Why Batteries Function Better with Their Dedicated Chargers?
47 posts / 0 new
killswitch
killswitch's picture
Last seen: 1 month 6 days ago
Hello. Have been hearing that for better charge and battery longevity batteries should be charged with their respective chargers i.e. eneloops with eneloop charger, Powerex with MAHA charger etc.
What about those complex chargers that allow for selective charging, draining, monitoring, cycling and refreshing? I have see those from MAHA, BT, LaCrosse. Can these chargers be optimal for popular brands rechargeable NiMH batteries sold today?
I have Amazon Basics, white eneloops, older black Sanyos, Duracells. I have been using Camelion cheap 4-channel charger to charge them. Can I just buy one of aforementioned chargers to have “best of both worlds” and not buy charger for every brand of batteries?
fogofwar
fogofwar's picture
Last seen: 2 days 12 hours ago
They don’t.
gravelmonkey
Last seen: 49 min 13 sec ago
Can you buy a decent charger for all brands of regular NiMh cells? Yes.
HKJ has reviewed many chargers, hopefully the table will help you decide which to buy.
zoulas
zoulas's picture
Last seen: 2 hours 41 min ago
Forget about the chargers that come with the batteries you buy. Get a good charger and that will charge all your batteries very well.
Couchmaster
Last seen: 1 week 4 days ago
..Although you may have a good charger that came with your batteries that will work with them all. The advice to peruse the HJK site is excellent. Panasonic, for instance, who sells chargers with their eneloops, has both excellent and not so excellent chargers tested on his site. You can sort by feature simply by clicking the heading you want to sort by.
zoulas
zoulas's picture
Yes the charger that comes with the batteries is for beginners that don’t have any charger and need to charge the batteries they are purchasing. If you buy Eneloop’s for example, get the ones w/o the charger and then get a good charger. I have found the Miboxer to be excellent but there are many to choose from.
flydiver
Last seen: 20 hours 45 min ago
Old men’s tale. Mostly BS, like a lot of them.
Research the advice you’ve been given. Check out the link to battery charger reviews.
To Air is Human, to Respire….Divine.
raccoon city
raccoon city's picture
Last seen: 2 min 3 sec ago
Location: Palm Desert CA ~ West Coast is the best coast
flydiver wrote:
Old men's tale. Mostly BS, like a lot of them.
Yup!  :THUMBS-UP:
Lightbringer
Lightbringer's picture
Last seen: 5 hours 45 min ago
I’d say just the opposite. Get a good quality charger and it’ll treat a cell better than an afterthought of a come-with charger that’s “free” with the cells.
Lotta cheep-cheep-cheep leetle cheeken chargers are just trickle-chargers that can slowly fry a cell’s innards.
JenkinsMatti
Last seen: 5 hours 18 min ago
fogofwar wrote:
They don’t.
^^^^ This
Johnny_Bravo
Last seen: 3 hours 59 min ago
A good charger and good cells should work, it´s the combination. And I´m not sure whether most of these manufacturers really manufacture chargers and cells or just buy from another and lable it
I have chargers which have problems with a lot of cells and (cheap) cells which cause problems in every charger.
killswitch
Thanks. Looks like years of work went into making that list.
There was a theory someone told me decade ago that manufacturers of chargers use default algorithm that is not optimal causing batteries to wear out sooner. Don’t know if it is a part of collusion for planned obsolescence.
fogofwar
fogofwar's picture
The “algorithm” is typically some fixed current like 1A and then trickle charge to full. More advanced chargers can track the battery temperature to make sure it doesn’t go above some value (like 40C). You don’t need anything more fancy than that.
If you want to just minimize the wear of your battery, then charge at something like 0.1A but it will take forever. Most people will never get close to the cycle life of their battery for usage in flashlights so I wouldn’t worry about it.
flydiver
There was a theory someone told me decade ago…
Sounds kinda like one of those ‘old men’s tales’, eh? Facepalm
How the hell did they know? What was their information source? Did they do ANYTHING to check it out?
Maybe women gossip, but men just bullshit themselves a lot. I think it’s the sapiens equivalent of chest thumping.
wle
wle's picture
Last seen: 12 hours 28 min ago
one thing about li ion cells is, they should only be charged up to about C/3 or so, in the initial constant current phase
any more and you may overvoltage the cell before it quits charging
any less and the charge takes a long time
using the charger that came with the battery or the light, may be already set to that charge rate
(he says optimistically – at least it is possible)
if you get to pick charge rates, you might pick the wrong one
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Ricflair
Ricflair's picture
I charge just about everything (You name the cell & chemistry) with Nitecore chargers. Been doing it for about a decade and never had an issue. I don’t buy cells that come with a charger or cells with built-in charging capabilities. Hopefully that gives you some insight to others experiences.
If you have a Saltytri you want to unload, hit me up. If you don’t know what that is, google it.
killswitch
any more and you may overvoltage the cell before it quits charging any less and the charge takes a long time
What is C/3 and does this extend to other lithium cells like those in laptops and phones?
Lithium ions you refer to? I never heard of these kind of batteries. Only know that 18650 have built-in overcharging protection.
gravelmonkey
They’re saying Capacity divided by three = charge rate. So a hypothetical 3000mAh li-ion cell should have an initial charge rate (the setting you put the charger on) of 1000ma.
Second point is one I also agree with, often the clamshell packages of cells and charger you buy in stores includes a cheap charger which isn’t very good.
killswitch
I thought you meant charging battery to 1000mAh capacity out of its 3000mAh capacity initially. So it’s charge rate 1000mAh and not maximum charged capacity? I know in cellphones its the opposite. They are charged at normal rate but slow down after around 90%.
Can even be charged using quick charge technology that is so much marketed these days but in itself introduces heat that affects battery longevity.
Do Nitecore, LaCrosse and BT chargers detect lithium battery automatically and set C/3 preset or I set it manually?
flydiver
18650 don’t ‘automatically’ have built-in overcharging protection. It has to be added after the raw cell or pack is made.
Some chargers automatically set the charge rate, but not by capacity. Its usually by testing the internal resistance. There is no way it can figure out capacity in a short electronic ‘probe’.
Some people like that feature-put it in and let it go. You usually CAN over ride it if you want.
I dislike it. I want control.
Pete7874
Pete7874's picture
Last seen: 1 hour 38 min ago
C/3 or 0.33C is certainly safe, but seems to be rather conservative. Most sources I’ve seen recommend 0.5C as a safe charging rate.
Pete7874
Pete7874's picture
All properly designed Li-Ion chargers will automatically and gradually reduce charging rate toward the end of the charge cycle when they switch from Constant Current (CC) phase to Constant Voltage (CV) phase. This is to prevent over-voltage situations.
All EVs, like Tesla, also do this. Charging up to about 80% is fairly quick. The last 20% takes a long time. Plus, it’s actually bad to charge li-ion cells all the way to 100% – high voltage puts extra stress on the cell. I typically charge my cells to about 70-80%, including my phone, unless I just really have to have 100% capacity available to me.
jon_slider
jon_slider's picture
Last seen: 6 min 46 sec ago
killswitch wrote:
Can I just buy one … charger…
Yes
here is a charger that can do both LiIon and Eneloop
https://www.illumn.com/vapcell-s4-plus-3a-battery-analyzer-li-ion-nimh-n...
you do not have to tell it what charge rate to use (but you can), it is smart enough to charge safely, automatically.
here is a review:
https://lygte-info.dk/review/Review%20Charger%20Vapcell%20S4%2B%20fast%2...
suggest just scroll past all the test pictures, to the conclusion at the very end..
wle
wle's picture
usually the ‘automatic’ ones are just slow
like 100ma default for a 2200 mah battery, would take all day
-Greg Lemond.
wle
wle's picture
they do have to reduce current at the end but bigger capacity cells can have more current before that phase
smaller ones may end up over-voltage if the charge is too fast
i have one tiny worn out 16340 that ends up at 4.7V on the lowest current i have, 300 ma
wle
-Greg Lemond.
wle
wle's picture
charging to 80% is still slow if you are way under the max current the cell COULD take
or if you do not monitor temperature
wle
-Greg Lemond.
Pete7874
Pete7874's picture
wle
Sounds like its internal resistance is extremely high now and should be headed for a recycle bin. Smile
wle
wle's picture
Pete7874 wrote:
wle
yeah probably
it;s old and cheap
-Greg Lemond.
Bart1080
Last seen: 3 days 5 hours ago
….didnt know about th HJK site. https://lygte-info.dk/info/roundCellChargerIndex%20UK.html
Wished I’d known before I bought my charger a month ago Smile
….just noticed the “sticky” in the charger category.
killswitch
This one I bought for several euros almost a decade ago but it was a standalone charger. Is it similar to chargers that come in clamshell packages with included batteries?
It takes almost half of a day to charge batteries. It acts strange sometimes because some channels have indicator that either does not turn on. Or turns on but emits a dim light. When I rotate the battery the light turns on fully. You can see it in this video: https://streamable.com/zhj7nv
killswitch
Are you referring to chargers that plug into wall’s receptacle directly? Those branded chargers for their respective batteries like Panasonic, Duracell and my Camelion? With 100mAh it would take 22 hours to charge 2200mAh battery?
