I’m trying to find a firmware to use for a twisty flashlight. I’ve never really played with twisties but I can only imagine trying to use something with a complex ui like Anduril would be a nightmare. Has anyone even done a firmware geared toward this? I couldn’t find anything in Toykeeper’s repository, anyway.
I got an ITP A2 Eos (the last remaining cr2 light afaict) and it has room for a 15mm driver, so I’ll probably use one of the mtn-15dd ones. The stock driver is a crappy boost converter made for disposables. I just want something basic like L-M-H i guess.
Any simple clicky UI can work for a twisty. The “standard” firmware option from MTN should work fine. I believe it is best to use a special fuse setting in order to prevent mode skipping: -Ulfuse:w:0x79:m This adds a 64ms startup delay for the MCU. You could ask mtn to flash it with this fuse setting.
Ok cool - if the startup delay helps, that should be good enough. I can flash it myself, I’m building from source because i want to customize the levels anyway and not use the FET, to avoid melting the thing. I just didn’t want to deal with trying to imitate 50mS button “clicks” by twisting the head really fast. Thanks.
For twisty use it is probably best to avoid clicky firmwares with fancy timing based mode controls like Bistro. Stick to Starry-offtime, Star_noinit, etc.
Ok so this worked out really well, I hacked up an old biscotti firmware, so no long-press reverse cycle etc, and cut down the mode list a bit, and made it work on a mtn-15dd driver board. Voltage and temp cutoff work, no problems so far.
For me on FreeBSD bzr is no longer an option unless I install python 2.7 myself (no pkg, no port, as it has been deprecated and brz needs 2.7)
I tried compiling the anduril code (on FreeBSD) and other firmwares and some compile, others not and similarly I get error messages compling firmware for the at1616 series. Not sure what the problem is exactly, it looks like missing definitions in the atmel pack but perhaps the source of the errors lies elsewhere. More on this in the next message.
The T1616 DFP error message should point to a readme in /bin IIRC, where there are instructions for installing it (downloading and pointing to its path in build.sh or something).
bzr which I used on FreeBSD 13.0 to download an older snapshot is longer supported on FreeBSD 13.1. brz is available as a port/pkg but I didn’t need it after all as despite the comment above of the download on launchpad not working, I just tried it and it did work:
2. click “Browse the code”, then “view revision”, then “download tarball”.
Then install software:
3 pkg install avr-gcc
4 pkg install avr-libc
This uses avr-libc 2.0.0 so I later modified the port to compile 2.1.0
5 for linuxisms (bash): ln -s /usr/local/bin/bash /bin/bash
6. The README in the zip says to download an Atmel pack for newer attiny1 series (needed as I wanted to change the firmware in the latest version of the SC31pro).
and use the environment variable as stated in the README
7. Compiling.
I had already tried to compile for example ‘crescendo’ before downloading the Atmel pack and before updating avr-libc and that worked fine.
The 2 pocket lamps I want to reprogram are, with version/type identifier if I counted correctly:
- SC31pro, version check says: 2022 02 08 (then not a zero but a long pause, I guess this is a change in later anduril versions to not give leading zeroes but a long pause) 614 [ From the table of models/firmwares: 614 = sofirn-sp36-t1616 attiny1616, is that correct? ]
- D4V2 219b sw45k + boost driver: 2021 11 12 0273 [ 0273 = noctigon-dm11-12v attiny1634, is that correct? ]
I tried hello_world and which gave errors, the inline functions are not recognized or not treated correctly by the compiler it seems:
JonnyC/STAR/STAR:
avr-gcc -Wall -g -Os -mmcu=attiny13 -o STAR STAR.c
/usr/local/lib/gcc/avr/11.2.0/…/…/…/…/avr/bin/ld: /tmp//ccOwF4CX.o: in function `main’:
anduril2-r653/JonnyC/STAR/STAR/STAR.c:(.text.startup+0x8): undefined reference to `ADC_on’
/usr/local/lib/gcc/avr/11.2.0/…/…/…/…/avr/bin/ld: /tmp//ccOwF4CX.o: in function `__vector_8’:
etc.
Same happens in hello_world.
Removing the ‘inline’ keyword makes them compile. Weird, what could be the issue?
Then in ToyKeeper/spaghetti-monster/anduril/
‘make’ gives:
= 40 builds succeeded, 22 failed =
Some give too much code such as:
= emisar-d4s-219c =
/usr/local/lib/gcc/avr/11.2.0/…/…/…/…/avr/bin/ld: anduril.elf section `.data’ will not fit in region `text’
/usr/local/lib/gcc/avr/11.2.0/…/…/…/…/avr/bin/ld: region `text’ overflowed by 10 bytes
collect2: error: ld returned 1 exit status
then the attiny1 series give other issues:
= sofirn-sp36-t1616 =
In file included from …/fsm-standby.c:24,
from …/spaghetti-monster.h:74,
from anduril.c:92:
…/fsm-standby.c: In function ‘sleep_until_eswitch_pressed’:
…/fsm-standby.c:59:9: error: ‘MCUCR’ undeclared (first use in this function)
59 | set_sleep_mode(SLEEP_MODE_PWR_DOWN);
MCUCR looks to be defined in many header files in the Atmel pack but not for the attiny1616, unless it uses another include too which for some reason doesn’t get included.
The avr-gcc compiler version number (avr-gcc -v) is 11.2.0
There is a port of brz so I could use that but as downloading tarball works I skipped it.
I will have a look at your docker files and devel versions of avr-libc.
Definitely no zero, but instead a pause. I made a video of the output of both lamps so I could check the counting, without having to go into version check multiple times to be sure. I had a look again, no zero…
Yes, but it should compile or not? Is ‘inline’ no longer working correctly? Seems weird.
I tried docker but for some reason the daemon doesn’t want to start, there is some contradictory information about renamed files in the FBSD guide so I will look into that later.
The main thing is to get the firmware for the D4V2 compiled and the SC31pro, not worried about code size as I will remove code anyway, so could you give the steps to compile the devel version of avr-libc? There is no configure file (logically) and though I have automake and autoconf installed, trying those I get errors about missing M4 files. This information would probably be useful for anyone else who wants to do this.
