Did anyone discover this part? Does the option 4 has any meaning in the config simple mode ramp config menu?
I’m pretty satisfied with my SP10 Pro (version 2022_04_18), only this minor question remained. It took time for me to understand ramp speed (option 3) does not work for Simple mode, according to Toykeeper’s manual it’s inherited from Advanced. In some versions Option 4 (in the ramp config menu) is the speed parameter, but I learned that for SP10 Pro it is Option 3.
Sticking to lowest ramp floor, with multimeter I get current draw:
3.5 mA with 1.2V cell
3 mA with 1.5V cell
1.3 mA with 3.7V cell
So in any case it would take few hundreds of hours do drain the cell. IMO still not long enough for always-on indicator light, but ocassionally I wouldnn’t hesitate to leave it on as a night light, as it won’t impact whole runtime too much.
Only the one that adds four more zeroes. It’s the top secret one that the military doesn’t want you to know about. You’ve probably heard about it on youtube….
I cannot find if this was mentioned, but the vapcell H10 flattop does not seem to work with my Sofirn SP10Pro. I just got one from Amazon. Maybe only button style 14500 work? there seems to be three gold conductors on the battery post of the positive terminal and they are close together. I may be missing something.
The outer two contacts are not connected electrically. They are a mechanical reverse voltage protection. A flat-top battery won’t make contact with the center contact, only the button of a button-top.
The hardware is supposed to be the same, except the microcontroller was swapped for an Anduril-compatible model, so the efficiency at a given output level should be the same.
The max brightness is the same, but gchart figured out tweaks to make in Anduril to allow the the minimum brightness to be much lower.
