NEW high current 60V 24A 1440W power supply RD6024 is released now
RD6024 feedback
Thanks for the present.
https://aliexpress.com/item/1005003744641750.html
RD6024 feedback
I bought it for the second time, the packaging is very good, the quality of the power supply is very good, the adjustment is relatively simple, the screen display is clear, and it is exactly the same as the seller's description.
hello, if you have interest and spare time, you can have a look at our Alibaba live
https://www.alibaba.com/live/rd-tech-products-introduction_54005b91-e3e7-4b34-8fe0-ad246584acce.html?referrer=SellerCopy
RD6012 feedback
take 10 minutes to finish the assembly, it is good
https://www.aliexpress.com/item/2255800866885424.html
RD6006P feedback
Great converter, it’s a pity that I didn’t take the 6012p version
https://www.aliexpress.com/item/3256801999408137.html
RD6018W feedback
Power supply works well and fitted perfectly in the case. I'm very happy with it.
https://aliexpress.com/item/1005001488070904.html
RD6024 feedback
the device comes in 2 weeks, and everything works
RD6006 feedback
Great converter! Delivery 29 days in KZ. I recommend the seller:)!
RD6018 feedback
Everything is packed perfectly, in a foam box.Everything is made at the highest level, The power supply came at the same time in another package. Thanks to the seller for a high-tech and high-quality product at a low price!
https://aliexpress.com/item/3256801301756152.html
Monthly Remind
when choosing the input PSU for RD power supply, make sure that the output voltage of the PSU does not exceed 70V DC, otherwise the product will be damaged. it is ok to choose other brand good PSU even if you do not choose ours
RD6006 feedback
very glad to get this bargain
https://www.aliexpress.com/item/4000282551930.html
25A cable feedback
These are a pretty good lead. In my pictures you can see the watts lost. their performance is better than all of my other power supply leads. I highly recommend these.
https://www.aliexpress.com/item/1005003735954321.html
tear down video of the 1200W 68V PSU
www.youtube.com/embed/yd2K8OC3Yhg
Comparison between 800W65V and RD 1200W68V switching power supply
S-800-65 is NVVV 65V 800W power supply, and RD-1200-68 is RD 68V 1200W power supply. We will disassemble them and show you the difference.
Overall comparison: There are obvious jumper Wire on the 800W power supply, and it uses green single-sided circuit board, half bridge type topology, and the use of low-cost components make the PSU more affordable when the performance is ensured. The 1200W power supply uses a black double-sided circuit board, which has better soldering performance. It uses a 2-transistor forward topology structure, and the used components are more abundant and have a longer service life. This two power supplies are glued at the large capacitor and inductor positions to fix them, both can work at full load for a long time when testing performance, which is recommended.
Comparison between 800W65V and RD 1200W68V switching power supply(part 2)
For the case, the 800W PSU use tapping fixed screws, it is low-cost, the 1200W PSU use press riveting process, it will be stronger and more durable.
Rectifier bridge: 800W PSU uses single rectifier bridge with heat sink, the heat dissipation is better and the working temperature will be lower. 1200W PSU use 2 rectifier bridges in parallel without heat sink, the over current performance is better and better impact resistance. Because the PSU does not have PFC circuit, the peak current of the rectifier bridge is relatively higher, it needs higher impact resistance.
Input main filter capacitors:800W PSU uses 2 PCS 200V1000uF,1200W PSU uses 2 PCS 200V1500uF, the higher of the output power, the bigger input capacitors required.The peak voltage after rectification of 220V AC voltage is 311V,so 2 PCS 200V capacitors connected in series is enough
Transformer: 800W PSU uses PQ4040 magnetic core,1200W uses PQ5050 magnetic core, bigger magnetic core can withstand higher power.
https://www.aliexpress.com/item/4001068050317.html
RD6012 feedback
Everything is top as always
RD6006 feedback
The power supply is fully consistent with the description. Fast delivery. I recommend the product and the seller.
https://aliexpress.com/item/4000282551930.html
