try this:
remove battery, tighten head, loosen, tighten, loosen, then tight again… a few times… my thought is to seat and get good contact of the inner and outer tubes, into the head
fwiw, the switch itself is a very simple affair… the issue is probably not the switch. I expect it is just poor contact from the inner tube end, to the pill.
if that tight twisting fails,
It might be poor contact at the tailcap instead.
one step at a time… the tailcap is glued shut because there is no retaining ring. If tailcap is removed, switch falls out.
btw, at 3.7v a battery is almost half empty. Youre not hurting anything by testing the light at that voltage, but I suggest you charge the batteries before any prolonged use.
Here is a photo of the tail, disassembled:
feel free to private message me if you like. I will be happy to help you figure out how to remove the tailcap, if it comes to that.
first, let us know if the twisting exercise solves the problem.
Brass has about 2/3 less thermal conductivity than Copper,
Brass has about 1/3 less thermal conductivity than Aluminium.
otoh, Brass has about 16 Times better thermal conductivity than Titanium. :student:
imo, buy the metal you like, dont worry about thermal conductivity… just dont use your light in ways that generate high heat… Medium modes are our friends… LOL
I recommend a ceiling of 120/150 = about 350 lumens, and turn Turbo Off, regardless what metal the TS10 is made of.
I’m a little curious as well, just from a general curiosity standpoint. Free-machining brass has more lead in it and these days you don’t see it very often in consumer-marketed products. Photos look like it’s just a tad roughly machined which might indicate hard brass but it could just be the operators in a rush (faster feed rates or speed, not swapping to sharp fresh tools, etc). I don’t know if RoHS compliance would apply here since it isn’t “electronics”, per se. Heat dissipation……brass of any type is never great, might be more of an issue on this particular light if you like to use it in turbo/top of ramp, but ya work with what ya got.
