Honestly I feel like Hank could have updated ALL the 18650 side-switch lights (D4V2, DT8, D1V2, DW4) with the new wider head diameter, then added a new 18650 tube to fit the new head design.
Right now it wouldnāt make sense though from a manufacturing/business standpoint, considering heās already invested into the 22mm tube system for the most recent lights
I think the DK4 highlights how chunky the D4V2 is. Donāt get me wrong, I like it a lot, but frankly itās too big for me to comfortably pocket carry.
Iām sure other people have had this idea, but Iād like to see Hank make a compact 18xxx light as a triple instead of a quad.
Hereās a modded Wowtac A6 triple compared to a D4V2. It might be hard to imagine with the pic, but thereās a huge difference in pocket-ability.
Iām overwhelmed by the emitter choicesā¦
Would be nice if there was a good writeup of characteristics to expect with each one, and maybe even comparative qualities (why one might choose 1 LED over another while still very similar in output/efficiency). Is there a page floating about somewhere in this long thread that takes a good stab at it?
Yes, I would be interested in that too.
From the emitter list I am familiar with the 365nm leds, so I immediately bough a D4v2 with 8 5W uv leds
But I would like to get 2 more D4v2 lights with regular high CRI leds like Nichia 219, and not sure which one to choose because there are so many new leds.
The new D4k, how larger is it compared to D4v2?
True. But if you want both good throw as a search light, and nice flood for when you want to light up a big area closely, I think those are the best options.
Question regarding dual channels: does ramping work the same with dual channel lights? I mean, can I still have low to high lumen ramp for just 1 channel that I choose?
This would be awesomeā¦ A compact sub-50g triple to beat FW3A / FW3X. 14500 lights are intresting also, but IMO it trades a lot of runtime/heat management for size.
519A is still pretty floody, and has a better tint and higher CRI than the LH351D, but with less output. In lights with TIR optics, there will be a very wide spill beam for all emitters. However floodier emitters will have a brighter spill beam and less bright hotspot.
The boost driver upgrade is available for the SST-20, Osram W1/W2, Nichia 219B R9080, as well as 519A version, each LED receives 2A current. The driver is not compatible with Nichia E21A, Nichia E17A, and mule versions of the flashlight.
