How refined are you taste buds? I've been freezing beans for years now in 5lb increments. Only issue is when I get certain beans, but most do fine in the freezer. Also, some beans require resting on arrival before freezing.
If you have the option not to freeze (buy/roast small batches), then an air-tight container works very well.
They say oxidation is the enemy of freshness. Chemical reactions slow down with lower temp. The reasons not to freeze never made sense to me. I’ve tried freezing, it works.
Totally agree. Freezing works. Fruits & vegetables, on the other hand, would be a no, unless they're going to be made into smoothies/soups. Freezing them changes the texture :-)
I don’t know the answer to freezing, but I do know that a lot of the negative mentions of it in articles don’t make clear that they are talking about putting it back and forth in the freezer as you use it.
I freeze it in the unopened original package plus a freezer bag to prevent punctures, until it is time to start using it, then I keep it in a tight jar, and I don’t know why that would be worse than leaving it on the shelf for many months or a year.
That article describes what I do, it starts with the advice against storing the coffee in the freezer between uses and then way down in the article it points out that freezing the unopened bulk purchase is fine in the freezer until use (time before use counts though).
regarding freezing intact
and not-ground BEANS…
this is what i have so far:
1. freezing is fine IF they are frozen ONCE and thawed ONCE.
2. freezing is fine IF the beans are protected in some way.
3. freezing is fine IF taste is not the overriding concern.
The bottom line is that lower temperatures do slow the staling process. Coffee also has incredible ability to absorb odors so I don’t mess around with any bag containers. I use only sealed mason jars for storage.
I generally roast every 7-10 days so I don’t worry about temperature and aging. But I do notice a difference between summer and winter during those 7-10 days! I have frozen beans (in sealed mason jars) if I will be out of town and need a stash to last a few days when I get home. It’s better than leaving for week(s) at room temperature.
IMO 18+ year green bean roasting experience, I’ve noticed that at about 14 months, in sealed poly bags, beans started to turn a ‘straw color.’ But who knows how long that they were sitting at the merchant?
They still roasted fine, but one has to do a lot of experimentation to truly determine any degradation and I’m not that hardcore.
The staling chemistry process for green vs roasted is entirely different. To be conservative I would say the green beans will last at least a year… but there are exceptions; mostly dry process beans can fade in their more subtle flavor character.
Roasted beans have expanded by 50-70% in volume, opening the cell structure to oxidizing and the oils are more exposed as well.
Roasting coffee is nothing less than a complete transformation of the bean. To demonstrate this, try grinding and brewing coffee with green beans!
1. green coffee beans which have been frozen for at least 6 months. then thawed. roasted. ground. brewed. what would you expect to be the outcome?
2. roasted beans frozen for 6 months. thawed. ground……etc.
3. ground beans……etc.
really, just curious.
although i do not drink coffee,
friends and relatives do and i would
like to have something they would like
to drink when they arrive unannounced.
easy as possible and flavorable as necessary.
We can talk about the voodoo behind home roasting, but if you do roast, do a batch, wait 24-36 hours in a sealed glass jar and then grind what you might prepare for over 1-2 days and just repeat the process until you’re out of roasted coffee, starting again.
COFFEE
Less a science than a religion for most.
But actually is is SCIENCE.
And the facts just say, the coffee you like is the good coffee.
I roast coffee beans now and then, when I’m in Laos. And definitely this is the best coffee in the world, for me, but that does not mean everybody else makes it wrong.
As said, the coffe you like is the good coffe.
No religion
No myth
No pricy shittery (cat shite coffee, forgot it’s name)
No pricy stuff sold by a hyperactive playing Jobs in a cringey manner
Has one of you tried the coffee cherries as they come from the bush?
The sweet juiciness?
The bean inside, that splits in two, an incredibly complex taste?
You can actually make a drink from this!
People use it’s effects for medicine since beginning of time.
If I read here
then I must think that there is something wrong with the green beans you can buy in those sealed plastic bags.
Well that’s true. This whole track wasn’t to delegitimize existing coffee as its presented, but merely to expand awareness. I am still enjoying my “dead coffee,” but yeah… just a tinge bit less knowing it could be much better than it is. And I am going to get into roasting my own coffee beans. Started reading reviews for green coffee beans on Amazon and it looks like there’s some good candidates. Now I just have to watch more videos on roasting with low cost methods that achieve the same as the pricer ones (but just less pizzaz and convenience).
I imagine it doesn’t taste much at all like coffee beans that have been roasted. But perhaps it’s still a good taste in its own right, or something you can acclimate to liking, like Kombucha.
