larger visible range and will not interfere or expose the position of teammates due to the spill. The rear of the W35L and W65L is a forward switch, with a shock-resistant, fatigue-resistant, low-resistance spring structure, and comes with a high-drain 18650 or 18350 battery. This is a groundbreaking weapon light that optimizes the LEP traditional beam to a spill beam pioneered by Weltool.
Weltool T2 - very good looking light with absolutely no information about the UI, not to mention lack of simple battery level indication. Sorry if I’m picky but it’s 2022.
Looking at 21700 to replace my 18650’s now. Brightness is at the point of diminishing returns, I’m more interested in being able to maintain power for longer.
Battery level indicator is a complex function? OK…
I have many lights with battery level indicators and they have been pretty stable and reliable, maybe look at your products before taking hits at the competition that is already in the 21st century, thanks.
It doesn't have to be a complex one. It could be an indirect battery indicator like the tail switch of the Lumintop Tool AA. It is lit when the voltage is still high. When voltage is low, the light in the tail switch turns off.
I really like the design, well done! I would like to know more about the Through Hole Cooling design. Perhaps there is like a cross section illustration?
