I think so? This is my first attempt at editing code and compiling. Looking at the notes on the page it seems the latest revision would work for the sp10 pro.
There are no extra pads, you can solder directly on the pins with thin magnet wire but it’s meticulous work. I’ve already done it while debugging drivers. Using a corner pin is less difficult.
Hum…well, when I got home I went to check the spare driver I have and…I guess I would fail completely to solder such thin wires there :o
That thing is tinier than I could remember and my skills and iron and not fit for the job after all
So, I will pass this possibility ti have an SP10 Pro with aux leds. For now
Thanks for your replies folks
Yes, waiting for Tir version. Will be shorter and give better beam with dedomed 519A. Would be nice if they include a kit of 3 type degrees lens, like 15° 45° 90° pebbled.
I have actually tried added an aux led to the SP10 Pro like described above, by soldering a wire directly directly to a pin. It was very difficult but I got it working with a driver that was removed from the light. But the connection so was weak such that when I tested its strength by pulling on it gently, it got disconnected.
32AWG solid wire soldered on two pins, at first I used only one pin and it held well enough, but since the pins are very small it’s easier and likely more robust with on two pins.
Oh man, that is thin!!! Idk, I may risk it. Gotta find the appropriate wire (abroad, local stores don’t have it :person_facepalming: )
Thanks for the inspiration, thefreeman!
And thanks for the report on your experience zumlin !
The usual 30 AWG silicone stranded wire should do as well, especially since as previously mentioned there are 3 consecutive free pins and the wire can be soldered horizontally, soldering on a middle pin is another story. Just put a generous amount of flux.
The enameled wires I often use are those actually it’s 36SWG, which is aprox 33AWG. the solid green insulated wire picture was actcually 30AWG
