FearOfTheDark's Modified Light for the 10th Annual BLF/OL Contest
31 posts / 0 new
FearOfTheDark
Last seen: 18 hours 17 min ago
I am so happy that another BLF competition has started. Cool
I have a project that I have been putting off for a long time. So I hope the competition will give me the necessary motivation to start (and complete) it soon.
One of my favorite headlamps (Nitecore HC90) was destroyed by water ingress which caused corrosion on the circuit. I tried to fix it without success. I also contacted the manufacturer and asked to buy spare parts but they no longer have spare parts for this discontinued model.
Since I love this flashlight and don’t want to throw it away, I decided to build a new circuit that would support the three RGB LEDs as well as the main white LED.
I don’t believe that I will be able to restore the magnetic slide switch, but I want to maintain the stepless ramping for the white LED.
For those who are not familiar with the model, here is a brief description from the Nitecore website:
The corroded board and some of my tries to fix it :
FearOfTheDark
Final look and video from the stairs
View post on imgur.com
Hoop
Hoop's picture
Last seen: 2 hours 28 min ago
Looks like a good project FearOfTheDark. Thumbs Up
Maybe you could implement linear dimming work with a slide potentiometer.
FearOfTheDark
This is a good idea but it will not be waterproof and water caused this whole mess in the first place Smile
FearOfTheDark
I have completed the board with the positive pole and a microswitch.
Instead of the USB charging socket, I inserted a switch boot. Under the boot, I placed a board with an electronic switch on one side and a spring on the other. I had to sand the board so that it would sit exactly in place like the original board.
FearOfTheDark
The work on the circuit board: I sawed and sand the Protoboard to fit exactly like the original one
MtnDon
MtnDon's picture
Last seen: 3 hours 33 min ago
Nice!
FearOfTheDark
Continuing the work on the board: adding a copper contact for the negative pole (lamp body)
FearOfTheDark
Soldering the 8 current regulators to the Protoboard:
These 8 thin wires are part of the next step I started working on but haven’t finished yet and will share next time…
Hoop
Hoop's picture
Wow. I wasn’t expecting this!
lumenzilla
lumenzilla's picture
Last seen: 1 day 13 hours ago
I believe this will be good Thumbs Up
FearOfTheDark
Thanks guys.
Hope it will be good.
FearOfTheDark
“Dead bug” soldering the MCU (The wires may be familiar to you):
MtnDon
MtnDon's picture
Smile Thumbs Up
The Whispering ...
Last seen: 3 hours 27 min ago
Nice work so far, can’t wait to see the finished product. What firmware are you going to use? Anduril for the stepless ramping?
FearOfTheDark
Thanks, I wrote my own FW.
Actually that’s why I only started making progress with the HW in the last few days, I was busy writing the code.
I did not find any existing FW for controlling four LEDs (RGB+W)
FearOfTheDark
I haven’t updated on my progress in the last few days because after soldering almost the whole circuit I couldn’t get it to work Sad
I had to desolder all components and wires and repeat everything, step by step, until I realized that the problem is probably with the current regulators.
I couldn’t figure out which of the components is defective so I will replace them all.
MtnDon
MtnDon's picture
Very frustrating. I’ve run into that and now am certain to test the operation many times as assembly progresses. Keep up the good work. Smile
FearOfTheDark
So it turns out I was just unlucky twice and two defective regulators managed to get into my component pool. I have to stop ordering components from AliExpress Facepalm
After I replaced all the regulators I encountered the same problem again – changing the PWM did not affect the LED and it illuminates constantly in low brightness , even with a cycle time of 0.
I turned to the BLF experts for help, but the solutions they offered me did not solve the problem:
I added a capacitor to filter the noise on the ATtiny’s voltage and even lowered the ATtiny’s frequency.
Unfortunately, lowering the frequency to 128KHz locked the ATtiny to burn and before I realized it, I changed to my second ATtiny and destroyed it too.
I was very desperate because I had no more ATtinys left to replace and I was already considering abandoning the project.
Finally, after some online research, I found a tip to change the frequency of the ISP’s clock and I was able to burn to the ATtiny again but I still haven’t solved the problem with the regulators.
I decided to desolder all the regulators from the circuit again and check them one by one until I found the faulty component and threw it away.
After all this struggle I soldered the working regulators back to the circuit for the third time and now it finally works properly.
bobvoeh
bobvoeh's picture
Last seen: 6 hours 43 min ago
Frankenheadlamp! Love it. Can’t wait to see how this turns out.
FearOfTheDark
After I finished with the regulators, I removed all the LEDs I solder for debugging the circuit and FW.
I permanently connected the resistor and capacitor. I had to sand down the capacitor to fit it in the narrow space between the board and the lid
FearOfTheDark
Thanks bobvoeh,
Unfortunately, it takes a lot more time than I planned
MtnDon
MtnDon's picture
Doesn’t most things? Wink Looking good.
FearOfTheDark
Indeed, especially hardware projects
FearOfTheDark
Just before I put everything together, I wrote a FW that turns on the LEDs randomly to make sure everything works as expected
MtnDon
MtnDon's picture
Thumbs Up
wcddesign
Last seen: 2 weeks 4 days ago
Oh I hope I’ve learned enough by next year to write my own firmware. This looks great.
FearOfTheDark
The last steps always take the longest. But, the deadline is approaching so I have to move forward with the project.
I soldered all the wires, to the button and to the colored LEDs.
I also glued the rubber to protect the button.
Unfortunately the original wire for the main LED is too short and I can't close the light so I have to replace it to complete the light.
Meanwhile I ran it with the random FW to make sure everything works.
FearOfTheDark
Before the end of the competition, I disassembled the LED and r reflector to replace the wire. I soldered a new longer wire and closed the headlamp.
Apart from the new button instead of the charging socket, it is not possible to tell that the entire internal circuit has been replaced.
MtnDon
MtnDon's picture
Thumbs Up
MascaratumB
MascaratumB's picture
Last seen: 12 hours 47 min ago
Wow, this was a modification deeper than it was expected Wink
I’m glad it worked out well and that you solved it! The learning curve surely rose in this project!
Well done Thumbs Up
