I’ve received the new AceBeam X75, and I find it a phenomenal light. I have previously owned the X50 (in both 70.2 and FC40) as well as the Manker MK38 Satellite. This light, for similar price, destroyed those other lights.
Full review here:
My zombie apocalypse trio: BOSS 70, Acebeam L19 green and X75.
My current edc: LAN-Apple ZircuTi
Cool!
The Eneloop 2005-2022 info thread
No, it’s actually quite HOT! Lol, just kidding ChibiM!
Ah, so it was not 80 000 lumens OTF ? you mentioned it isn’t in the review. Indeed there isn’t any FL1 mention or chart in the product pages but a ”Max Output” mention, which could mean anything from marketers… no FL1 rating on the box either ?
As mentionned in the announcement thread, it’s not surprising it doesn’t reach them, it would require too much current for the cells.
Also, take my lumen tube numbers with a grain of salt. I mean, it’s a texas_Ace tube, and I’ve found it matches within 95% of lumens found on COAs from companies like Prometheus, but it’s definitely not authoritative enough to battle Acebeam’s numbers.
Also, I have the 5000K version.
Yeah there’s that, as for the CCT, it seems that both can be found with the same highest flux, though there is still probably a difference. Looking g at other acebeam products, they usually provides FL1 ratings, yet not with this one.
I see there is an XHP70.3 Hi version. Very cool! I just wish it didn’t have an integrated battery pack.
My Collection
I hear you. But I gotta say that battery reset button I pointed out in the video solves the one major gripe I had. I’m not too worried about the actual life of the cells, because at least in my case I go through lights so fast. There is just no way I won’t have a replacement for this light within 2-3 years.
I can see the cool factor of 80k lumens. Is there any practical use case for a light like this? I mean, it’s about the same price as the MK38, so it seems like a no-brainer between the 2, but is there a real-life use case where 40k lumens won’t do, but 80k will?
There have been lots of times where I looked at my flashlight collection, and purposely grabbed a D18 or my MK38 because I knew that’s what the situation called for.
A light like this is all about flood, of course, and once I was illuminating the end of our cul de sac so that we could continue playing with our RC cars. The light was on a tripod.
Another time I was at the play set in our local playground, and there was no lighting. Sun went down, I set the MK38 on the ground about 30’ away and my kids kept playing.
Last time I recall grabbing it specifically, was when we lost our indoor cat. I grabbed it and went searching through the neighborhood. Sometimes you just want a lot of light everywhere at once.
Although it’s a flooder, I’d still be curious to know what kind of throw it’s capable of.
And God said; "Let There Be Light"...And There Was A Flash Of Light...From A Flashlight.
Thank you for your review Cheule, I found it most informative and interesting. I most certainly will read your coming reviews also!
It would be very nice to see a "thrower" version of the Acebeam X75, then equipped with a different type of Led's. In the same way as e.g., Acebeam X65 min or Acebeam K30 GT.
As usual, as soon as a company has put in the effort and comes out with a new product, the customers want more. It is thankless to work with product development...
lennarta
On a light like this, I don’t even think to measure it (because of course I have some SBT90.2 throwers like the GT90, K75 and MF05+ to name a few.) and my review was already very long.
Acebeam quotes the XHP70.2 as 1150m, and the XHP70.3 as 1300m (both in the 6500K version)
I can do some rough candela testing inside my garage if you’d like, but Zeroair has rated a lot of acebeam’s lights and their throw numbers are usually good.
Thank you so much for your kind words! It makes me happy to know that people enjoy watching my video reviews!
As we wanted to demonstrate, the 80000 lumens are just a mirage, from the review we saw 64000 lumens for 1 second, immediately dropped after 30 seconds to 47000 lumens, considering the 5000k of the hue and adding an 8% more emission on the 6500k shade however we will not go never more than 69k which are the same numbers as Imalent MS18 mini with a range of 2000-3000 lumens. Again, marketing sensationalism triumphed ...
That’d be very kind and most appreciated. That was a great review, btw.
I read the comment from ACEBEAM X75 on TLF . The high efficiency of boost driver and Current 55A is possible to make X75 as a new successful high lumen monster.
Please don’t over estimate my lumen number accuracy. I use a home made texas_Ace lumen tube and it has not gone through any rigorous scientific calibration.
I think what is more important is the relative reading you can glean, like the fact that the Manker MK38 and X50 were both registering in the 30,000 to 34,000 range for seconds, while this light hit double that on the same equipment for longer.
Imalent is sending me a MS12 mini, and I will do a direct comparison against these two, which should be enlightening.
This is an excellent point. AceBeam uses boost buck drivers, and they are very efficient. It’s also why the ”very low” mode is 500+ lumens! Haha!
How did your Texas Ace tube hold up?
Well, however I only ran it for ANSI style lumen tests—no long runtime tests. I would worry that the media inside the tube might melt under 10+ minutes of operation. The light puts out SERIOUS heat.
After looking at the title, I think the numbers are even better since the 5000k is supposed to get less than the 80k lumens.
Exactly. I felt my finding supports one heck of a light. I have never had a light with this kind of output. I asked Imalent to send me a 5000K MS12 Mini. It will be interesting to see how they compare. My testing might not be super accurate with the lumen tube I have, but it should at least be sufficient to show which is brighter or has better regulation.
Thanks for sharing!
Don’t forget to participate in our Photo Contest on SM.
Exclusive Coupon to BLF members: BLF10
sales@acebeam.com
ACEBEAM ► https://www.acebeam.com
FB ► https://www.facebook.com/AcebeamWorld
FB Group ► https://www.facebook.com/groups/acebeam
Ins ► https://www.instagram.com/acebeamofficial
YTB ► https://www.youtube.com/c/ACEBEAM/featured
Tiktok ► AcebeamFlashlights
Official Amazon.US ► https://www.amazon.com/acebeam
Official Amazon.UK ► https://www.amazon.co.uk/acebeam
Official Amazon.JP ► https://www.amazon.co.jp/acebeam
Official Amazon.DE ► https://www.amazon.de/acebeam
Official Aliexpress ► https://www.aliexpress.com/store/5879734
Have some guy compare the 70.2, vs the 70.3 Hi versions please?
The 70.3 version was just added. I can make predictions:
- it will be slightly less output (should be measurable on a lumen tube, but not very noticeable to the eye)
- It will be slightly throwier, because it has no domes
- it only comes in 6500K, which for me is a bit too cool. I really prefer 5000K and lower.
Thank you Cheule.
The 70.3 HI is spec’d at only 150m more range, so I’m not sure it’s worth it.
I measured the range of this 5000K version at 931m, so it falls 218m short of their 6500K spec. No idea what the 6500K will achieve.
Piercing The Darkness YouTube channel – https://www.youtube.com/c/PiercingTheDarkness
I only manage to get an average of 220Kcd for a 6500K.
Hardusvd70
