It is a very impressive model, but I only purchased this (reviewers discount) to show my viewers the drone images since no one else will. I was relying on the range spec on turbo for the specific locations, only to be disappointed. If I had known the 1150m range was at turn on only, I wouldn’t have put my hand up to review.
No issues whatsoever with the design, build quality etc
In that video, was the flashlight on 4x21700 batteries or on power supply?
For OTF reading of 80k lumens, each LED has to output 7000+ lumens, let’s say 60W per LED, total power could be as high as 720W, that means each battery has to supply 180W of power.
Calculating battery voltage drop, assume voltage is 3.9V at high current, the current is 46A per battery.
I found the current information from another forum(【图片】acebeam x75拆机夜射【手电吧】_百度贴吧), can it explain the relationship between current and lumens about the X75?It’s 55.8A of the total battery pack output.
I think have to wait for more review.
But I think high chance it is scam.
X50 - 8LED 3x21700 38k lumens
X50 2.0 - 8LED 3x21700 45k lumens
X75 - 12LED 4x21700 80k lumens (sounds too good to have such advancement with similar type of LED and 4250mAH 21700 batteries)
And current measurement done by X75 owner in the link above. Way above maximum battery discharge specification.
With typical internal impedance of 0.016Ohm of the battery, voltage drop will be higher, 10A will have voltage drop of 0.16v, 20A will have 0.32v of voltage drop, so my estimated calculation of 3.9V at high current is too optimistic. The more voltage drop, the more current it needs to sustain 720W power estimation.
If the current measurement is correct with minimal error, 720W/55.8A/4 = 3.22v per battery.
Or 55.8A*0.016ohm= 0.89v , 4.2v-0.89v = 3.31v per battery.
Now the question is the safety to discharge at 55A for 45A max discharge battery. Looks like power consumption wise it is there.
And question about the very high efficiency of Acebeam circuit to deliver all these power to the LEDs, or it won’t get to 80k lumens.
More review will reveal the actual lumens number.
This is both scam and SAFETY issue to me.
Acebeam should make X75 takes 8x21700 battery pack and sell this battery pack at cost price to existing buyer. Feels like it is incomplete product with 4x21700 battery pack.
You mean modded direct drive lights? Sure some extreme expert modders are doing that for extreme performance. But 55A for one 21700 battery is not common.
I am not aware of any stock light that sucks 55A of juice per battery.
wow it does look a bit underwhelming at that pic, if thats how its close to reality what u see with eyes it seems its not worth it… so many lumens and not so big difference ?
i think the flashlight industry needs rules and regulations, stating a light that does 80k lumens but doesnt even hold that for even 10 seconds sounds like a ripoff to me…
