Just received mine yesterday and it’s nothing special as expected. Unfortunately I jumped early and paid the $6.99 price. I originally thought it might be a good light to toss in the car for general use and not be upset if it was lost or damaged, but I think the protruding strobe button might be too easy to unintentionally activate. It’ll probably just end up being a *fire battery holder in the garage instead.
Heads up on one of the older deals.
Grathia Rechargeable Camping Lantern Solar Lantern with 4 Lighting Modes IPX45 Waterproof Camping Lights Led Lantern Power Bank LED Flashlight Lanterns for Power Outages Hurricanes Emergency Amazon.com
Mine has an issue and it is a battery killer. The first cell I figured was due to it be a cheapo cell. After the second I decided not to use it any longer. I assume the circuit with the solar panel is missing a diode and when the panel isn’t charging its pulling off the cell… but I don’t know that for sure and I haven’t done any testing
Got mine today as well. Kind of big for a basic 18650 light. Beam pattern is on the throwy side. Not a whole lot of difference between hi and low mode. I was surprised to find a USB charging port on it - the description didn’t mention it. Alas, on mine it doesn’t work.
Finally, pictures on Amazon show magnetic tail - mine doesn’t have it. I’ll probably just send it back.
Damned… came in on this a couple days late. Coupon seems to no longer work, or you must be a PRIME member to enjoy the discount. :person_facepalming:
EDIT: I was selecting the black model, which is a few bucks cheaper. But it appears the discount coupon works only on the colored ones. Still, very good deal. Got a green one.
Geeez I thought you had ‘My’ keys for a second……… what’s that scary skull key to?
I havent had a problem with the usb cover however I bought mostly to use the clip on a pocket or backwards cap but the clip comes loose REAL easy and it would be REAL easy to lose the light if it was not being used. I will probably glue the clip……… :person_facepalming:
