Wow, thanks again man - much appretiated sharing the smaller footprint data. I use spring-loaded pogo pins for programming my Atmel Tiny processors, and for testing some small boards, but these SMT test points will come super handy as they free your hands and allow for a good/solid connection while testing/trying things out
For sure, the solid connections and free hands are awesome. Once you start using these things, it gets addicting - I put them on every signal line I think I might ever need/want to probe. Theyâre small enough that it doesnât usually have any real effect on board size, and they are so nice to have when you need them.
The pogo pins are what I always use for programming headers
Unless Iâm really tight for board space, then I use a tag-connect layout
Very cool. My programming setup is not fancy, but works well for the relatively low volume of my projects. Here I am programming a Tiny85:
And here is the programmed board on its battery carrier (cover off in picture, but bolted in place for end customer use). On this photo you can see the 7 test/program test points (some with silkscreen labels):
Sorry I havenât quite been keeping up with this thread, but where are things at? Pilot, you have some already produced (fully assembled), are we just waiting to see what hosts will work well for it?
In terms of torches, yes - I still havenât found a great host for it yet. A lot of people are inquiring about using these for non-torch applications though (bike-lights, off-road lights, you name it lights). I have some modules available right now for anyone who wants one - I havenât announced major/general availability just yet because Iâm still waiting for my shipment of U2 LEDs, and I donât plan on running the big production run until I have everything (it costs big bucks to run on a U.S. production line for half a day).
Cool White T6 and Neutral T5 modules are available for purchase right now - I donât have a lot of them though.
There was discussion in this thread about using this module with a D Maglite. After seeing this thread (3D Magmule with triple Nichia 219s), I think itâs very feasible to fit this module and a heatsink into the top end of the Maglite with a bit of boring (just above the switch) The stock head could then be milled down, or a head like the one cut on the lathe in that thread could be used to hold the module and optics in place. If the momentary configuration is desired (I would want that), the module could be hard-wired and the stock switch could be converted to momentary action for mode changing (or the stock switch could just be replaced entirely). Along with cutting down the battery tube and either using 3 x 14500âs or have it bored for 3 x 18650âs, this could be a pretty compact powerhouse.
PPtk: Quick question - can the momentary switch be wired to pull up (to positive) instead of pull down (to negative)? That way the stock switch converted to momentary could work as-is.
Unfortunately, no. The switch must be wired between the Momentary Contact Input and Ground. It is pulled up on the circuit board, and the switch pulls it low to toggle an input. Pulling the Momentary Contact Input to Battery+ would be very bad, in fact.
How much time is consumed in completing this extraordinary project?..I would be definitely learning something from you for sure !!! What are the prices?
Sorry if this was discussed, but how hard or easy is this: âMax output: 3.2Amps (up to 5Amps with one resistor change)â? Would you change the resistor if we request?
I do have production versions ready, but I havenât done a âbigâ run of them (which is why I havenât really advertised them as available very heavily). The reason is that Iâm still waiting on the U2 Emitters that I ordered, and I want to run a big batch of Cool U2, Cool T6 and Neutral T5 all at once since more of the production cost is setup time than actual run time.
If youâre interested in a Neutral T5 or Cool T6, I have a few available.
Yes, Iâll be happy to make the change - although I donât necessarily recommend it. 5 Amps * 3 Emitters gives about 52.5 Watts of heat. You had better be putting this module in an enclosure made of about 5 pounds of copper if you hope to control that kind of heat.
If youâre only going to use it for a short âTurbo Modeâ, it will be fine. But, donât plan on long run times, unless, like I say, you have one heck of an enclosure/host.
Why do you want or need 5A? It will produce far too much heat, you will need forced cooling unless its mounted to a HUGE heat sink.
The hotter an LED gets, the less lumens they give out. So running hot at 5A may produce the same output as seen at 3A, with the bonus of a smaller housing. Also, look at www.budgetlightforum.com/node/2603 , a sticky in this section of the forum.
You can see the output tails off after 4.4A... Now look at the size of his heatsink, and he's only got one LED...
Your eyes won't even notice the extra 10% in output. Why not try 4 XMLs run at 3A? You'd get more light and they will be a whole lot more efficient.
Or two triple boards run at 2A. You'd get about 4100 lm at 36W. One triple run at 5A gives out about 2900 lm at 45W.
I don't know what your set up is and I'm definitely not trying to knock you down, just though I'd put some info down for ya. I've made some silly lights and run them at huge currents only to find more LEDs at a lower current is brighter and kinder on my batteries!
