Naw, Star Wars had The Daleks.
Jump Into Fall With Our Autumn Sitewide Sale 12% Off!
Offer: Site-wide 12% off
Valid Date: Sep 27th - Oct 1st, 2022 (UTC-6)
Coupon Code: SEP12
Customers can buy gift certificates via PayPal or credit card to get an extra 3% free value instantly.
Convoy 3X21B 12000LM 6500K LED Flashlight
3*XHP70.3 Hi LEDs / smooth/stepped ramping / 3*21700 / USB-C charging / 529m throw / 70kcd
Details:
Low voltage warning: automatic power off
Required battery type: 3*21700 batteries (without protective plate)
Head diameter: 69mm
Battery tube diameter: 51.8mm
Please note:
Reverse polarity protection: None, all the positive poles should face the head, otherwise the battery will be burnt.
If you carry the flashlight in your bag, please loosen the battery tube half a turn to prevent the flashlight from accidentally lighting up and burning the valuables in the bag.
GT FC40 LED / 5-mode / 2*21700 / IPX6 / 500m throw / OP reflector
Details:
Switch: tail switch controls on/off, side switch controls the mode
LED: soldered on 20mm copper plate
Head diameter: 55mm
Outer diameter of battery tube: 27.9mm
Inner diameter of the battery tube: 22mm
Convoy H3 1400LM- 2400LM 2700K-6500K EDC LED Flashlight Headlamp
Nichia 519A R9080 emitter or Luminus SST40 emitter / smooth/stepped ramping / 1*21700 / USB-C charging / IPX4 / 100-200m throw
Details:
Battery: 1*21700 lithium battery flat head without board (not included).
Drive: 6A output, with temperature control protection.
Switch type: electronic switch (with standby current, about 32 μA).
Tube diameter: 25.6mm.
Please note:
If the flashlight is placed in the bag, loosen the flashlight tail cover for half a turn or lock the flashlight by 10 clicks to prevent the flashlight from being opened by mistake.
If you do not use the flashlight for more than a week, take out the battery, or loosen the tail cover half a circle to prevent the battery from running out of power due to the standby current.
Jump Into Fall With Our Autumn Sitewide Sale 12% Off Now!
Dear all,
After a fun-filled summer vacation, it’s time to unwind and enjoy the cozy weather of fall. Light breeze, colorful leaves, bare trees, discover how fun life can be at FastTech. Cool season, cool offers! Join our incredible 12% sitewide sale to celebrate the harvest.
By purchasing our gift certificate, you can get a 3% extra amount instantly and a total of 15% off for this sale. The gift certificates can apply for everything, especially for E-cigarette products.
Detail about gift certificate and user guide→
Coupon Code: SEP12
PayPal payment is not available for my order - so I’m out . I’m not purchasing e-cigs or Li-ion products what goes on here?
Website states invalid coupon for Sep12.
Edit* coupon is now accepted but it doesn’t change the price to my total. It does not deduct 12%.
Does the coupon not work with chargers?
Early Fall Sale! - 7% Sitewide Off + 3% extra gift card
Dear valued customers,
We are preparing an Early Fall Sale during the National Day holiday! Let’s join the 7% Off Sitewide coupon sale now!
Offer: Site-wide 7% off
Valid Date: Oct 2nd - Oct 5th, 2022 (UTC-6)
Coupon Code: FALL7
3% extra amount by purchasing gift certificate:
By purchasing our gift certificate, you can get a 3% extra amount instantly and a total of 10% off for this sale. The gift certificates can apply for everything, especially for E-cigarette products.
Hi Paul321,
You can contact our Customer service to manually create an order and send a PayPal link to you. Thank you.
Hi blueb8llz,
If the item qty is above 3+, you will get the bulk price automatically. You can contact our CS to manually offer the 12% discount.
Get Your Halloween Treats Early! 15% Off Sitewide Sale
Offer:15% Sitewide Off
Coupon Code: TREAT15
Oct 29th - Nov 2nd, 2022 (UTC-6)
Nitecore NU05 V2 40LM 6500K & Red Ultra Lightweight LED Headlamp Kit
authentic / 4*LEDs / 5-mode / w/0.44Wh battery / USB-C charging / IP66 / PC construction
NU05 V2 can be attached to the headband or the back of the helmet for warning cars or people, aiming to guard your safety at night.
Utilizes 4 x high-performance LEDs
Dual white and red light sources
Built-in rechargeable Li-ion battery with a max runtime of up to 47 hours
Built-in intelligent Li-ion battery charging circuit with a USB Type C charging port
One-handed operable single-switch design
Available with 4 special modes
Built-in power indicator to indicate the remaining battery power
Constructed from durable PC material
Ultralight and compact design
Impact resistance to 1 meter
Fenix PD36R Pro 2800LM 6500K EDC Tactical LED Flashlight w/21700 Battery
authentic / Luminus SFT70 emitter / 6-mode / USB-C charging / IP68 / 380m throw / 36600cd
The Fenix PD36R Pro rechargeable flashlight is a high-performance rechargeable flashlight that is sure to surprise you. Fitted with a Luminus SFT70 LED, this flashlight features an incredible performance by delivering a maximum of 2800 lumens to an impressive distance of 380 meters, all on the included 5000 mAh battery. The high-capacity 5000 mAh battery can be conveniently charged through the USB-C port on the flashlight. Operating this powerful LED rechargeable flashlight is simple with dual tail switches for momentary on/off, the ability to cycle through five lighting modes, and the activation of the instant strobe. Additionally, you will always be able to see the battery’s charge status at a glance with the external battery level indicator. The amount of power and runtime packed into this flashlight are unmatched for its handheld size. IP68-rated dustproof and waterproof, this flashlight is the perfect all-purpose lighting tool for those needing maximum brightness and long runtimes.
Features:
2800 lumens maximum output and 380 meters maximum beam distance.
Uses a Luminus SFT70 LED with a lifespan of 50,000 hours.
Included a 5000 mAh 21700 rechargeable Li-ion battery.
Instant activation and instant strobe with dual tactical tail switch.
Reverse polarity protection, to protect from improper battery insertion
Toughened ultra-clear glass lens with anti-reflective coating
Boot-up battery level indication and low-voltage warning.
Made of A6061-T6 aluminum.
Premium type HAIII hard-anodized anti-abrasive finish.
1m impact resistance
The Proprietary APF system makes a super tactical flashlight.
Intelligent overheat protection (IOP) ensures that the surface temperature does not exceed 60’C to prevent the risk of burns.
Fenix E-CP 1600LM 6000K EDC LED Flashlight w/18.5Wh Battery
authentic / Luminus SST40 / 6-mode / 18W fast charging & discharging / IP68 / 222m throw / 12400cd / power bank function
The Fenix E-CP is a high-output flashlight with a power bank that’s capable of projecting 1,600 lumens with a useful far-reaching beam of 222 meters. The built-in 5000mAh high-capacity battery can last up to 504 hours. This groundbreaking flashlight defines maximum versatility. Use it as an everyday carry light or a mobile power bank - it can handle either job confidently. Its tail is fitted with USB-A and USB Type-C interface, supporting 18W efficient fast charging, whether to charge the light itself or to charge external digital devices such as mobile phones. High-strength aluminum alloy body, IP68 rated protection, E-CP is built to withstand harsh environments, and it is the best choice for your daily use, outdoor activities, and gifts to families and friends.
Features:
1600 lumens maximum output and 222 meters maximum beam distance.
A Luminus LED with a lifespan of 50,000 hours.
Built-in a 5000 mAh rechargeable battery.
Anti-slip body design ensures a firm grip.
The light tail features a power bank function supporting 18W fast charging and discharging.
The electronic lockout function avoids accidental activation.
Made of durable A6061-T6 aluminum.
The flat tail makes tail-stand lighting possible, the power bank function supports emergency lighting needs.
Fenix E-SPARK 100LM 6500K EDC LED Keychain Flashlight w/2.96Wh Battery
authentic / 4*LEDs / 5-mode / USB-C charging / IP24 / 30m throw / 225cd / power bank function / red signal light
Details:
The Fenix E-SPARK a rechargeable keychain flashlight with a power bank function. With the built-in 800mAh battery, it produces a maximum output of 100 lumens. Timely recharge the light through the USB Type-C charging port when you need constant illumination, and this light is capable of charging your mobile phone for emergencies. The functional red light and red flashing are perfect for signaling. Keep this light on your keys, in a pocket, or a drawer to always have a flashlight at your fingertips. Trust this keychain light for your everyday needs.
Features:
100 lumens maximum output and 30 meters maximum beam distance.
Four quality LEDs with a lifespan of 50,000 hours.
Built-in 800 mAh large-capacity Li-Polymer battery.
Power bank function for mobile phone charging with USB Type-C port.
Lockout function avoids accidental activation.
The tail protection cover can be used as a diffuser tip fitted on the light head.
Battery level indication for instant checking of remaining battery level.
Bright 5 lumens red light and red flash offer conspicuous recongnition for vehicles and fellow travelers, providing for safe activities in the dark.
The quality PC-made tail protection cover can be used as a diffuser tip on the light head for a softer dark-adapted vision.
1m impact resistance.
Manker E05 Cu Bundle 400LM 6500K EDC LED Flashlight w/USB-C 14500 Battery
authentic / OSRAM KW CGLNM1.TG emitter / 3-mode / 1*AA / IPX8 / 250m throw / 15625cd / red copper construction
Impact resistance: 2m
Operation: User-friendly One Button Interface
Turn OFF/ON:
When the light is OFF, one click tail switch to turn the light ON.
When the light is ON, one click to turn the light OFF.
Mode Operation:
When the light is ON, half one click the tail switch to cycle through ‘low - High’. Quickly double half-one click to activate the hidden strobe.
When the light is OFF, one click the tail switch to turn on a low level, A single click after this urns the light OFF, and then one click to turn on the High level.
*Please note: *The flashlight is made of red copper. This material is easy to oxidize and turn black in the air, which is a normal phenomenon.
Convoy H3 1400LM 2700K EDC LED Flashlight Headlamp
Nichia 519A R9080 emitter / smooth/stepped ramping / 1*21700 / USB-C charging / IPX4 / 100-200m throw
Battery: 1*21700 lithium battery flat head without a board (not included)
Please note:
Driver instructions:
Click to start up, enter the brightness before the last shutdown, long press the switch to enter step-less dimming (brightness increase), release the switch, and long press the switch again to enter step-less dimming (brightness decrease). When the step-less dimming range (1-100%) reaches the maximum or minimum, it flashes to indicate the maximum or minimum brightness. The brightness of the flashlight can be memorized after releasing the switch.
When the driving temperature reaches 55 degrees, the brightness starts to decrease slowly, and the flashlight will use the reduced brightness as the benchmark, and the reduced brightness will be used for the next startup.
Press and hold for 0.5 seconds to ultra-low brightness (0.2%) in the shutdown state, and click to shut down. If long-press, there will be no response (ultra-low brightness will not be memorized).
Double-click in any state to reach 100% extremely bright (the extremely bright at this time belongs to the part of stepless dimming, click to shut down, and long press for stepless dimming. With memory)
In the shutdown state, click the switch 3 times to enter the burst flash (50% brightness progress) without memory function, and click the switch one time to return to the original state. If long press, no response will be made.
In the shutdown state, click the switch 4 times to enter the tactical momentary on mode. At this time, there is only one gear 100. Press the switch to directly turn on the extremely bright 100, and let go to turn off the light. 4 click to exit the tactical mode. The tactical mode also has temperature control.
In any state, press the switch 5 times and the voltage indicator flashes at 1% brightness (count the number of LED flashes, corresponding to the voltage. For example, the LED flashing pause means that the voltage is 3.7V. Click to return to the original state.
In the shutdown state, click the switch 6 times, the stepless dimming will switch to the conventional four-gear mode (1–10–30–100), click the switch, and long press the switch to change gears. To switch back to stepless dimming, just click the switch 6 times after shutting down.
In the shutdown state, click the switch 10 times to enter the locked state. The light flashes twice at 1% brightness to indicate that it is locked. In the locked state, no matter the long press, short press, or double tap, it will flash once to indicate that it is in the locked state. The lock can be unlocked with another 10 clicks.
Note that this is the only unlocking method. Considering that the flashlight will be accidentally unlocked due to the special situation that the positive electrode of the battery will be separated from the driving copper column and the power will be cut off due to the violent vibration. The flashlight can not be unlocked by manually loosening the tail cover and removing the battery.
Low voltage protection function: when the voltage is lower than 3V, the stepless dimming and gear mode will automatically jump to 1% to work, except for ultra-low light. But it can also be dimmed. If it continues to be below 3V, it will jump back to 1%. It will shut down automatically when it is lower than 2.8V.
Happy Halloween! 15% Off Sitewide Sale! Get Your Halloween Treats Early!
Happy Halloween! Our treat to you! All the witches are talking about this Sale. We launched a 15% discount with the code TREAT15. Don’t miss it!
Halloween Sitewide Sale
Offer: Sitewide 15% Off
Valid Date: Oct 29th - Nov 2nd, 2022 (UTC-6)
By purchasing our gift certificate, you can get a 3% extra amount instantly and a total of 18% off for this sale. The gift certificates can apply for everything, especially for E-cigarette products.
WUBEN X-0 1100LM 6500K EDC LED Flashlight w/4.07Wh Battery
Samsung LH351D emitter / Titanium Alloy / 7-mode / USB-C charging / IP68 / 125m throw / 3920cd / magnetic tail cap / tritium slots for customization / 175’ floodlight
X-0 features a sturdy clip and magnetic tail cap, making it suitable for a range of indoor or outdoor activities!
Designed to also offer stress relief, this serves as a switch, as well as providing optimal water and dust protection for its USB Type C charging port!
Powered by a replaceable Li-ion 18350 battery, it can be fully charged in just 1.5 hours!
Tritium slots for customization
Waterproof: IP68 (submersible to 2m for 1 hour)
Impact resistance: 1.5m
