This is hard for me...decent big lantern are quite expensive over my side (rechargeble 8 Ds inside, florensent tube, coming USD$ 200/-).-[i rather forgo the lantern & get HID torch, haha] **generator size [bringing in & out of country is a hassle-dunno will there be thief if i leave the generator at the house with flimsy door], kero lights are just like 1 candle. Real commercial floodlights running 24v/36v cost slightly over usd$1k to reach me..
I read many reviews of "flood to throw torch" but your photos say a thousands words, am very much impressed with Poppas w878 too.
Poppas w878 seems to be the cheapest way for me, but having to use so many battery also dun seems any bang for buck.
Also do not know can it handle car battery 12v like tf-3t6, hmmmmmm......how should i wire them? LOL
May i know if the "head & body" (do not know the exact term) O-ring is sufficent for watertight/submissible?
Ok, apparently the lens is glued into the bezel and I didn’t want to force it out, so I did the best I could. It’s 29.0mm across (inside of bezel to inside of bezel really) and about 10mm in thickness (the front of the bezel gets in the way to measure to the lens, but 10mm is going to be darn close.
It must have a different driver as I’ve had the following tailcap readings, off of a King King unprotected 26650:
At 4.2V 2.69A
At 3.9V 2.25A
At 3.6V 1.6A
Current reduces as the voltage lowers. It’s very bright with a fully charged battery. I’m pretty happy with it, and the zoomy head seems pretty stiff and hasn’t yet automatically zoomed on me when nightriding on the mountain bike. It also makes a great emergency replacement room light if you blow a bulb.
I took my poppas apart and did have closer look what it have been eating. Unscrewing the pill was kind of hard… It was so tight that i thought there is some clue in threads, so i even warmed the head little bit ( there was no clue ). After a little struggle ( and many scratches later ) I did get that pill unscrewed. Leather clow and long head pincers was the key.
There is reason for this. It does not only feel like that, it really scrathes metal against metal. When you unscrew pill you can take head of and there is place for o-ring in body. Apparently torch builders thought that metal ring is better than rubber o-ring (???). So I recommend to change that. After changing sliding head is sooo smooth ;). Here’s picture with stock metal one on table and blue o-ring but as replacement on body. You can even but thicker o-ring if you want adjusting to be more stiffer. Sure that o-ring can’t take as much stress as metal ring and maybe some harder plastic ring would be best option. But I think that quality and tight o-ring with grease on it will last as long as light it self.
Garry already told about one missing o-ring, but here’s picture of that. I have put blue ring on there so you can see that place better.
Tail-cap reading from my light on high is 2.74A with TF flame 26650. It’s also steady now ( pushing battery does not increase amperes ) ’cause I welded cord in drivers spring.
When I do few snappy hammer motions the head did slide about 1-2mm. Even it is much better now it still could be little stiffer to avoid all accidents.
I try to remember today to pick thicker o-ring from work and try with that. I’m sure then it will be pretty stiff.
I changed o-ring to little thicker (about 19x2mm). 19mm o-ring needed some stretchning ’cause that heads diameter is 30mm (bigger diameter rings that I had was too thick). But it snaped nicely in its place.
Now that head is stiff. It won’t move by accident, I’m pretty sure about that. I “hammered” with flashlight few times hard and that head remained same place where I left it.
This is how it should have worked in first place.
Ordered/shipped on 11/12, any day now hopefully. Was looking for a light to use a single 26650, and the flood on this one sounds nice. Looks like it need some TLC - when I get it, I'll be studying this thread carefully - thanks for all the info!!
I would be interested in upgrading to a KD V2 3.04A driver, maybe add 1-2 380's to it (3.4A-3.8A). It looks like an aluminum pill however - wonder if there's a brass ring to solder to. If it's solid aluminum, it's a pain but I'm experienced with the cheap stuff!
Just got this light, bad news with this light - no flat surface/heat sink for the LED star mount. LED is loose, floating, and hangs on the edges, same as a driver does on the opposite end of the pill. I've seen this before in a cheap zoomie. Does anyone have any ideas? I could use good thermal grease or thermal epoxy on the edges, or press fit something inside the pill, but to get it aligned perfectly to the back of the star may be a nightmare. There is plenty of depth in the pill to work with.
I ordered the Poppas S7, that's what the links for the 878 take you to now - looks like Manafont changed the model name listed but appears to be the identical light, accept maybe for the hole at the top of the pill ...
Solved it - I got several brass pills from FancyFlashLights and sanded one down to build a press-fit insert, flush fit behind the star - worked well, also added copper/solder into it for additional heat sinking. I'll post pics. I'm using a 2nd brass pill to convert the 20mm driver mount to 17. This light has a big aluminum pill, massive now will the copper, solder, 2 brass pills, so I'm putting in a KD V2 running 3.8 amps (10*7135).
Update: I got it working at 3.4A, still will update it to 3.8A. At 3.4A, it's nice, real nice - my most powerful zoomie but all my other zoomies are cheap and small. With a 26650 and all the mass I added, it's heavy, feels solid. Really like the width of it in full flood (truly lights up a full room, more than a HD2010 or modded C8) and in throw, the square image is smaller than my other T6/U2 FTT's and it throws pretty well - not as much as a HD2010, Jacob, or maybe even my modded C8 at 3.8A/U3. It takes quite a while to get warm/hot which is what I expected with all thah mass - used Arctic Silver grease, not epoxy, on the star because the reflector screws down onto the star to keep it firmly in place.
More Updates (12/09/12 eve):
Got it working at 3.8A now - really like this light now! Using a King Kong, lot of mass, tailstands, just need to add a nice GITD lanyard and a holster.
The hole under where the star was, and the sanded down pill to use as the star backing:
Close up of the sanded down pill:
Sanded down pill with the original pill, before sanding:
After mounted:
Showing the heat sink additions (cut copper wire, held together with solder), and the next pill sanded down for mounting the 20mm driver:
Up close view of sanded pill before press-fitting into place:
Final assembly (no pic) has the original pill with the star backing pill with heat sink filler, and the other brass pill for mounting the 17mm driver in. This thing is now heavy!
Thanks Tom for the photos! Never realized this one had a hollow pill. I've run mine on a King Kong unprotected at 4.0A+ for a few minutes at a time too!.
BTW - is that an older Kenwood receiver I spot down there under your workbench?
Garry - could be the original 878 was ok, but the Poppas S7 replacement has it missing. If you go to the link for the 878, you get the S7 light with the earlier 878 reviews posted, including yours! Think they cheapened out in the redesign. Thought I saw a pic on BLF of the 878 pill showing it had the full backing for the star.
Update: hhhmm, not a Kenwood, but kind of got stuck there - nowhere else to go with it for now.
Garry - did you verify you have the 878? Was wondering if the S7 model cheaped out. here's the 878 pill posted back in April and it definitely shows a solid backing behind the star, but no thermal grease: https://budgetlightforum.com/t/-/7687. You posted there as well.
