Is it possible to backup my TS10, SP10 Pro, SC21 Pro custom Anduril 2 settings that I change manually?
Things like, the floor in simple mode, that I set to 1/150, and several other preferences I have regarding Turbo, 1H from off, ceilings, ramp speed, etc.
Right now I can backup my lights hex files, using the SP10 Pro programmer and hex files I got from gchart, and the Terminal scripts I got from Adair21.
But if I reflash to my backup hex, I Lose All my Settings!
is there a way to backup everything, including my floors, ceilings, and other user selected preferences?
My goal is to use my own hex files, to reflash other lights Im expecting in the mail.
I do Not have the ability to modify my own hex files. I can only load and backup hex files I got from gchart. I do Not have the ability to run avrdude, I use pymcuprog.
For example this is my present command code sequence for backing up:
pymcuprog read -m flash -f ~/Desktop/SP10backup.hex -t uart -u /dev/tty.wchusbserial1420 -d attiny1616
I tried adding -m eeprom, like this:
pymcuprog read -m eeprom -m flash -f ~/Desktop/SP10backup.hex -t uart -u /dev/tty.wchusbserial1420 -d attiny1616
that did not save my settings, after backing up, and reflashing with this command:
pymcuprog write -f ~/Desktop/SP10backup.hex -t uart -u /dev/tty.wchusbserial1420 -d attiny1616
and after a Factory Reset,
I lost all my custom preferences… again…
do I need to add -m eeprom to the reflash command also?,
something like this:?
pymcuprog write -m eeprom -f ~/Desktop/SP10backup.hex -t uart -u /dev/tty.wchusbserial1420 -d attiny1616
It was a long day… I do not love fiddling with pogo pins, and doing a jillion clicks to get my lights back to the settings I cannot save… This is a BFWP! (Big First World Problem!), for me… lol
