If I have these: https://www.amazon.com/dp/B00LZV1G6K, then can I just solder the wire to the jumper connecting TX/RX or is the diode required?
I just got some of those USB adapters. From my tests, I was able to flash firmware just fine. BUT… I have not yet tried that with just jumping the TX and RX together. Some people have gotten it to work, and I think a couple have not reported as much luck.
Those are the adapters I have, I have not tried any flashing yet, I only connected it to my pc to make sure I could see the com port.
No dice. So where is a good place to get assorted diodes and resistors?
Are these still shipping with Anduril 1.0?
yes
the SC21 Pro ships w Anduril 1.
I use gcharts programmer to reflash to Anduril 2.
alternatively, the Wurkkos TS10, and Sofirn SP10 Pro, ship w Anduril 2
Cool, my SP10Pro is on permanent EDC duty, but I just wanted to see the difference in hand between the 16340 and 14500 size lights. Can’t really take the word of people online about feel in hand because, well, their hands aren’t my hands
I might go for one anyway just because they’re so(firn) affordable. Just to see how it feels.
I like the shorter (but fatter) SC21 Pro size better than the SP10 Pro form factor. (both lights have the same carry weight)
I also like the lighted button better, the clip rides deeper, and it tailstands better
Very nice - the reflectors are the same size, right? I think I heard that somewhere.
Any luck on finding a TIR that goes in without too much sanding or cutting required? I’ve got DC-Fix on my SP10Pro, but I’m curious if there are any other nice lens options.
actually no
I do not have a good undetstanding of the Pebbled Tir Options… but yes, I have seen some photos
Ok thanks. Those are nice pinks
Pebble Tir info
Don’t recall if this was mentioned earlier; the TIRs Convoy/Simon sell for the S2+ also fit wonderfully in the SC21 without the glass lens and emitter gasket just as they do in the S2+. The head will screw down more for those who don’t need the warning label to line up I grabbed a random beaded TIR from my stash, probably a 15deg, and honestly wish this were an option from factory, it’s great. [image] [image]
Pebble Tir info
Sofirn SC21 mini - #230 by DarkShot
Very interesting, thanks for that. Pity they aren’t the same size, because I tried the S2+ TIRs and they don’t work like drop-ins on my SP10Pro like they do in that SC21Pro. That’s another tick for me getting one I guess.
20mm TIRs are most common for these lights (S2+, etc.), but 17mm is another somewhat common size. Fits in D25 headlamps with minimal sanding, so see if one of those would do.
Only thing I’d be concerned with is depth. (That’s what she said…)
Well looky what showed up in the mail yesterday! I got one built up and tested, worked great. I’ll try to get some more built up over the weekend to be able to ship out.
Yay
I just got a new SC21 Pro today… I will be happy to use your new programmer and pogo pins, when ready.
the Programmer and pogo pins you provided for SP10 Pro also works on TS10. It has been working Great for me.
fwiw, the hex for SC21 Pro needs updating to lower lows, and to add LVP to the button light circuit…
in the meantime, would it work to use the TS10 hex you made, dated 7/19, on an SC21 Pro
the only difference I know, from using the TS10 hex, is the SC21 Pro button light will be Off when main LEDs are On… no harm in that. But there is a lot I dont know… lol
Any reason NOT to put TS10 firmware on SC21 Pro?
Jumping in the pool here without reading this whole thread. I’m interested in updating to Anduril 2, so I’m interested to hear the response to jonslider’s q in the previous post.
also, my programmer is rather different than ones I’ve seen used recently.
How can someone guide me to instructions how to use this programmer with the SC21 please?
I see no reason not to put TS10 firmware on the SC21 Pro. I’ll be the guinea pig and report back.
Sorry, sbslider. That’s a USBasp, great for the attiny85 and attiny1634. But not compatible with the attiny1616. You’d need a USB to Serial TTL adapter like what you linked to above. I’ve got some on hand that I can send out with pogo adapters, or they’re available on Amazon
step 1. buy the TS10 ProgoPogo from gchart
2. here is a tutorial:
word is avrdudess also works… I cant say… my Old Mac has a brain of its own
good luck,
for me learning to reflash without prior experience… was a total cluster. I killed 2 lights in the process (I call it a Seminar Fee), almost more than Ive killed modding… lol…
I dont have your background, it may be like frisbee golf in Alameda Park for you
