Unheard
(Unheard)
August 7, 2022, 12:59pm
2058
So, thanks to thefreeman (nice adapter) and gchart, I was finally able to reflash my SP10 Pro .
This light will get a 5000K 519A if I can get one. Installed gcc-avr und the Atmel files on my Pi, hopefuly I can get Andúril to compile on this system. One thing to do: Kicking out the reversed direction after ramping up.
TimMc
(TimMc)
August 7, 2022, 1:25pm
2059
Thanks for the pogo adapter gchart!
I finally got around to updating Anduril on my SP10 Pro and TS10 using a CP2102 USB adapter and pogo adapter.
Here are my notes for using gchart’s adapter with Ubuntu 22.04 LTS to build Anduril 2 and flash an SP10 and TS10 with avrdude:
starryalley pointed out that v1 of the attiny dfp pack works. I had a compilation error with the SP10 Pro when using v2 of the pack.
Has anyone got ZFlasher AVR working for Android?
Flashbug
(Flashbug)
August 22, 2022, 1:25pm
2061
Have anyone done a runtime on moon mode ?
Just curious how long it last
Parametrek or Bob_McBob could make a synthetic runtime test…
newbie74
(newbie74)
August 25, 2022, 12:44am
2063
This forum rocks.
Lost my Convoy AA and it took less than 5 minutes reading to decide on buying the SP10.
Thanks for all the info!
Venom
(Venom)
September 1, 2022, 11:42am
2064
What’s everyone using for a 14500 cell with the SP10 Pro?
Protected or Non?
It’s a long thread to read through everything. I figure I’ll ask.
SammysHP
September 1, 2022, 11:57am
2065
The unprotected one from Sofirn.
Venom
(Venom)
September 1, 2022, 12:29pm
2066
Anything in the U.S.?
I have a Sofirn headlamp with 14500 & charger. Will the charger charge any 14500 or any size cell?
Unheard
(Unheard)
September 1, 2022, 2:44pm
2068
There’s not much space in the battery tube. None of my 14500 fits. They’re all protected, Olight, Klarus, and Wuben. So I’m stuck with Eneloops. Could be worse.
Venom
(Venom)
September 1, 2022, 9:08pm
2069
Will the Vapecell fit the tube?
I have a local Vape shop that sells Vapecell.
Venom
(Venom)
September 1, 2022, 9:09pm
2070
Unheard:
You could be stuck using alkaline.
contactcr
(contactcr)
September 1, 2022, 9:39pm
2071
Yes I use them. Make sure you get the button tops though (unprotected). I think the positive side requires it since there is no spring if i recall.
TIFisher
(TIFisher)
September 2, 2022, 12:05am
2072
^This ^
There are two raised pads on either side of the driver’s positive contact to prevent reverse polarity issues if the cell is installed backwards, thus flat top cells won’t work. I’m running a Keeppower P1450C2 protected 1000mAh 4A cell in mine. It’s a little long (51.5 mm), but no problem. Have Vapcell Gold 3A button tops as well (50.5 mm). Great cells and run them in a few of my lights.
Venom
(Venom)
September 2, 2022, 12:11pm
2073
TIFisher:
^This ^
I was looking at the Keeppower 14500 for the Lumintop Tool AA.
Do you know if the Keeppower will fit the Tool AA?
TIFisher
(TIFisher)
September 3, 2022, 12:15am
2074
Sure does. As a matter of fact, that’s what I run in my Tool as well.
mortuus
(mortuus)
September 3, 2022, 10:44am
2075
vapcell should fit since its unprotected, the H10 is the best 14500 cell. Dont have the light so cant test but i asume its same as with fw3a lights, most protected too long…
Venom
(Venom)
September 3, 2022, 1:39pm
2076
Thanks for all the replies everyone, appreciate it!
What’s everyone using for a charger?
Its been years since I bought anything flashlight related.
Venom
(Venom)
September 3, 2022, 10:18pm
2077
What’s is the difference between SP10 Pro version 1 and version 2?
I seen it mentioned somewhere but I can’t find it now.
EDIT
Found the article I was looking for. It was on a different forum.
