Does this mean we will see new drivers with stepless ramping for other flashlights? For example, side switch flashlights with the ability to ramp up and down in brightness?
M21d and onward already do. But the interface has issues, the big one being the uneven ramp speed. This is why I keep bugging Simon about flashing pads and source code, so that he has to make only one change on any new driver designs, and users do the rest. For example, there was a tussle about what mode group spacings were best for the mechanical switch lights, the debate would be obviated with easy firmware updates.
I think the side e-switch flashlights do have true ramping but it gets slow at high brightness (and fast at low)… I’m not sure because I don’t own one yet, I’ve been hoping for a update to the UI for, at a minimum, a visually linear brightness ramp.
I’ve been holding off since the first side eswitch m21* were released… I’m not going to buy one now just to learn a month later that the UI was upgraded with anduril haha
I have a S21D with 4 519A LEDs. I put it into a 50% maximum mode but it reaches about 60°C after a few minutes on the front side. On 100% I cannot touch the flashlight anymore.
Is that normal? The driver is 8A.
The S21E has USB-C charging, side e-switch, stepped/ramping UI, general purpose beam profile (reflector), and is slightly more compact.
S21D has a no internal charging, tail switch, Biscotti/12-group UI, floody beam profile with 30/60 degree optics (TIR), approx. 50% more sustained lumens, approx. 100% more max lumens. (A side switch/USB-C version is coming soon).
