Red and Green are often used for hunting animals that can see white but not red/green so much, so you can sneak up on them better and kill them. Not very sporting, but it works.
Blue is often used for “blood tracking”, too.
I think it was Brynite that made a zoomie that would have R/G/W chips on a slider, that would slide under the lens when selected. No blue. That was marketed as a hunting light.
But “light-painters”, or people who just like playing with different colors, can use, say, red (or green) on its dimmest setting to not ruin night vision. And blue can be used as a cheap way to check (some) fluorescence.
I thought the original WK30 would be just a “gimmick” light, but it became (and still is) one of my favorites.
I use my WK30’s red light on the dimmest setting for putzing around at night without ruining my night vision. Nice and floody, not a bright concentrated hotspot.
Me, I like floody lights for the wider angle, except for when I want/need dedicated throwers. So floody is definitely good.
In the ANSI/NEMA FL1 chart, just to clarify:
The mode Runtime(police flash) refers to just red and blue flashing right?
While (color flash) is for red, blue and green flashing?
Thanks
Operation Instructions of WK40
WK40 with dual switches, tail switch for modes changing and ring magnet switch for brightness.
3 Groups:
Group 1: white lighting mode (default)
Full click to turn ON/OFF, Rotate the magnetic control switch for brightness adjustment: low-medium-high-turbo.
Double half press to strobe mode, the other half press to return.
When ON, triple half press taggle to Group 2.
Group 2: Color mode
When ON, half press to cycle different colors: green-white-blue-red, rotate the magnetic control switch for brightness adjustment: low-medium-high-turbo.
Double half press to strobe mode on each color, the other half click to return.
When ON, triple half press taggle to Group 3.
Group 3: Flash mode
When in Colorful gradient mode, half press to lock the color when gradient, another half press to return.
Colorful infinite gradient:The gradation cycle is about 15 seconds, and the three leds of red, green and blue are dimming and cyclic light distribution, and the magnetic control ring is rotated to adjust the brightness.
Police flash: red-red→blue-blue→red-red→green-green→cycle, each color flashes at 4HZ.
Color changing flash: red→green→blue→white→cycle, each color performs 6HZ flashing with a cycle of 1S.
Color changing slow flashing: use red→green→blue→→cycle, each color flashes at 2HZ with a cycle of 1S.
When ON, quickly half press the tail switch twice to change flash modes: Colorful infinite gradient→ police flash → color changing burst flash → color changing slow flash → cycle.
When ON, triple quickly half press the tail switch enter the white lighting mode.
The Wurkkos TS22 looks like a very interesting light, I would like the manufacturer to also release a technically identical headlamp with a boost driver, 21700 cell and LED xhp70.2 or xhp70.3 hi
Would love to try the WK40 for light painting photography! Excellent choice on the RGB Luminus emitters Wurkkos, in combination with rotary switch I’m sure I could pull off some unbelievable pics!
