【TS10V2 Al available】Wurkkos "slender waist" TS10v2 aluminum version available with black,green,orange
Has anybody managed to unscrew the tailcap ? I didn’t have much trouble with the front but the tailcap doesn’t bulge.
yes,
it helps to warm up the host, to soften the blue loctite
(there was a lot, not shown in photo after cleaning)…
there is no retaining ring, the switch parts just fall out, so it is a good idea to keep the tailcap glued on.
there is an additional O ring to support the signal tube, in a groove inside the body tube. This is an upgrade over the FWAA, that lacks a second O ring for the inner tube.
TS10 has slightly less switch parts than the FWAA, I prefer the feel of the TS10 switch, and it has better resistance to false activation:
Switch pressures:
stock FWAA 10 ounces
stock TS10 24 ounces
FWAA w O ring mod 28 ounces
the other difference between FWAA and TS10, is no lens over the optic in the TS10, which contributes to making the TS10 shorter than the FWAA.
Thanks, I’ll try with some heat (actually for the front I simply turboed it beforehand).
I guess I’m a bit weird because I want to use a lower force switch, I find the FWAA switch to have a perfect feel (granted it can accidentally activate more easily).
For those that have flashing kits for this (or are interested), I noticed this morning that AVRDUDE recently added support. So you can bypass all the Python/pymcuprog rigmarole if you want and just use our tried-and-true AVRDUDE: Adventures in TinyAVR 1-Series - #294 by gchart
You could check the page 9 write.
Since this is a brand new LED, there are still many places that have been uploaded more than two months ago without update.
And I will upload a new document after the Lattice Power updated their manual.
I updated my TS10 to the latest firmware and what a difference! I’m measuring 0.01lm now.
The max regulated level appears to have changed from level 65 to something else. Does anyone know what the max regulated level is for this updated firmware?
SammysHP made this ramp and I copied it. Looks like 90 is the max regulated.
https://bazaar.launchpad.net/~gabe/flashlight-firmware/anduril2/view/head:/ToyKeeper/spaghetti-monster/anduril/cfg-wurkkos-ts10.h
Any chance Wurkkos update their firmware to this latest?
when is red back in stock on wurkkos website?
Still can’t wait for the copper and brass version!
PMC just reply my “The red body would be available in August, but the specific time cannot be determined.”
my understanding is wurkkos tried the new hex and found another bug, so they’re going to use the original settings on the third batch too. (i think the third batch is already gone too.)
and they plan to “mass produce” the flashing pad for us…(because we’re all advanced programmers :P)
What was the new bug?
i am not sure, i just took the information from public facebook posts from a week ago.
Wurkkos wrote there:
They simply don’t know how Anduril works. In the ceiling config 1 click means level 150, 2 means 149, 11 means 140 and so on. There is no range check and when you set ceiling below floor, strange things will happen. It’s not a bug (although a range check on the user input might be a good idea, although it will increase the code size significantly).
I think they misunderstand how to set the ceiling. He thinks you have to click 150 times to set a ceiling of 150. And when he does this there is “chaos”
@Wurkkos, please note that the ceiling becomes [151 - n] where n is the number of clicks.
1 click sets ceiling to level 150 (151-1 = 150)
21 clicks sets ceiling to level 130 (151-21 = 130)
55 clicks sets ceiling to level 96 (151-55 = 96)
Some of the Anduril diagrams which are circulating do not explain this clearly enough.
If you make 150 clicks you are telling it to set ceiling to level 1. I never tried this but I guess it could cause strange behaviour.
It turns out that there’s a big difference in wording between the 2021 version Wurkkos has versus the 2022 April version!
As a newbie to all this, the 2022 version makes a BIG difference in trying to make the UI do what you want it to do.
Question about battery type
is the Wurkkos 900mah 14500 Battery an ICR, IMR, or INR chemistry?
Difficult to know, but recent cells are usually INR/NMC or NCA. ICR is old stuff.
thanks for your guess
I ask because of the tendency to overdischarge when using High Bright Aux/button.
Although I have reflashed to add LVP… not everyone has
Im under the impression that recharging an unprotected IMR/INR that dropped below 2.4v is less risky than recharging an overdischarged unprotected ICR
