I also have a 20,000 mah graphene power bank with a 100 watt usb-c port and a 90 watt car Charger. I just have to decide how important 5000K is or if I should just get the 6500 one
Why would you not use the conversion factor if your meter / lumens tube requires a conversion factor, then proceed to call the non converted measurements “lumens?”
The lumen output at 30 seconds from the calibration lights is relatively low (e.g. 270 lumens) and I doubt the accuracy of a DIY lumen tube when it comes to integrating light from these big flooders with 50,000+ lumens. A sphere may be needed.
Did he use the lux values for comparing big flooders rather than lumens?
Matt used his tube without Maukka’s calibration for 77,200. If he uses his Maukka calibration it’s only 57,900.
My Astrolux EC06 peaked at 26K and the X75 at 54K, but people say you need 3-4x the lumens for something to appear twice as bright, and the X75 in my photos looks at least twice as bright, so who knows. Marco at 1Lumen measured the EC06 at 16K with his sphere, so maybe these tubes are just not able to measured higher output very well. We will see what his numbers are when he finishes his review Correction: it was owen that measured close to 18K in a tube, so I really don’t know then
Yes. I also got greasy fingers the first time I used it, but the second time I just kept my hand on the body when I plugged in the charger. Hands down I prefer not having to carry a charger with me. I can take the cable from my phone or anything else and charge it even if the brick is at home.
Glad you asked For the video I was trying to keep it simple and not get the general public bogged down in too many details. Here I’m happy to go full blown rabbit hole.
What I did was actually more like “calibrating” off the acebeam X75 5000k which is 75000 lumens. Saying that IF acebeam is correct about their numbers Then these are the numbers I get from Imalent. Doing this brings the numbers for both companies very close to being in line with the claims they make on paper. I thought it made for a simpler A to B to C comparison.
Here at BLF the general consensus is that we’re right and they’re wrong, and everybody gets all dug in on both sides. I still want to acknowledge that I’m using a PVC pipe and most of the big manufactures in China are likely using a $15k integrating sphere. Clearly they have financial motive to keep the numbers high, but I also like to remember that this entire forum including myself calibrated off one guy. My core belief is that Maukka is right and therefore our numbers are closer to being correct.
I’ve had backlash from different companies in the past over this, and a number of other things, and I’ve always stuck to my guns (unless some actual mistake was pointed out). I feel confident about the integrity of my reviews for this reason (I didn’t take anything here as “questioning” that.) I try to deliver the most digestible content to my audience a large % of that on youtube are not forum members, hence the deviation from tradition.
I just heard from Marco at 1Lumen, who has a sphere, he measured close to the Acebeam rating. He hasn’t mentioned exactly what he got, but said it was much closer than what he expected.
Everyone using a tube is getting a low result which brings me to the conclusion that Maukka’s calibration, in a tube, is only accurate to a certain point. I think we should be building a sphere, I just don’t know where to get a Styrofoam ball at 50cm in NZ to make one.
Thank you for the suggestion, but it looks like liquid latex isn’t cheap. Marco said he could ship me one, I just don’t know whether it would arrive intact since it is hollow
China user measure much lower throw number of 244kcd although Acebeam claims to have 330kcd. That explain why X75 has unimpressive throw(Someone posted beamshot saying disappointed with the throw of X75 in this forum, but later edited it because of unknown reason.)
Is this promotional review to boost sales of X75? Why hiding all the short coming of X75? If it is promotional review, please be frank.
I hope you note that China user also is using a cheap lux meter and shouldn’t be used to claim Acebeam were providing false numbers, The lux meter is the UNI-T UT383BT which isn’t certified. My measurement of 932m is also only measured with a $20 lux meter.
1Lumen has measured the X75 and said their lumen result is very close to the 80,000 rating. Marco used a calibrated Sphere, not just a PVC tube that myself, Matt, and Cheule used in our reviews.
You better learn to respect your own words. I don’t trust you’re neutral anymore as you keep defending Acebeam and hiding X75 shortcoming. I know Acebeam gave you discount, so what? Do you really need to defend Acebeam so much even forgot your own disappointment.
X75 5000k claims to have 75000lm
X75 6500k claims to have 80000lm
You really trust Acebeam saying that the throw can deviate so much between them? You better don’t be reviewer anymore.
I am sure you will be disappointed with X75 6500k too because it is only 5000lm more, about 6% more lumens but spread across VERY VERY wide area.
Sure. Let’s wait for 1lumen review.
China users and reviewers are more straight to the point nowadays. Those lux meters are cheap, but it is done at the same condition and same night. It sure can be used to compare throw performance among flashlights.
Your measurement of 932m means 217kcd. It is even much lower than the spec of 330kcd.
