What did you mod today?
I use 3M Safety walk tape. This is very stick grey rubber grip tape that removes cleanly and completely when done.
  • Tear off a couple pieces and wrap one around the bezel and other around the head. This allows for much better grip.
  • Still not enough? … apply plastic-jawed pliers on top of the grip tape.
  • Don’t have plastic jawed pliers? Cut a piece of 0.032” sheet aluminum and bend it into a U shape, then wrap it around your light above the grip tape. Apply regular pliers on top of the sheet aluminum.
  • Apply muscles to unscrew.
  • Once open use a metal pick to remove the threadlocker from the threads.
  • Do mod, reassemble, remove grip tape.
I’ve generally found that this technique is sufficient to break most threadlocker used in lights. The only brand I’ve tried this doesn’t work on is Fenix. They seem to squeeze a whole tube of red threadlocker into their threads.
For lights where mechanical pressure does’t work you may need a blowtorch or oven to loosen the threadlocker. Then I’m guessing silicone or leather gloves to insulate the hot metal as you unscrew. I’ve never tried this method so do not know the best technique when applying heat.
Heating helps even if it isn’t blazing hot when you unscrew. I think it breaks it down a little each time.
To heat the light, put it in the sun for an hour or two. or, dip flashlight bezel in hot boiled water for a minute…
then use leather wrap and vise grips
or use strap wrenches:
Also important to note to NOT use a plain vise or anything that would squish either head or body out-of-round, because then you’ll never get it off.
I would not advise to dip it into water! I’d say that it is more risky than heating it with sun heat or even a lighter.
If there is any leak into the driver, it may result in damage when turning the flashlight ON.
Heat and force (vise, leather wraps) = YES; Hot water = NOT so much.
Just my perspective of course :wink:
He only dips the bezel part. That’s my method also. First whole head of light to freezer to shrink. Then just quick dip of bezel to boiling water. Bezel expanses when rest of the head is still shrinken.
Ok, I was just being cautious with that, because for someone unexperienced, it may result in failure. :+1:
I also use the boiling water method but the parts are in a plastic bag when they are dipped in the water. I’m pretty sure jon_slider also uses this method.
I will try it today.But the usb port is there…Need to be carefull,…
Just Dip the Tip… or use protection :innocent:
:smiley: :smiling_imp:
Tried out a weird Osram emitter (S2WN) in my S2+
Swapped Convoy 519A 4500Ks into my Jaxman i2, YLP Unicorn, and Lumzoo GH10
So its done.Sofirn Sc32 reflowed with xhp50.2.Its a little pocket rocket.Interesting that the optic is fit with xhp as it was fit with the original sst40.And the size is pretty different.Shines brutally good.Hot on turbo after 15 seconds but its the smallest xhp50 torch i know about…Maybe any Eagletac model.But this is pretty small.10 cm…Nice model really small and bright.Now a hot rod.Sadly i dont know how to post pics here.Iam in the forest.And its briiight
I did my first spring bypass on a BLF Q8. The soldering isn’t the prettiest, but all of the joints are solid enough. I scraped some of the solder mask off the traces on the bottom board near the screw holes and soldered the bypass wires to those.
Looks great! I believe the next step is brass screws for the board, if you can find them.
Hey there Friends! I havent posted on the Mod page here in awhile, but this weekend I did a mod for a customer that i am quite proud of!
My first Novatac SPL !
I definitely didn't even want to attempt it out of fear of failure (and ruining the light), but it came out pretty good. I had hit some bumps along the way like needing to make my own 1.5mm wires to extend the leads from the driver bc they wouldn't reach my reground 16mm mcpcb pads. I also had to use a centering ring i had luckily left over form a GT Micro mod.
A huge thank you to JonSlider for showing me the way on how to even get this light apart, and for leading me to the Amazing CRX mods on what the MCPCB needed to look like! Thank you Jon, and CRX too! My mcpcb doesn't look anywhere near as clean as theirs do, but I tried my best! the light works and the tint... well, a dedomed sm405 Nichia 519a, it looks amazing of course!
Nice Artie. Great to see a “vintage” light up to date. This one is still on my modding bucket list also.
Thank you! I had not planned on being successful, so when I was I was quite happy lol. All in all I guess it wasn't a terrible mod, but since it wasn't my light and I have no idea how hard these are to replace it I broke it, the tension was high lol. I'm glad it worked out tho. It's acrually a really nice light I would've never given a second look unless I handled one. I think I may try to find one to mod for myself.
Nice. My “4500K” 519A (Convoy) that I swapped into mine read about 4200K on Opple, original TIR
