Sofirn SP10 Pro (AA/14500/Andúril 2) - now available!
The hardware is supposed to be the same, except the microcontroller was swapped for an Anduril-compatible model, so the efficiency at a given output level should be the same.
The max brightness is the same, but gchart figured out tweaks to make in Anduril to allow the the minimum brightness to be much lower.
Thank you. So the sp10pro seems to be the better choice for me. I already got an sp10pro. Thinking of getting v3.0 bit sp10pro can be simplified enough using the simple mode.
how does the LVP looks like? From my testing, it is just stepping down quite fast and that's it, you can still force it to go up for short time. Is that it?
LVP will turn the light off completely, after repeated step downs.
chart from page 1:
however, batteries will rebound and the light can be turned on again, not for long though, it will turn off again more and more quickly, the more you try to drain the already empty battery.
So there's no blinking warning, and so on?
I just took out a 2.5V 14500, because I thought I just had not calibrate the thermal sensor, and that's why it was stepping down. And I was just forcing it to go up...
When I did 3C it just blinked 7 time, and that was not what I was expecting, so took out the battery to see the voltage...
I thought It would just turn off, and then not turn on under 2.75V or so.
I know the 1.5V Ni-MH don't have the LVP, but the Li-ion mode should have one, right?
Do I just need to buy a protected 14500 cell?
stepping down can happen due to heat, or also due to low battery
here is how the LVP Step Down and Thermal Step Down, is described in the Anduril 2 Manual:
“Anduril includes low voltage protection (LVP) and thermal regulation.
LVP makes the light step down to a lower level when the battery is low,
and if the light is already at the lowest level, it shuts itself off.
This activates at 2.8V. LVP adjustments happen suddenly, in large
steps.
Thermal regulation attempts to keep the light from overheating, and
otherwise adjusts output to stay as close as possible to the
user-configured temperature limit. Thermal adjustments happen
gradually, in steps so small they are difficult for humans to perceive.”
not a good habit, as this defeats the step downs by repeated use
good thought, but if you turn it on after it shuts off, you are defeating the protection system
Learn to check battery voltage sooner… Recharge any time the battery goes below 3.6V. Do not wait for LVP.
you could, but, that creates a slightly different problem. With a protected cell, it can shut the light off suddenly and completely, even if the battery is not empty, if you try to use too high an output. I consider sudden darkness very UnDesireable, so I dont use protected batteries.
fwiw there IS also LVP for AA…
I have been on vacation with my SP10 PRO as my sole torch for the last week. I’m running a standard eneloop straight from the package. The performance has been beyond my expectations. I have run the light as a ceiling bouncer, shuffle to the loo illuminator, and rigging out pre-dawn fishing gear. I have well over 3 hours on the cell with no discernable loss of output. What a great combo.
Kudos to jon_slider for pointing out all the good things low and slow with this light.
Yay! :beer:
little update, on my SP10 pro magnetic tail drama.
Contacted the ali store, they refused to send a good one for free
(had to pay 0.8$ for shipping with tracking, well i can understand that, and it was comparable, to getting the old one refunded, and buying new one, so I accepted it)
after 3 weeks I got it, and well this one surely won't work.
Yes that's the 18650 one, for SC31 pro and so on, not the 14500 for SP10 pro.
Ps. I do have SC31 pro, but I have black one, and I already bought a magnetic tail for it, so this one is useless for me, at this time.
I ordered the SP10 Pro and magnetic tail cap direct from their Chinese store (not AliExpress.) The correct one arrived luckily. I’ve had similar experiences on AliExpress with other sellers- they refuse to replace faulty/ incorrect goods and want you to pay postage when it’s their fault. :rage: I just don’t buy anything else off them ever again.
Is the Lumintop Tool AA tailcap mechanically compatible with the Sofirn SP10 Pro? Can I use a Lumintop magnetic tailcap on the SP10 Pro?
No, the SP10 is slightly wider than the Tool-AA.
Thank you very much for the quick and accurate answer. Have a very good day.
Does blink during ramp still present or was removed on this batch?
yes, no
but if you are set up for reflashing, there is a Hex from gchart without the blink
Don’t have right hardware now and I lack of experience, risk to brick driver.
I wonder why Sofirn doesn’t correct by flash right FW .
Blink is present even in HS10 headlamp with propietary ramp UI :frowning:
fwiw, the blink in the ramp is part of the Normal Anduril UI installation
It would not make sense for Sofirn to reflash all the lights they already made, to put on the custom firmware you would like
If you want the NoBlink custom firmware, you could pay someone in Europe to install it for you, maybe ask the_freeman, SammysHP, Unheard…
Gchart, do you still have flashing kits for sale? I sent a PM but I’m not sure if you prefer posting here instead.
Is the only emitter option still 5000k? Hoping for 4000.
Hoping for Nichia 519A
