Will the KR4 be upgraded to 21700?
Yes, brightness ramp works just as expected (1H), the channel mix is set with 3H (it replaces momentary turbo).
This would be awesomeā¦ A compact sub-50g triple to beat FW3A / FW3X. 14500 lights are intresting also, but IMO it trades a lot of runtime/heat management for size.
Am I wrong when I say lh351d is a better flooder than 519a? I like the tint better with 519a but Iāve heard itās not as wide/flood as the lh351d.
519A is still pretty floody, and has a better tint and higher CRI than the LH351D, but with less output. In lights with TIR optics, there will be a very wide spill beam for all emitters. However floodier emitters will have a brighter spill beam and less bright hotspot.
Hank, do you offer D4K as mule with 16x E17A 1800K or E21A 2000K? If so, would a boost driver make sense, too? Hoping for a positive reply.
It's right there in the "DESCRIPTION"
The boost driver upgrade is available for the SST-20, Osram W1/W2, Nichia 219B R9080, as well as 519A version, each LED receives 2A current. The driver is not compatible with Nichia E21A, Nichia E17A, and mule versions of the flashlight.
Also hoping for a xhp70.3 D4K, mule or shallow opā¦
Iām afraid that you have to make custom D4K by your own, buddy.
Awesome. Thanks!
Hank, can you post a picture of a D4K next to a D4V2?
I just saw on Reddit D4K next to a D4V2. I like it a lot but the only thing i didnāt like is the clip.
I have a feeling it wonāt fit easy in in the pocketā¦
here it is:
https://www.reddit.com/r/Hanklights/comments/xknihj/i_got_my_new_d4k_today_im_loving_it_also_some/?utm_source=share&utm_medium=web2x&context=3
How come they both have same thickness ? Tube is thinner on D4k?
D4v2 : 95mm(length) * 28mm(head) * 24mm(body)
D4K : 103mm(length) * 28mm(head) * 26.5mm(body)
It's almost the same, but little over 1 mm thicker for the tube on both sides.
The head is the same, as the D4v2 is quite large for the 18650 (it just got a little bigger hole for the tube)
Hi, does the DM11 come with a tail magnet? I see no tick box option for one, and I could find very little information on whether it has a magnet.
It does not have a magnet. The only way to get a DM11 with a magnet (from Hank) is to also buy the 26800 tube & magnetic tailcap.
Hello, Iām new to the forum, although not in the world of flashlights, Iāve been a member of forolinternas for some time.
As in this forum and thread you are a great connoisseur of intl-outdoor flashlights and leds, I would like you to advise me which led to choose for a D1V2 of those eligible at no added cost, that it be a good launcher and 5000K.
Excuse my English, I use the google translator.
Thank you very much in advance.
As in this forum and thread you are a great connoisseur of intl-outdoor flashlights and leds, I would like you to advise me which led to choose for a D1V2 of those eligible at no added cost, that it be a good launcher and over 5000K.
I would strongly recommend considering spending the extra $5 for the SFT-40 but if your budget absolutely wonāt allow it, then W1 or W2 is the way to go for throw. W1 will throw slightly farther and will not use the battery as quickly, but W2 will have a less narrow, more generally useful beam. Personally I love the W1 but I believe many seem to prefer the W2.
