I'll do the runtime / regulation tests as soon as I have enough time. I have two very interesting lights incoming (most probably tomorrow) and I think I'll write those reviews before even trying to measure these lights => Don't hold your breath.. ;)
Thanks the for taking the time to share these lights with us. I’m surprised that the 10440 capability doesn’t give the tank more of an edge. Interesting.
Yes. It takes 10440 and is significantly brighter with that. But that's not what I want from a keychain light. :)
True. I would classify it as a neutral white. The packaging says that SKILHUNT is manufactured as CW, NW & WW versions. Maybe I won in the DD lottery? ;)
Much stronger. It tailhangs without any problem in any position.
Thanks for the comparison, I was wondering when the SkillHunt would be out, I’m glad you ran a comparison because by itself it’s nothin fancy but it excels as a backup or coat light
very nice comparison ty
unfortunately prices are unstable at DD…
could you compare the mid of the E09 with the high of the others? mAh are leveled if the e09 is not bright like the others the driver sux to don’t speck about PWM
which parts are you talking of were glued? there is no need to tear out the driver pill or driver sandwhich (with the green contact disc). in any case, on the top side there is the LED (LED star) with the 2 soldered wires, as shown in my review. if you want to swap the LED, de-solder the 2 wires off the LED star, exchange the LED star, and use the same wires to re-solder them back on the new LED star. done.
if you have "ruined" the E09 driver itself (somehow), then tant pis. Keep it as reservoir of spare parts. Buy a new E09 from DD (starts from 11.99$ before the triple discounts) and all good ;)
