I think it looks kind of cool. You lucked out that it happened to be the LED on the “bottom end” of the switch as the light tailstands. If it was on the sides… much more “askew” looking.
You got lucky that it's bottom one.
I got one on the side, that is dimmer. I Asked hank about it, and received this answer
"It's normal for this small LEDs to have different brightness, since they have different VF value."
from my understanding Its peculiar bad with the warm white.
That's why for next purchases I chosed cold white.
Testing them is probably to much labor intensive
And yes, it's worst in reality, then in the pictures...
Hi Hank. Random question. How do you prevent particles from getting on the reflectors/lens when you assemble? Is your lab pressurized? Any recommendations to help prevent contamination? Thanks.
I think this is the common issue for the B35AM LED itself, the MCPCB is the best that we can produce, and there is no soldering issue whatever.
The LED will not die at high current (3.6A), but the smoke will come out on turbo mode.
We plan to reduce the current of the B35AM LED, this is the only way to prevent the smoke, only that the output will be reduced as well unfortunately.
Well just received My D1 mini B35AM 4000K (cold white aux), and I can confirm that it's smoking on turbo. But to be honest it doesn't bothering me at all. It even look nice, as the smoke swirls inside the reflector.
There's a visible tint shift, from low to high mode. opple measured around 250K shift, from around 3800K on low to around 4050K on high. opple isn't very accurate, so I average it measurements (take it with a grain of salt).
Turbo - 5.6A
Moon - 7030µA
Aux off - 67µA
Aux on Low - 76µA
Aux on High - 260µA
it jumps +200µA every 8 seconds or so for brif moment, from my understanding, that's just the driver waking up to check the voltage.
And well, to be honest, it's not so smaller than my 21700 flashlights...
the beam is quite nice, but the spill diameter is rather tight compared to my other flashlights.
