Sofirn SP10 Pro (AA/14500/Andúril 2) - now available!
For “magnet wire” I find mostly/only thicker wires with clear enamel coating. But I’m looking for the very thin, colored ones.
The one I listed have colored enamel (they also have 38SWG), but solid wire, not stranded like headphones cables. Searching for stranded enamelled wire gives a couple of results but not colored.
Maybe you would have more luck stripping audio cables with stranded enamelled wires inside, This for example
This is an example of what I get in the US, don’t know how different Germany is
https://smile.amazon.com/s?k=magnet+wire+36awg&sprefix=magnet+wire+36awg
Anyone got the SP10S blue and SP10pro blue? Is the anodizing similar? I no longer have my old SP10S blue but I remember it being light blue while the SP10pro is darker blue.
I might be misremembering the color though.
Hi, I have a ramp config question
  • 7H from ON has 3 ramp config options, while
  • 10H from OFF has 4 config options.
Did anyone discover this part? Does the option 4 has any meaning in the config simple mode ramp config menu?
I’m pretty satisfied with my SP10 Pro (version 2022_04_18), only this minor question remained. It took time for me to understand ramp speed (option 3) does not work for Simple mode, according to Toykeeper’s manual it’s inherited from Advanced. In some versions Option 4 (in the ramp config menu) is the speed parameter, but I learned that for SP10 Pro it is Option 3.
It’s explained in the manual:
Thank you very much for the help. I didn’t find this information in the manual, my fault.
Good tip. I put glue directly on the solder joint after I soldered a wire directly to a pin on a ATTINY1634 to salvage the aux on a lume1 .
I’m so excited about the new low. Any idea how much current it uses? Is it low enough to be an indicator light?
No, the MCU needs to be running, so it still consumes some mA. It might work for a day, but probably not much longer.
Mine appears to only draw ~1.3mA at lowest moonlight mode, so it would probable run several weeks. Not as long as Aux though.
Sticking to lowest ramp floor, with multimeter I get current draw:
3.5 mA with 1.2V cell
3 mA with 1.5V cell
1.3 mA with 3.7V cell
So in any case it would take few hundreds of hours do drain the cell. IMO still not long enough for always-on indicator light, but ocassionally I wouldnn’t hesitate to leave it on as a night light, as it won’t impact whole runtime too much.
thanks for the data
1900mAh/3.5mA per hour/24 hours per day= 22 days.
IF the LiIon is an 800mAh cell:
800/1.3/24 = 25 days
fwiw, a Zebra AA claims 100 days on its lowest mode
Are there modes in which MCU doesn’t need to run? If yes, which are those?
When the flashlight is off the MCU can sleep as well.
The good ’ol 0.00 lumen mode, what other flashlight has a mode this low!?
Only the one that adds four more zeroes. It’s the top secret one that the military doesn’t want you to know about. You’ve probably heard about it on youtube….
What is the different between the current batch SP10V3.0 and SP10pro? Do they use diferent driver? or any other thing to be aware of?
Pro uses Anduril, V3 has Sofirn’s own UI.
I know that they use different UI/OS.
But what hardware driver did they use? Efficiency? Lower and highest mode differences?
I heard that there are problems in the early batch of SP10V3.0. Is the SP10V3.0 problem rectified? Is there a ny new problem surfacing?
