I got my silver 4000k with ice blue a few days ago and love this little guy!
Everything is great about this light. If it should hold for years, it will be my all time favorite EDC for sure.
Looking forward to buying Ti / Copper / Brass version of it.
Agreed. I’ve been EDC’ing my silver 4000K for the last week. I love it.
Only thing that needs improvement is the clip. The stock 2-way clip is awkward. The light would be much better if it shipped stock with a deep-carry clip.
There’s been a bit of general discussion about the included pocket clip having some issues. Wurkkos, here are some specific things you can do to make a better pocket clip, with a render to help illustrate. The clip shown below will function much better than the current pocket clip design. I hope you’ll produce an updated pocket clip similar to this one shown below and include it with TS10, SP10 Pro, and HS05 in the future. If so, I hope you’ll also make it available for purchase so people who have the old clip can buy the new clip easily.
I also carry my lights in my front pocket but I have never had this issue. Where in your front pocket do you keep the light? Do you keep it on the far edge of your pocket closest to your hip or do you keep it somewhere else?
In order to minimize the chance of snagging on a seatbelt, but also still being able to “snag” a pocket, how wide should the mouth of the clip be? I find 3mm between the body of the light and the end of the clip to be ideal for me.
Would you rather the clip sit flush with the side of the light to eliminate snagging? If so, how do you clip it to your pocket? Do you lift up on the clip when inserting the light into your pocket?
It’s funny to me how the clips on flashlights are so troublesome, I personally haven’t had any trouble.
If we’re just dreaming here I would like a few threaded holes and a flat spot on the side of the tail cap so I could install a clip from a Spyderco, Benchmade, or even a simple 2 hole clip like zero tolerance or dozens of other knife companies use.
But I’m sure I’m in the minority as my pocket knife is in my front right pocket and depending on the light or pants, my flashlight is next to my knife in pocket or clipped inside the 5th pocket. Where I probably differ is I also wear an insulin pump in a pocket clip holster. So my pockets are always loaded up
That clip design is perfect TG. I’ve got two TS10’s so far and would love to buy more. The current clip is the only part I dislike about the light.
I would be happy for this on future models and would purchase two more to replace my current ones.
I’ve tried the E05C clip. It’s ok, but the bend at the top of the clip is a bit tight and it often fails to go all the way in when clipped to sweat pants. And the lip at the bottom is a bit small making slipping it onto pants not as easy as I’d like.
for sweatpants you would probably like this Olight S Mini clip. The garment gap is 3.3mm
for my preferences the Olight clip sticks out too far, the Lumintop clip rides closer to the body of the light, and works well with lighter material I wear:
the downside is there is no hatclip option with these clips
some of the Olight clips with S bends might be appealing to some people: .
pic is a link
Thanks for all the aftermarket suggestions Jon_Slider! Those are excellent options for current TS10 owners. That S-Mini clip looks just about perfect! If you find them for sale anywhere, let me know.
Hopefully Wurkkos will see all this clip discussion and make a new, better clip to include with TS10 so we don’t need to spend extra on aftermarket options.
I think a two way clip would be an improvement on TG design. The TS10 is actually a very good headlamp when you clip it to a baseball cap. It’s so light that you barely feel it.
I very rarely need a headlamp so I don’t own one. The TS10 is now my go to and only headlamp.
So, I carry in my left front jeans pocket at what I would call the outside of the pocket, next to the side seam. The deep carry clip that I love and would go for on every light is the KR4 clip, the new style one. Lately, I have been carrying and FW1A with Neal’s deep clip and it has worked fairly well for me. To me, rather than a hook, placing the fold in the clip at the right part of the body and not placing tons of tension against the body seems to be a perfect fit. It usually takes me a few days to get accustomed to a new clip and most will work fine with one hand, I do not like having to pull the clip out to attach to jeans. The FW1A really does have the perfect angle and tiny bit of extension to make the slide into a pocket work.
2-way clips are IF you actually wear ball caps and clip your light to them.
If you’re like me and never use your light that way, then 2-way clips are always inferior to 1-way clips. For my use, the extra backbend is a complete waste. It usually sticks out too much, adds unnecessary weight and gets caught on things.
I spent some time this morning attempting to draw a new 3-way clip design that carries over all the important 1-way features but I belive that a 2-way clip designed to work well in both directions and to carry deep is too bulky for such a small light.
The existing 2-way clip does not work well primarily because it is too small. There’s not enough ramp/mouth at the front of the clip in either direction to slide it over clothing material or the brim of most baseball caps. There’s also not enough space inside the reverse loop to fit the brim of all the baseball caps I’ve tried. In the design below, I’ve had to make the ramps/mouths large enough to fit over clothing material or hat brims and I’ve made the space inside large enough for most baseball cap brims. The result is quite bulky and I do not recommend Wurkkos produce it.
The Olight clip that Jon_Slider has suggested does not carry as deep nor does it have any ramp at the frond end, but I think it’s the best option for the seemingly few users who find the 2-way clip function important. Wurkkos should focus on including a great 1-way clip with TS10.
Thank you sir for all your efforts here. I am one of the few who uses the two-way clip, carrying a small light on my hats daily. I have been rotating my two TS10’s since receiving. As you have stated, the stock clip is insufficient for any real use. I ordered a few of the Olight clips that work well enough.
