Emisar D4SV2 extra optic option?
11 posts / 0 new
Jerryo100
Last seen: 3 weeks 6 days ago
Hi, I'm ready to pull the trigger on the Emisar D4SV2 but not sure about the extra optic option. What is it? The option says more floody beam. I'm thinking orange peel reflector but it says EXTRA. Is it something you can swap out or add on to the light?
I also have a couple battery questions. Will it take flat top batteries? What is the minimum amps I should be looking for without sacrificing max brightness? The choices I'm seeing range from 7 to 40 amps.
Here are the available options:
      Picked Cyan
    Picked Cyan
    Picked W2 (Osram CSLPM1.TG), 6000K
raccoon city
raccoon city's picture
Last seen: 16 hours 8 min ago
Location: Palm Desert CA ~ West Coast is the best coast
I'm also thinking it's an orange peel reflector.
I don't know for sure, but I don't know what else it could be.
SammysHP
SammysHP's picture
Last seen: 10 min 13 sec ago
There is no reflector in that flashlight, it’s a TIR optics. And you can order one with a more floody beam shape and swap it yourself.
raccoon city
Oops...
I guess I don't know what I'm talking about!
:FACEPALM:
Oleg'destr
Oleg'destr's picture
Last seen: 1 hour 11 min ago
Stock optics have a narrower beam and more light throw. Additional optics have more flood light and less throw.
MtnDon
MtnDon's picture
Last seen: 8 hours 14 min ago
“Works with high drain unprotected 26650 cell under 69mm” ….from the noctigon webpage https://www.noctigon.com/Emisar-D4SV2-26650-LED-Flashlight
vyvyra
Last seen: 1 week 6 hours ago
somebody said it is like a frosted lense.
Jerryo100
SammysHP wrote:
There is no reflector in that flashlight, it's a TIR optics. And you can order one with a more floody beam shape and swap it yourself.
Thanks. Is it easily swappable on the fly? Or is it more involved than just unscrewing the bezel and swapping out the optics?
Scallywag
Scallywag's picture
Last seen: 10 hours 52 min ago
It is basically just a matter of unscrewing the bezel and swapping the optics, but it’s not something I’d advise doing “on the fly”
The optics are fragile, there’s a glass lens and o-ring, and you want to keep everything clean. While the optics are pretty easy to install at a bench, sometimes they don’t want to come out, and installing them wrong could damage something.
Jerryo100
Scallywag wrote:
It is basically just a matter of unscrewing the bezel and swapping the optics, but it's not something I'd advise doing "on the fly" The optics are fragile, there's a glass lens and o-ring, and you want to keep everything clean. While the optics are pretty easy to install at a bench, sometimes they don't want to come out, and installing them wrong could damage something.
Thanks. Very good to know. No extra optics for me then.
Jerryo100
MtnDon wrote:
"Works with high drain unprotected 26650 cell under 69mm" ....from the noctigon webpage https://www.noctigon.com/Emisar-D4SV2-26650-LED-Flashlight[/quote]
Thanks. I think I'll be getting these: https://www.orbtronic.com/26650-battery-5750mah-30a-high-drain-imr-li-ion-flat-top
I found some with a higher capacity but they were only 15 amp batteries.
