Nitecore MH40S 1500LM 6500K LED Flashlight w/Wireless Remote Switch
Authentic / Luminengin G9 emitter / 7-mode / w/2*21700 batteries & 18W US QC charger / 4*CR123 / USB-C charging / IP68 / 1500m throw / 570000cd
Details:
2.4G wireless control, 1m (3.28ft) maximum signal range. The wireless remote switch is included, each of which is designed with an independent digital ID, providing better anti-disturbance performance. The wireless remote switch is powered by a 3V CR1632 button cell battery (included). The advanced power cut-off (APC) technology guarantees a standby time of 12 months for a new battery.
The QC 3.0 adapter is included, providing a max charging power of 18W.
When the remaining power is below 10%, the MH40S will inform the user by vibrating.
Highly efficient constant circuit (non-PWM): The constant brightness beam without flashing guarantees the comfortable visual experience.
Utilizes a Luminengin G9 LED with a max output of 1,500 lumens.
Max peak beam intensity of 570,000cd and max throw of 1,500 meters.
An optical system combined with crystal coating and “Precision Digital Optics Technology” (PDOT).
Powered by 2x21700 high-capacity Li-ion batteries to provide a runtime of up to 105 hours.
Equipped with the low power vibration indication.
The tactical tail switch and the mode button control 4 brightness levels and 3 special modes.
STROBE Mode uses randomly changing frequencies for stronger dizzying effects.
A power indicator beneath the mode button indicates the remaining battery power.
Intelligent Li-ion battery charging circuit with a USB Type C charging port.
Nitecore 21700 Li-ion batteries included (NL2150 5,000mAh).
Highly efficient constant current circuit provides a stable output.
Incorporated Advanced Temperature Regulation (ATR) module.
Optical lenses with double-sided scratch-resistant coating.
Constructed from aero-grade aluminum alloy.
HA III military grade hard-anodized finish.
Waterproof and dustproof rating in accordance with IP68 (2 meters submersible).
Impact resistant to 1 meter.
