So, I carry in my left front jeans pocket at what I would call the outside of the pocket, next to the side seam. The deep carry clip that I love and would go for on every light is the KR4 clip, the new style one. Lately, I have been carrying and FW1A with Neal’s deep clip and it has worked fairly well for me. To me, rather than a hook, placing the fold in the clip at the right part of the body and not placing tons of tension against the body seems to be a perfect fit. It usually takes me a few days to get accustomed to a new clip and most will work fine with one hand, I do not like having to pull the clip out to attach to jeans. The FW1A really does have the perfect angle and tiny bit of extension to make the slide into a pocket work.
2-way clips are IF you actually wear ball caps and clip your light to them.
If you’re like me and never use your light that way, then 2-way clips are always inferior to 1-way clips. For my use, the extra backbend is a complete waste. It usually sticks out too much, adds unnecessary weight and gets caught on things.
I spent some time this morning attempting to draw a new 3-way clip design that carries over all the important 1-way features but I belive that a 2-way clip designed to work well in both directions and to carry deep is too bulky for such a small light.
The existing 2-way clip does not work well primarily because it is too small. There’s not enough ramp/mouth at the front of the clip in either direction to slide it over clothing material or the brim of most baseball caps. There’s also not enough space inside the reverse loop to fit the brim of all the baseball caps I’ve tried. In the design below, I’ve had to make the ramps/mouths large enough to fit over clothing material or hat brims and I’ve made the space inside large enough for most baseball cap brims. The result is quite bulky and I do not recommend Wurkkos produce it.
The Olight clip that Jon_Slider has suggested does not carry as deep nor does it have any ramp at the frond end, but I think it’s the best option for the seemingly few users who find the 2-way clip function important. Wurkkos should focus on including a great 1-way clip with TS10.
Thank you sir for all your efforts here. I am one of the few who uses the two-way clip, carrying a small light on my hats daily. I have been rotating my two TS10’s since receiving. As you have stated, the stock clip is insufficient for any real use. I ordered a few of the Olight clips that work well enough.
I know many people use clips and that’s fine obviously, I never do. But I do WISH manufacturers wouldn’t ship them with the clip already on, as no matter how careful you are removing them nearly always ends up with a little damage to the coating or finish with removal. If they were shipped in the box rather than on the light those who want them on can put them on and not worry about damaging the finish because it’s under the clip, and those of us who hate clips would have a pristine light with no damage
FWIW, my red TS10 was shipped without the clip attached to the light (thank you Wurkkos). I’m with you on preserving the finish. I did attach the provided clip, because the light is too small and smooth to securely handle (for my clumsy mitts anyway). I used the plastic straw trick (over the ears) to install it without boogering up the finish…works spectacularly. Removing it? That might be a different story.
The Olight clip works great for me. I have had no problems either with clipping the light in my pocket nor with it falling out since I got them. I don’t find it to be too bulky for the light. Honestly, I could do without the second loop, though can see it coming in handy at certain times. There is something to be said for flexibility.
I also ordered some of the Lumintop E05C clips mentioned in several places. It should be a bit smaller, but I will have to see if ease of use and retention is adequate. Unfortunately the package has not moved in status of “parcel information received” for 8 days. Who knows when they might show up…if ever.
I think I will buy some more of the Olight clips. BTW those showed up in about 4 days from the US facility. They also work very well for the several SP10 lights that I have.
Can you be more specific? I don’t understand how you can have a pocket clip without a ramp. By ramp, I mean some kind of opening at the mouth of the clip to grab your pants material. Without a ramp it would just lay flat against the side of the light and you’d have to lift it up every time you want to pocket the light. Can you provide an example of a pocket clip that handles this ramp area better?
I guess I should elaborate. The ramp sticks out too much, the slope should be minimal. For examples, I had this Ausus Knife and it scratched up the shit out of everything because its clip sticks out.
But this knife that I use now doesn’t give me a problem:
The clip in your mockup sticks out too much consider squeezing between two tight cars in a parking lot with that shape sticking out of your pocket.
When I tried it, the light started flickering, the same way it does when pressing the button on a TS10 that has been physically locked out
I later realized my TS10 had been reset, all my floors and ceilings had gone back to default. I just spent some quality time multiclicking and checking outputs on my light meter… I really should make a backup of my custom TS10 Anduril settings…
I like
ceilings at 110/150
floors at 1/150
1H from off to give floor and NOT start ramping automatically
I disable 2C to Turbo, so 2C only gives ceiling
thermal limit set to 50C
ramping speed option 2 (slower)
manual memory set to 10 lumens, with 10 minute hybrid memory
moral of the story… its not nice to fool w TS10/FWAA headswaps
Thanks for your drawings and ideas.
I want to focus on your 3mm gap mentioned earlier. I think a measurement for the ramp of the clip tip, is also helpful to specify.
I do lift the blade of the E05C to help it over the edge of my pocket… the clip ramp is very short, just 2.0mm, and sudden, and is only 1.7mm above the body of the light. It is not ideal.
The tip of the clip on the TCR-1 on the right, sits 2mm above the body, plus the ramp is 7mm long. That is a very convenient gap, for my jeans (pocket seam material is 2.2mm thick) and light slacks I wear (pocket seam 1.5mm). That is my favorite pocket clip.
So I propose redrawing your pictured clip w 2mm ramp height off the body, with a 7mm long ramp, and 3mm gap at the top of the garment curve. See if that produces a more compact profile, more suitable for the size of the TS10.
I do wear baseball caps, and I do clip lights to my baseball cap, instead of wearing a dedicated headlamp. But I agree with others comments that the stock TS10/SC21 Pro/SP10 Pro clip is almost too small to be useable on a hat brim because the gap at the curve of the clip is so narrow, 2.7mm, it barely pushes onto a baseball cap brim, which is 4mm thick.
I don’t think you can measure it with a multimeter like with the low or high mode. When you measure it, the current changes with each blink, there would not be a stable current to read at all. I am not sure how we can measure it accurately.
It is not useful as an always-on aux for a flashlight on a shelf, no.
However it can be useful for reading a map while preserving night vision (in the case of the red aux). Or creating some ambiance in a dark room.
There will never be unanimous agreement about how bright an aux light should be, due to differing use cases. I think a low that is very low and a high that is quite high… this is a reasonable compromise.
If they made the High aux significantly less bright, so that it can last many months of battery… then essentially you would have two low modes, instead of high and low.
Extrapolating parasitic drain is often off by a lot. In my opinion, there is no substitution to measuring long-term drain since the drain level will typically be lower as the battery voltage drops.
For example, I did a long-term drain test for the TS10 and found the ice blue aux to reduce the standard Wurkkos battery from 4.18V to 2.90V in exactly 7 days. The drain is still too high to be practical but it’s a sizeable difference from 4.5 days.
I’m doing long-term drain tests on all my lights with electronic switches (1 month and 2 month tests).
I’m of the opinion that high aux should last at least 1 month. The TS10 drains from 4.2 down to 3.9 in just one day which is a crazy amount. The D4 levels are perfect for me.
