Sofirn Q8 Pro Comprehensive Review
Thanks for the review.
Got a couple of BLT LT1. Love that lantern and is pushing me to a Q8 as my next purchase.
Iā€™ve seen a few newer gadget down graded from previous builds. Is it cost cutting, design flaw or chip shortages? I tend to think the last two here.
Great review on the Sofirn Q8 Pro.
Tried your 30% discount code on amazon UK. polymeros30 no longer works.
Do you have another 30% discount code?
Thank you.
Got the Q8 pro and the If22a in my Amazon basket any 30% discount codes? Cheers Dean.
I have an original BLF Q8 and Sofirn Q8 Pro - It is a worthwhile upgrade for the additional power and efficiency of the xhp50s and the convenience of USB charging. Either way I recommend upgrading the firmware in your Q8 to Anduril 2 - you will love it - I do.
Also latest batch only has single wires going to MCPCB.
Hello everyone :slight_smile:
Long time reader here (years!) but new member :slight_smile:
Itā€™s my first post and it is a question. I am not too proud about that
There it goes:
I am the proud owner of many flashlights, diverse and all satisfying.
Recently, I bought a Q8 Pro as an upgrade to my original BLF Q8. The appeal of the USB charge, powerbank and blablabla you know the excuses we make to expand the collection.
However, 2 things have been frustrating me for the 48 hours Iā€™ve had this light.
A. Can you change the color of the LED switch as indicated in the Anduril 2.0 manual?
The 7H from locked or standby doesnā€™t do anything for me.
B. How do you remove the reflector? I would like to swap it with the one in my original Q8 just for fun, but it seems glued to the head. I know it probably wonā€™t even fit due to the difference in size between emitters, but I would love to try :slight_smile:
Can anyone help me with these questions?
Thank you.
Hello, welcome and I hope I can help.
A. Anduril has the ability to control RGB Auxiliary and / or switch LEDs, if they are present. The LEDs in the switch of the Q8 Pro are not RGB and therefore you cannot control / change their colours.
B. The reflector is screwed on to the body of the light from the inside. You would have to remove the driver first and then remove a screw that holds the reflector in place.
Aaand thank you :face_with_monocle:
Very clear answers, you did help :slight_smile:
A. Disappointed that I cannot change the color of the switch, but at least I now know why it did not operate.
B. Understood. I will do that.
PS: this forum really is invaluable. I really appreciate it and I love the spirit of this community.
It is a pleasant hobby, that I am very happy to share with pleasant people :slight_smile:
Thanks for signing up, Magnus.LPA!
Your English is perfect although you are in France.
How many languages do you know?
Thank you!
I was born in France and then lived in various places, so I speak:
- French
- English
- Spanish
  • Italian.
Nice!
Although I took 2.5 years of Spanish in Junior High and High School, the only language I know well is English.
Performance aside, you simply cannot beat the OG Thorfire Q8.
Well, that is enough to be understood almost worldwide :slight_smile:
Interesting! :slight_smile:
What do you think makes the original one better than following versions?
Is it soldering quality or things like that? Is it the tighter beam pattern? Or the tint?
Itā€™s the fact itā€™s the original version, that was designed here - and is perfect in every way.
Other versions are simply using the OG design with newer technology, and they donā€™t really have the status and aura of the original one.
Iā€™m a person who likes old school, I own 2 90s cars and will always deem them better than newer cars. I suppose that ethos has rolled over to some torches I own, Q8 included.
Ok, I understand :slight_smile:
Hello everyone. New guy here!
Just got a Q8Pro. I heard that there may be some tweaks that would be worthwhile. First was mention of thermal paste. Has anyone done this? I assume there is a heat sink and maybe some crappy factory thermal pad or paste that would benefit from a professional do-over? And something about a better lens, better than the stock one?
Separately, I did a factory reset and have checked the temperature. It seems to consistently come in at a couple degrees lower than ambient. For instance, right now it has been overnight in a 65F room, unscrewed. But it thinks itā€™s 17C, which is 62.6F. I have a digital temp sensor next to it and also confirmed with an optical thermometer point&shoot. Should I manually calibrate?
Iā€™m going to fabricate some sort of robust handlebar/stem mount for my mountain bike. I originally wanted to use the tripod receiver, got a GoPro adapter that screws in. But even with a well tightened down lock ring it ultimately starts wobbling due to its weight. Donā€™t need it going loose while dropping some big roller in the middle of the night. Anyone have any ideas of a mounting system, or examples of someone who already did this?
I just bought some of these to try mounting some smaller lights to my handlebars. Havenā€™t tried yet but they look solid enough for a 1x18650 or 21700 lightā€¦ Amazon.com
