Thanks for the recommendation mate, anyone here use that charger?
Can the color of the button light on a SC31 Pro be changed….? OR is this feature not available in the SC31 Pro (red and green for charging only)?
Nope. Switch LED’s are red/green only on this model.
Zephon:Can the color of the button light on a SC31 Pro be changed….? OR is this feature not available in the SC31 Pro (red and green for charging only)?
Thank you! Was afraid I wasn’t doing it right. Thanks for confirming the hardware limitation!
Just curious if anyone has any recent feedback on a Sofirn IF25A? Most of the feedback out there are a year old already and I’m wondering how it holding out…against say a TS21 or such? Is it worth USD30 and Anduril 2.0?
Seems like the IF22A has been more popular, compared to the IF25A. It has been out for a while… and I’m wondering if they’re nearing a point for an updated release.
Why does this say “New” instead of “Updated”?
Why does this say "New" instead of "Updated"?
Glitch in The Matrix?
What have they changed?
Use it as you would. I’d say if you think the brightness steps down too fast from a specific level then increase your temperature ceiling. Might as well check what room temperature the flashlight is reading while at it. Then there’s the aux light which you can set.
I’m still waiting on my TS10 but I’m going to probably be like you where I’ll keep settings in default at first, to see what works for me or not.
Thank you. I get around 3 seconds in turbo so I was wondering if I should adjust something. Also top ramp gives few seconds max, but that is identical power level as turbo?
I believe top of ramp is by default 150/150 in simple UI, so yes.
And no I don’t expect light this small to hold turbo for a long time, but that flicking step down just irritates me. What I would want to adjust after temperature settings is that top ramp so it would end in that stepped down level and turbo would be just highest high. That is also possible, yes?
Yes, again. I set my TOR in both simple and advanced UI’s at around 90/150. You’ll have to experiment to determine what works best for you.
I have Convoy L2 with sliced SST40 (when I was doing this there wasn’t SFT yet) and fet+1 driver.
Should I upgrade to SFT40?
I don’t use this flashlight anyway, like most of my collection.
I was in this thread and wondered what happens if you try to charge a CR123 battery in a light that has USB-C charging capability meant for LI 16340?
LB: I was afraid of that.
OK. Another “not stupid question”, how can one lubricate the magnetic ring on the WK40?
….I feel like this thread just allows me to ask stupid Q’s…
Didn’t try getting to the ring yet, so dunno.
How do you get the rainbow coloring on Stainless Steel like S41S?
Heat treatment
When swapping a SST40 light with a 3535 led footprint and pcb. Are amps the only need to look out for if the driver will kill the led?
Why no 26800 headlamp/right angle !!!
1 x 26800 won't have enough runtime.
We need a 4 x 26800 headlamp!
