I’m pretty keen to see Anduril on some of the Convoy drivers. I would replace the driver in my M21C-U if one were available, or simply buy an M21D for the onboard charging
Large 3x21700 SBT90.2 thrower prototype shared on Facebook and then Reddit. It looks awesome! I hope that the Anduril 2 driver Simon said he’d work on will be compatible.
I’ll soon buy a S21A with the B35AM 4500k, but I really wanted something small with a 1800k LED in it. Something like a T3 or even a S2, perhaps a triple E21 S2? That would be awesome. Btw, do you still have plans for a triple S2+
Ahhhhhh it’s a WT90 lookalike. Yep, FET driver for sure with this. Sadly just another hotrod thrower probably. If he did a constant current channel like 15-20 amps and a FET channel for turbo I’d be all over it. Amutorch did a buck driver for the DM90 that pulls over 20 amps sp it’s possible.
Doesn’t Hank have a 6V 22mm driver now for the B35AM in the new D1?
Speaking of 6V drivers, I think one of the best things Convoy could focus on next would be getting some XHP50.3 HI and XHP70.3 HI in 90 CRI. The 50.3 HI in particular would fill the niche of a reasonably throwy High CRI light. Could likely pair it with the XHP70.2 driver, since I think it can take a fair bit more than the 3A from the XHP50.2 driver.
