Big Ole batteries
24 posts / 0 new
MaintenanceMan2
Big Ole batteries
I have some large batteries. They weigh 350lbs a piece they are 2v calcium plate batteries. 2515amphr.
Any thoughts on a charger that would work with them?
raccoon city
raccoon city's picture
Last seen: 16 hours 37 min ago
Location: Palm Desert CA ~ West Coast is the best coast
You're going to love it here, MaintenanceMan2!
Holy cow, those are large batteries!
MaintenanceMan2
Yes they are. Lol
I’m just a consumer can you imagine me unloading 6 of these from the back of my truck with a tractor bucket and some ratchet straps? Lol
chops728
Last seen: 2 min 53 sec ago
I saw your Thread on DIY Solar
MaintenanceMan2
I figured. Lol
I used the same name just for that reason.
I can’t find an effective way to charge these batteries.
I am joining all the forums. Lol
kennybobby
kennybobby's picture
Last seen: 9 hours 25 min ago
Do they not take a charge when connected, e.g. connect all 6 in series then use a 12V charger such as car battery charger, the higher the amperage the quicker the charge. It may take a while unless you can find a high current charger, 75 – 100 Amp, even then long time.
What (flashlight?) are you gonna use them?
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
MaintenanceMan2
Lol. They won’t be used for a flash light that’s for sure!
In order to charge them properly I need 250amp hrs worth of charger.
That’s 10% of the capacity.
Or so I have been told.
chops728
Most of the time you Paralel charge batteries before connecting them in series
MaintenanceMan2
Once they are hooked up in series how do I keep them charged?
chops728
A Big A—-S charger or multiple chargers in parallel — the problem you are going to have is —- used batteries — no telling how much each one can actually hold — therefore when you series charge them — some might get overcharged
MaintenanceMan2
How can I overcome these issues.
I hate to just scrap them.
kennybobby
You would just have to add distilled water to any cells that reached the upper end, which isn’t likely to happen anytime soon. but a 12V charger is easier to come by than a bigassed 2V power supply for parallel charging. Ignore the 10% rule of thumb for now.
The 6 series 12V string would let you know whether it could accept charge and would be worth buying an expensive power supply or even pursuing. Charge it for 24 hours then check if the OCV has risen or not; if not then they are scrap for recycling. If they do come up then it might be worth investigation of higher current power supplies/chargers, make or buy, etc.
We had a bank of cells like that for our lab, the charger was the size of a phone booth or Tardis.
There may be some used 6v or 12v golf cart battery chargers out there for low cost, high current, etc.
If you can, label them all and measure/record the at-rest open circuit voltage first; then connect in series and charge with the biggest 12V car charger you got for 24 hours; then disconnect everything and remeasure/record to compare.
Scallywag
Scallywag's picture
Last seen: 11 hours 21 min ago
That capacity is surprising at that weight. Aren’t those essentially lead-acid deep cycle cells? When I was in that world 2 amp-hours per pound was doing pretty good.
Edit: silly me, forgot that’s for 6 cells. Sounds like a typical solar battery. If you can get a single-cell lead-acid charger you should be fine. I’d want to balance-charge them.
Also, note that the 20hr rate is likely 1700Ah capacity, and 2500 is probably the 100hr rate.
MaintenanceMan2
Well I didn’t test every one but the ones I did test were at 2.2 and 2.3 volts…I pretty sure they are charged already!
I tested them with a chep DMM.
I need to get a Fluke.
MaintenanceMan2
Are you talking about discharge capacity?
The tag on the battery says 2515 over 8 hrs
grin
Last seen: 2 days 4 hours ago
Welder
The charger was interesting 415v 3phase delta incoming a transformer with 120v star delta secondary into a 12 pulse bridge rectifier. The inductor was 300mm wide copper sheet and weighed 100kg
MaintenanceMan2
Best brain can come up with is a forklift charger. Lol
wle
wle's picture
Last seen: 1 day 17 hours ago
solar panels?
look up the chemistry
are they lead acid?
what does calcium plates mean?
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
MaintenanceMan2
Calcium is the additive used in the lead plates. Yes lead acid.
I don’t have any panels.
wle
wle's picture
a car battery charger would work – if there are 6 in series, and you have 200 hours
it doesn;t make sense to charge them unless you can use them though
if they have been discharged below 1v per cell for over a month, they may not be recoverable
also check electrolyte levels
you need a 250A charger, which would need 240VAC input, and would be $$$, to do it in 10 hours
wle
-Greg Lemond.
zoulas
zoulas's picture
Last seen: 2 hours 24 min ago
Let me understand this a bit better, you have some 350lb batteries, you know the chemistry, you know the amp/hour, and you come on a flashlight forum to ask what kind of charger you should use. Makes no sense man.
Can you tell us where you got them from, what you plan to do with them, what device they are from?
The more you tell us, the more we can help. So far you have not told us anything.
So far it’s just a story out of a bad novel.
chops728
+1
raccoon city
You gotta admit...
This thread about batteries and chargers is different;)
different
Variety is the spice of life, unless you're on Arrakis, in which case spice is the spice of life.  :BEER:
Photon Master
Last seen: 1 week 5 days ago
I’ve been wanting to get a whole house battery backup installed but the Tesla Powerwalls are back ordered. I bet you could build a system like that using a bunch of these puppies
