It is the same series, so it’s great, after all I am interested how they all look in this series of flat jaw wrenches.
I do not know why one is ground and another not, but definitely I would like to know how are these sold in general.
That is what I have thought too, that the smooth surface on both jaws should actually protect the surfaces, since you actually want it to slip on the nut then press on the handles once parallel is achieved.
I have several of them. But all at home. Can check tomorrow.
That would be great.
the amazon description doesn;t mention smooth or rough jaw finishing
I copied that description from the Knipex website.
“Smooth jaw” should be smooth jaw. There should not be any questions here. It clearly slipped through the cracks or the seams. A file or Dremel tool or sanding tool or other should be able to make it pretty smooth pretty fast.
why not just return them
I want to know how these look in general, before going into a long return and buy again cycle.
And I still hope people share how it looks on theirs, I have not seen any talk about this matter before.
And I still hope people share how it looks on theirs.
oh
but you still will not know what you will be getting, if you re order
it;s kind of a long shot that more than 1 or 2 people on here will have these exact pliers
wle
Any size in this series is good info for me like I have said before, I may want to order other sizes too, in fact that is what I wanted.
These series of pliers are quite popular, not sure why you imagine only 1 or 2 people having them.
The V jaw type are so much better at everything. If you’re worried about scratching things, put some electrical tape around the V jaws before you attack anything that you might scratch. Or like I said, make it smooth yourself. If you don’t have tools to do it probably know somebody that does. And they will tell you to get the v jaws.
Knipex? Waste of money.
Mine (86 03 180) looks just like yours, top flat, bottom “not ground”
Like Oli said, if you don’t want to scratch something, you’ll have to use a barrier, like paper or tape or whatever. This would be the case even if both surfaces were ground.
Total noob here and first time posting but I do own a set of 86 03 250 (same size without the comfort grip handles) Knipex pliers wrenches. I don’t know if it’s clear in the attached pictures but the upper jaw is forged with a machined surface. If it didn’t get machined, there would be a parting line through the gripping portion of the upper jaw. However the lower jaw doesn’t have any obvious secondary operations. My thoughts are that it is investment cast. Either way it’s not as rough as the lower jaw in the set you received.
i have ~10 knipex PWs, and the surface finish on the jaws of OP's pics are within the range of what i've seen. it's normal imo, but funny to see both on one tool.
besides, after use, they will get a bit chewed up and will have bigger surface defects than that.
btw, i would have asked this on garage journal.
I had not noticed this before . I have the 86-03-250 , and 86-03-180 . Both have ground upper and a slightly textured bottom jaw .
Checked my set of pliers wrenches, they all look like strangequark’s one.
It looks like neither the top nor the bottom pieces are forged as you can see the parting line of the pressure casting mold and the taper or draft in the side wall of those “strengthening” holes in the lower jaw. Likely the flashing was unsightly and needed to be ground off the top jaw.
Odd, mine is also 86 03 180, but both top and bottom are the same. Both sides are not quite ground but not rough.
