Thanks Raccoon city and fasttech
Manker Timeback III 2500LM 6500K EDC LED Flashlight (Titanium Alloy)
authentic / 4*Luminus SST20 emitters / 8-mode / 1*18350 / 200m throw / multi-color ambient lights
Details:
Main light operation mode:
Moonlight mode: Long press the key for seconds to enter the moonlight mode (0.1 lumen)
Normal mode: Click the key to enter the normal mode (long press the key to switch between low light (46 lumens) - medium light (200 lumens) - high light (600 lumens))
Turbo mode: Double click the key to enter the turbo mode (2500 lumens-Automatic downshift one minute)
Special mode: Press the key three times to enter the special mode (press the key for a long time to switch strobe-beacon-SOS)
Tail light operation introduction:
Battery indicator: Automatically turn on the tail light, automatically turn off after 10 seconds (you can customize five display modes of power)
Customize five display modes: Long press for three seconds to enter the custom mode in the shutdown state (long press to switch five modes, and release to lock the current display mode)
thanks
will never buy manker
terrible switch on earlier product, no warranty support, too expensive
sorry
Just wait a few weeks for Utorch to come out with a copy.
Klarus GL4 3300LM 6500K Tactical Rail LED Flashlight w/21700 Battery
authentic / Cree XP-L2 HD emitter / 6-mode / USB-C charging / IPX8 / 370m throw / 34240cd
Details:
Voltage: 2.8-4.2V
Impact resistance: 1.5m
Waterproof: IPX8 (30 minutes operation submerged 2m)
370m range can be easily adapted for both tactical and outdoor use
Professional cable switch setup for maximum versatility
1913 rail compatible
Please note: When attaching or detaching the GL4 light, unload and remove the magazines
Tactical/outdoor settings, different situations, different uses
Manker MC12 II 950LM Green EDC Tactical LED Flashlight w/USB-C 18650 Battery
authentic / OSRAM OSTAR Projection Compact KP CSLNM1.F1 emitter / 3-mode / IPX8 / 650m throw / 97600cd
Details:
Powered by 1x 3.7V 2600mAh high-drain protected 18650 rechargeable lithium ion battery with USB Type C charging port (Included) 18650 battery built-in charging & reverse charging circuit with a USB Type C port. Plug the included USB Type C charging cable (integrated OTG), it can be charged (max. 5V/1A). And also reverse charged to other digital device, works as powerbank.
High efficiency constant current circuit provides a stable output (Non-PWM).
Electronic reverse polarity protection and over discharge protection.
User interface is simple and friendly. Only 2 modes + strobe, defaults on high mode.
Lens: Double-sided anti-reflective coated, 99% transmittance toughened glass lens + high temperature resistant total internal reflection (TIR) lens
Material: Constructed from aircraft-grade aluminum alloy.
Surface Treatment: Premium type-III hard-anodized anti-abrasive finish.
The anti-slip knurling on the tube guarantees a firm grip within your palm and offers better user experience.
Stainless steel pocket clip works on the pocket, belts, the backpack, and is molle system compatible.
Forward click tactical tail switch allows for momentary-on and constant-on illumination.
Specialized silicone button cap facilitates precise tactical operation with gloves.
IPX8 waterproof standard (2 meters under water).
Impact resistance: 2 meters.
Battery charging indicator: Plug USB Type C socket of the included charging cable into the USB Type C port of 18650 battery, and connect another USB socket to the adapter. 18650 battery has built in intelligent identified charging function. When battery is charging, the indicator will be red and keep flash. After battery charging is completed, the indicator will stop flash and red constant on.
Powerbank Indicator: Plug USB Type C socket of the included charging cable into the USB Type C port of 18650 battery, and connect another USB socket to the USB port of the digital device. 18650 battery built-in intelligent identified discharging function. When battery is reverse charging, works as powerbank, indicator will be blue constant on. When battery have not enough power to charge other digital device, blue indicator will turn off.
Manker Timeback III 2500LM 6500K EDC LED Flashlight (Aluminum Alloy White)
Details:
Moonlight mode: Long press the key for seconds to enter the moonlight mode (0.1 lumens).
Normal mode: Click the key to enter the normal mode (long press the key to switch between low light (46 lumens) - medium light (200 lumens) - high light (600 lumens)).
Turbo mode: Double-click the key to enter the turbo mode (2500 lumens-Automatic downshift one minute).
Special mode: Press the key three times to enter the special mode (press the key for a long time to switch strobe-beacon-SOS).
Battery indicator: Automatically turn on the tail light, and automatically turn it off after 10 seconds (you can customize five display modes of power).
Customize five display modes: Long press for three seconds to enter the custom mode in the shutdown state (long press to switch five modes, and release to lock the current display mode).
Whoa, cute!
That looks like a little R2D2 from Star Track!
Star Wars
Star Wars
Naw, Star Wars had The Daleks.
Jump Into Fall With Our Autumn Sitewide Sale 12% Off!
Offer: Site-wide 12% off
Valid Date: Sep 27th - Oct 1st, 2022 (UTC-6)
Coupon Code: SEP12
Customers can buy gift certificates via PayPal or credit card to get an extra 3% free value instantly.
Convoy 3X21B 12000LM 6500K LED Flashlight
3*XHP70.3 Hi LEDs / smooth/stepped ramping / 3*21700 / USB-C charging / 529m throw / 70kcd
Details:
Low voltage warning: automatic power off
Required battery type: 3*21700 batteries (without protective plate)
Head diameter: 69mm
Battery tube diameter: 51.8mm
Please note:
Reverse polarity protection: None, all the positive poles should face the head, otherwise the battery will be burnt.
If you carry the flashlight in your bag, please loosen the battery tube half a turn to prevent the flashlight from accidentally lighting up and burning the valuables in the bag.
GT FC40 LED / 5-mode / 2*21700 / IPX6 / 500m throw / OP reflector
Details:
Switch: tail switch controls on/off, side switch controls the mode
LED: soldered on 20mm copper plate
Head diameter: 55mm
Outer diameter of battery tube: 27.9mm
Inner diameter of the battery tube: 22mm
Convoy H3 1400LM- 2400LM 2700K-6500K EDC LED Flashlight Headlamp
Nichia 519A R9080 emitter or Luminus SST40 emitter / smooth/stepped ramping / 1*21700 / USB-C charging / IPX4 / 100-200m throw
Details:
Battery: 1*21700 lithium battery flat head without board (not included).
Drive: 6A output, with temperature control protection.
Switch type: electronic switch (with standby current, about 32 μA).
Tube diameter: 25.6mm.
Please note:
If the flashlight is placed in the bag, loosen the flashlight tail cover for half a turn or lock the flashlight by 10 clicks to prevent the flashlight from being opened by mistake.
If you do not use the flashlight for more than a week, take out the battery, or loosen the tail cover half a circle to prevent the battery from running out of power due to the standby current.
Jump Into Fall With Our Autumn Sitewide Sale 12% Off Now!
Dear all,
After a fun-filled summer vacation, it’s time to unwind and enjoy the cozy weather of fall. Light breeze, colorful leaves, bare trees, discover how fun life can be at FastTech. Cool season, cool offers! Join our incredible 12% sitewide sale to celebrate the harvest.
By purchasing our gift certificate, you can get a 3% extra amount instantly and a total of 15% off for this sale. The gift certificates can apply for everything, especially for E-cigarette products.
Detail about gift certificate and user guide→
Coupon Code: SEP12
PayPal payment is not available for my order - so I’m out . I’m not purchasing e-cigs or Li-ion products what goes on here?
Website states invalid coupon for Sep12.
Edit* coupon is now accepted but it doesn’t change the price to my total. It does not deduct 12%.
Does the coupon not work with chargers?
Early Fall Sale! - 7% Sitewide Off + 3% extra gift card
Dear valued customers,
We are preparing an Early Fall Sale during the National Day holiday! Let’s join the 7% Off Sitewide coupon sale now!
Offer: Site-wide 7% off
Valid Date: Oct 2nd - Oct 5th, 2022 (UTC-6)
Coupon Code: FALL7
3% extra amount by purchasing gift certificate:
By purchasing our gift certificate, you can get a 3% extra amount instantly and a total of 10% off for this sale. The gift certificates can apply for everything, especially for E-cigarette products.
Hi Paul321,
You can contact our Customer service to manually create an order and send a PayPal link to you. Thank you.
Hi blueb8llz,
If the item qty is above 3+, you will get the bulk price automatically. You can contact our CS to manually offer the 12% discount.
